Перепрошивка Datamax 4204b
Добрый день. Кто - нибудь перепрошивал с сайта производителя принтеры этикеток Datamax 4204b? http://www.datamax-oneil.com/do/com/en-us/home/printers-software/stationary-printers/desktop-printers/e-class-mark-iii (E-Class Mark III Pro/Pro+ Firmware Ver. 9.03_0026) Как я понял, надо скачать файл а потом запустить его на копирование на порт lpt1 ... copy filename.zg lpt1/b .. Индикатор зеленым замигает и он перезагрузится. Но как быть, если принтер устанавливается на USB001 или USB002? o_O авторThe operating programs and fonts for the printer are stored in Flash memory on the Main PCB. When program updates and/or new features are added, they can be downloaded to the printer as follows: 1. Identify the new version for your model of printer from the Datamax-O’Neil FTP site at ftp.datamaxoneil.com and download it onto your computer’s hard drive or a floppy disk. 2. Ensure that the printer is connected to the host and that the power is ON. Using the DOS copy command, enter: copy filename.zg lpt1/b Other programs (e.g., hyper-terminal and certain Windows Driver programs) may also be used to download this file. 3. The Green LED will flash during the download. 4. Following a successful download, the printer will reset. The previous printer setup will be unaffected unless substantial firmware data structure changes have occurred. Print a Database Configuration Label to verify your new firmware version. Following an unsuccessful download, the RED LED will turn on, then the printer will reset. The original firmware will remain operational. If the printer fails to reset, cycle power OFF and ON. Try re-sending the file to the printer. If the failure continues, check the following possible causes: An invalid or corrupted file is being downloaded - Ensure the file being downloaded is correct and applicable for your printer model. Possible communications error - Check the cable connection between the host and printer and ensure that a quality, shielded cable is used. Possible Flash memory problem - Call for service. ... |
| 19.08.2015, 06:08:53 |
start [/forum/topic.php?desktop=1&fid=30&tid=1529298]: |
177ms |
| others: | 198ms |
| total: | 438ms |
