SQL Server Reporting Services - как засунуть картинку?
Всем привет :) Объясните бестолковому, как в отчет засунуть картинку? Логотип фирмы. BMP или JPG или GIF Отчет выполняется на стороне сервера. ... |
| 30.05.2008, 17:40:00 |
The easiest Example I can give is the following. Open your .rdl or .rdlc file in the VS designer. At the top you should of a menu item called "Report". Click it, and on the dropdown choose "Embedded Images". Then choose New Image, and browse to your image. Once you've completed that... Choose your image control, Change it's Source to embedded and then hit the drop down for value and you should be able to choose the image you just embedded. ... |
| 31.05.2008, 17:23:03 |
start [/forum/topic.php?desktop=1&fid=31&tid=1536989]: |
48ms |
66ms |
| others: | 310ms |
| total: | 505ms |
