Не могу подключится к Report Server 2005
Добрый день, строка подключения такая: server=http://testsrv/ReportServer$SQL2005;datasource=/ModelNew - не проходит, это я пытаюсь подключится из Visual Studio, из SQL Server Studio подключение проходит, но там не указывается datasource, в чем может быть проблема? ... |
| 14.06.2006, 16:08:28 |
Что в сообщении об ошибке? --- This posting is provided "AS IS" with no warranties, and confers no rights. ... |
| 20.06.2006, 11:43:39 |
TITLE: Microsoft Report Designer ------------------------------ A connection cannot be made to the database. Set and test the connection string. ------------------------------ ADDITIONAL INFORMATION: The path of the item "ModelNew" is not valid. The path must be less than 260 characters long and must start with slash. Other restrictions apply. ---> The path of the item "ModelNew" is not valid. The path must be less than 260 characters long and must start with slash. Other restrictions apply. (Microsoft.ReportingServices.DataExtensions) ------------------------------ The path of the item "ModelNew" is not valid. The path must be less than 260 characters long and must start with slash. Other restrictions apply. ---> The path of the item "ModelNew" is not valid. The path must be less than 260 characters long and must start with slash. Other restrictions apply. (System.Web.Services) ... |
| 20.06.2006, 15:30:41 |
start [/forum/topic.php?desktop=1&fid=31&tid=1538932]: |
23ms |
45ms |
58ms |
| others: | 330ms |
| total: | 499ms |
