Журнал
Как можно просмотреть в Win2000Server журнал для входящих соединений? Т.е. в какое время был коннект, с какого телефона (если есть колбэк), айпишник компьютера и все в таком роде? ... |
| 14.07.2003, 16:04:56 |
Журнал
Что, неужели такой возможности в винде нет? Хотя б в какое время было соединение и с какого телефона (если включен колбэк)... ... |
| 16.07.2003, 08:27:47 |
Журнал
Народ!!! Кто-нибудь подскажите как это делается? или в win2000Srv или в Win2000Pro. ... |
| 21.07.2003, 08:35:47 |
Журнал
Authentication and Accounting Logging A remote access server running Windows 2000 supports the logging of authentication and accounting information for remote access connections in local logging files when Windows authentication or Windows accounting is enabled. This logging is separate from the events recorded in the system event log. You can use the information that is logged to track remote access usage and authentication attempts. Authentication and accounting logging is especially useful for troubleshooting remote access policy issues. For each authentication attempt, the name of the remote access policy that either accepted or rejected the connection attempt is recorded. The authentication and accounting information is stored in a configurable log file or files stored in the %SystemRoot%\System32\LogFiles folder. The log files are saved in Internet Authentication Service (IAS) 1.0 or database format, meaning that any database program can read the log file directly for analysis. If the remote access server is configured for RADIUS authentication and accounting and the RADIUS server is a Windows 2000 computer running IAS, then the authentication and accounting logs are stored in the %SystemRoot%\System32\LogFiles folder on the IAS server computer. Event Logging On the Event logging tab on the properties of a remote access server, there are four levels of logging. Select Log the maximum amount of information and try the connection again. After the connection fails, check the system event log for events logged during the connection process. After you are done viewing remote access events, select the Log errors and warnings option on the Event logging tab. ... |
| 21.07.2003, 09:44:25 |
start [/forum/topic.php?desktop=1&fid=26&tid=1517185]: |
61ms |
| others: | 201ms |
| total: | 314ms |
