CR11R2. Как удалить секцию? Как удалить группировку? (runtime)
Можно ли и как? ... |
| 26.12.2007, 13:45:40 |
Вот что нарыл: How can I modify a report using the Crystal Reports .NET SDK? автор Symptom Prior to the release of Crystal Reports XI R2 Service Pack 2, report modification was only possible using the RAS (Report Application Server) SDK with a RAS server or by using In-Process RAS with the purchase of additional licensing. Cause As of the release of Service Pack 2 for Crystal Reports XI R2, the RAS SDK is available to developers without the need for a RAS server to process the reports without additional licensing. Report modification such as changing/adding/removing database providers, adding/removing/creating report objects, parameters, formulas, sections etc. can be achieved by accessing the RAS SDK through the Crystal Reports .NET SDK. ... Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. 21. 22. 23. Только вот откуда брать класс ISCDReportClientDocument? Нет у меня ClientDoc, Controllers, DataDefModel. ... |
| 26.12.2007, 15:31:29 |
У меня CR11R2SP3 Developer. ... |
| 26.12.2007, 15:32:34 |
Нашёл сборки. ... |
| 26.12.2007, 15:38:32 |
Тех справочнике есть Sections Collection с методами Add и Delete, но "у меня" в проекте на .NET этих методов нет. ... |
| 27.12.2007, 09:48:50 |
start [/forum/topic.php?desktop=1&fid=31&tid=1537366]: |
51ms |
47ms |
| others: | 315ms |
| total: | 476ms |
