JDE. Ошибка лицензирования: "You are not licensed to execute this published application"
Всем Добрый день! Помогите пожалуйста решить проблему в JD: при нажатии на кнопку "Завершение ЗНР" (Р31225) выскакивает ошибка: "You are not licensed to execute this published application". Под учеткой администратора тоже не работает. jde.log ничего не показывает (в прикриплении). Права на следующие ветки реестра всем пользователям даны Full control: (ссылка http://discussions.citrix.com/topic/269557-running-jde-oneworld-xe-as-a-published-app-you-are-not-licensed-to-execute-this-published-application/) 11. Set the following keys to Full Control for users: HKEY_LOCAL_MACHINE\Software\JDEdwards HKEY_LOCAL_MACHINE\Software\Microsoft\Cryptographic\RNG HKEY_LOCAL_MACHINE\Software\Classes\CLSID HKEY_CURRENT_USER\Software\JDEdwards (this usually has the right permissions by default) HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\MediaProperties\PrivateProperties\Joystick\Winmm 12. Full control to HKEY_CLASSES_ROOT must be given to JDE Users as the application will try to recreate the below registry keys. HKEY_CLASSES_ROOT\ONEWORLD.JDEAPPLICATION HKEY_CLASSES_ROOT\JDEPPCOM.Column HKEY_CLASSES_ROOT\JDEPPCOM.DataItem HKEY_CLASSES_ROOT\JDEPPCOM.DataStructure HKEY_CLASSES_ROOT\JDEPPCOM.Environment HKEY_CLASSES_ROOT\JDEPPCOM.Library HKEY_CLASSES_ROOT\JDEPPCOM.Table HKEY_CLASSES_ROOT\JDEOBJECTBROWSETABCTRL HKEY_CLASSES_ROOT\JDEdwards.Application HKEY_CLASSES_ROOT\TypeLib HKEY_CLASSES_ROOT\CLSID\{A0926C50-8658-11CF-8806-0000F692D87A} HKEY_CLASSES_ROOT\CLSID\{A0926C50-8658-11CF-8806-0000F692D87A}\InprocHandler32 HKEY_CLASSES_ROOT\CLSID\{A0926C50-8658-11CF-8806-0000F692D87A}\ProgID HKEY_CLASSES_ROOT\JDEOCX.CJDETestGridOCX.1 HKEY_CLASSES_ROOT\JDEOCX.JDEAOCtrl.1 HKEY_CLASSES_ROOT\JDEOCX.JDEDbGridCtrl.1 HKEY_CLASSES_ROOT\EMPTY.Empty2Ctr2.1 HKEY_CLASSES_ROOT\EMPTY.Empty2Ctr3.1 HKEY_CLASSES_ROOT\EMPTY.Empty2Ctr4.1 HKEY_CLASSES_ROOT\EMPTY.Empty2Ctr5.1 HKEY_CLASSES_ROOT\EMPTY.JDEColListOcx. ... |
| 21.10.2014, 14:38 |
Включите режим отладки в ini-фале и посмотрите что пишется в JDEDEBUG Режим отладки включается так: [DEBUG] Output=FILE ... |
| 23.10.2014, 15:12 |
В прикриплении ... |
| 24.10.2014, 13:24 |
Проверьте наличие версии KAM0002 приложения P31114 (именно она вызывается при выполнении пункта меню) Возможно ее нет, либо ошибка в коде версии. Создайте новую, используя латинские буквы и ее пропишите в параметрах P5531225 и P31225 ... |
| 27.10.2014, 12:22 |
Александр Войман, Версия есть, но при запуске любой этого приложения ошибка. К приложению P31114 вообще нет доступа, ни к созданию версии (при попытке Добавить ничего не происходит), ни к добавлению в проект. Предпологалось сделать копию отчета (версии), перед этим попытались добавить в проект, а написало ошибку: Error - Action: AddObjectToProject called for: Project: P31114 Object: P31114!KAM0002 Type: APPLVER by User: ... returned Error: 40. (Not licensed to access object) Есть следующая идея (но еще не согласована с руководством, т.к. могут быть риски): 1) на deploymen сервере запустить утилиту, которая перерегистрирует SPC код; 2) Зайти на client сервера и запросить лицензии (GetAuth/Получить). ... |
| 27.10.2014, 16:55 |
start [/forum/topic.php?desktop=1&fid=29&tid=1525903]: |
145ms |
37ms |
| others: | 211ms |
| total: | 435ms |
