Microsoft Reporting Services. Разрыв страницы.
Как добавить разрыв страницы при определенном количестве строк? заранее благодарен ... |
| 05.08.2015, 15:54:24 |
| 05.08.2015, 16:05:39 |
1. Create a top parent group. 2. In 'Group by' expression write =Int((RowNumber(nothing))/10) (change 10 to your desired number) 3. Click Ok. In table, delete the first column ('Columns only') if a column group is created for this newly created group. 4. In Group properties - enable Page Break - Between each instance of the group. Also Delete sort expression for this new group. ... |
| 05.08.2015, 17:23:47 |
start [/forum/topic.php?desktop=1&fid=31&tid=1533363]: |
43ms |
55ms |
| others: | 259ms |
| total: | 423ms |
