Ошибка коннекта к Report Server
Всем привет. Недавно начал знакомство с SQL ( SQL Server 2014) - обучаюсь на локальном сервере: подключения к Database Engine, Analysis Services создаются норм, в первый день и к Reporting Services подключался, теперь выскакивает ошибка : ЗАГОЛОВОК: Connect to Server ------------------------------ Cannot connect to SIBLING. ------------------------------ ДОПОЛНИТЕЛЬНЫЕ СВЕДЕНИЯ: Unable to connect to the server at SIBLING. The specified URL might not be valid or there might be a problem with the report server version or configuration. Specify a different URL, or contact your server administrator to verify that the report server runs SQL Server 2008 or later. Additionally, if you are trying to connect to a SharePoint-integrated report server, verify that SharePoint is installed on the server and that the report server uses SharePoint integrated mode. (Microsoft.SqlServer.Management.UI.RSClient) ------------------------------ Прошу помочь. Спасибо. Модератор: Тема перенесена из форума "Microsoft SQL Server". ... |
| 09.02.2015, 13:32:05 |
Законнектился. Решение: After hours of research and trying different things this was eventually solved by 1./ Removing all the urls for webservice and report manager url in Reporting Services Configuration Manager. 2./ Manually editing the rsreportserver.config file and removing any entries between the tags (there were some not being cleaned up properly ) 3./ Restarting the SSRS service, and readding the URL’s with a fresh port number ( I had already tried changing port numbers earlier with no success) 4. Поиграться с TCP Port в Reporting Services Configuration Manager ... |
| 09.02.2015, 15:49:20 |
start [/forum/topic.php?desktop=1&fid=31&tid=1533465]: |
30ms |
65ms |
26ms |
72ms |
| others: | 274ms |
| total: | 508ms |
