Купил Девайс новый. Что скажете? В Дум 3 поиграю?
------------------ System Information ------------------ Time of this report: 11/28/2004, 20:41:36 Machine name: C0V1K5 Operating System: Windows 98 (4.10, Build 2222) A Language: English (Regional Setting: Russian) System Manufacturer: n/a System Model: n/a BIOS: Phoenix Processor: AMD Sempron(tm) , MMX, 3DNow, ~1.7GHz Memory: 256MB RAM Page File: 154MB used, 1637MB available Windows Dir: C:\WINDOWS DirectX Version: DirectX 9.0b (4.09.0000.0902) DX Setup Parameters: Not found DxDiag Version: 4.09.0000.0902 32bit ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: The file ATI2DRAG.DRV is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). Current drivers tested for a WHQL logo are only available on Windows ME, Windows 2000, and Windows XP. New Windows 98 drivers are no longer tested for WHQL logos. Sound Tab 1: The file viaudios.SYS is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: ABIT R9600XT Manufacturer: ATI Tech. - Enhanced Chip type: RADEON 9600 XT AGP Pro (0x4152) Rev 0 DAC type: Internal Device Key: Enum\PCI\VEN_1002&DEV_4152&SUBSYS_6195147B&REV_00\000800 Display Memory: 255.0 MB Current Mode: 800 x 600 (32 bit)(optimal refresh rate) Monitor: Default Monitor Monitor Max Res: Driver Name: ATI2DRAG.DRV Driver Version: 4.14.0001.9148 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 5/8/2004 22:36:42, 95488 bytes WHQL Logo'd: No WHQL Date Stamp: None VDD: *vdd,*vflatd Mini VDD: ATI2VXAG.VXD Mini VDD Date: , 0 bytes Device Identifier: {D7B71EE2-0212-11CF-3877-9441A1C2C935} Vendor ID: 0x1002 Device ID: 0x4152 SubSys ID: 0x6195147B Revision ID: 0x0000 Revision ID: 0x0000 Video Accel: ModeMPEG2_C ModeMPEG2_D Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: VIA AC'97 Audio (WAVE) Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: PCI\VEN_1106&DEV_3059&SUBSYS_0A811019&REV_50\BUS_00&DEV_11&FUNC_05 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: viaudios.SYS Driver Version: 6.14.0001.3850 (English) Driver Attributes: Final Retail WHQL Logo'd: No Date and Size: 2/26/2003 16:04:00, 370048 bytes Other Files: viaudios.SYS Driver Provider: VIA Technologies, Inc. HW Accel Level: Full Cap Flags: 0xF5F Min/Max Sample Rate: 8000, 48000 Static/Strm HW Mix Bufs: 1, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: VIA AC'97 Audio (WAVE) Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: viaudios.SYS Driver Version: 6.14.0001.3850 (English) Driver Attributes: Final Retail Date and Size: 2/26/2003 16:04:00, 370048 bytes Cap Flags: 0x40 Format Flags: 0xFFF ----------- DirectMusic ----------- DLS Path: C:\WINDOWS\system32\drivers\gm.dls DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port VIA AC'97 Audio (WAVE), Software (Kernel Mode), Output, DLS, Internal MIDI Mapper, Hardware (Not Kernel Mode), Output, No DLS, Internal Microsoft GS Wavetable SW Synth, Hardware (Not Kernel Mode), Output, No DLS, Internal Registry: OK Test Result: Not run ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Poll w/ Interrupt: Yes Registry: OK ----------- USB Devices ----------- ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ ---------------------------- DirectPlay Service Providers ---------------------------- DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900) DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900) DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900) DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (4.09.0000.0900) Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (4.09.0000.0900) Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (4.09.0000.0900) Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (4.09.0000.0900) IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (4.09.0000.0900) DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run DirectPlay Test Result: Not run Registry: OK ------------------- DirectPlay Adapters ------------------- DirectPlay8 TCP/IP Service Provider: VIA Rhine II Fast Ethernet Adapter - DirectPlay8 TCP/IP Service Provider: Microsoft TV Data Adapter. - DirectPlay8 Modem Service Provider: Standard 28800 bps Modem DirectPlay8 Serial Service Provider: COM1 ----------------------- DirectPlay Voice Codecs ----------------------- Voxware VR12 1.4kbit/s Voxware SC06 6.4kbit/s Voxware SC03 3.2kbit/s MS-PCM 64 kbit/s MS-ADPCM 32.8 kbit/s Microsoft GSM 6.10 13 kbit/s TrueSpeech(TM) 8.6 kbit/s ------------------------- DirectPlay Lobbyable Apps ------------------------- ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 52.0 GB Total Space: 76.3 GB File System: FAT32 Model: IDE DISK TYPE47 Drive: d: Model: LITE-ON CD-RW SOHR-5238S ------------------ DirectX Components ------------------ ddraw.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 384000 bytes ddraw16.dll: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 28496 bytes ddrawex.dll: 4.87.0000.0700 English Final Retail 9/9/1999 07:00:00 24092 bytes ddraw.vxd: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 30469 bytes ddhelp.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes dxapi.sys: 4.87.0000.0700 English Final Retail 9/9/1999 07:00:00 2170 bytes d3d8.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 1208320 bytes d3d9.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 1648640 bytes d3dim.dll: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 625690 bytes d3dim700.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 892416 bytes d3dramp.dll: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 589852 bytes d3drm.dll: 4.06.0002.0436 English Final Retail 4/23/1999 22:22:00 446464 bytes d3dxof.dll: 4.06.0002.0436 English Final Retail 4/23/1999 22:22:00 118784 bytes d3dpmesh.dll: 4.06.0002.0436 English Final Retail 4/23/1999 22:22:00 102400 bytes dplay.dll: 4.03.0000.1096 English Final Retail 4/23/1999 22:22:00 57344 bytes dplayx.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 229376 bytes dpmodemx.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 90112 bytes dpwsock.dll: 4.03.0000.1096 English Final Retail 4/23/1999 22:22:00 40960 bytes dpwsockx.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 86016 bytes dplaysvr.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 40960 bytes dpnsvr.exe: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 28672 bytes dpnet.dll: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 720896 bytes dpnlobby.dll: 4.09.0000.0900 English Final Retail 3/24/2003 09:00:02 16384 bytes dpnaddr.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 16384 bytes dpvoice.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 385024 bytes dpvsetup.exe: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 86016 bytes dpvvox.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 122880 bytes dpvacm.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes dpnhpast.dll: 4.09.0000.0901 English Final Retail 3/24/2003 09:00:02 45056 bytes dpnhupnp.dll: 4.09.0000.0901 English Final Retail 3/24/2003 09:00:02 73728 bytes dpserial.dll: 4.03.0000.1096 English Final Retail 4/23/1999 22:22:00 49152 bytes dinput.dll: 4.08.0001.0901 English Final Retail 10/30/2001 08:10:00 667648 bytes dinput8.dll: 4.08.0001.0901 English Final Retail 10/30/2001 08:10:00 692224 bytes dinput.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 10874 bytes dimap.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 94208 bytes diactfrm.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 466944 bytes vjoyd.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 33882 bytes joyhid.vxd: 4.88.0001.0881 English Final Retail 12/12/2002 00:14:32 13067 bytes joy.cpl: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 442368 bytes gcdef.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 491520 bytes gchand.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 6656 bytes pid.dll: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 40960 bytes gameenum.sys: 4.07.0000.0700 English Final Retail 9/9/1999 07:00:00 10512 bytes hidgame.sys: 4.07.0000.0700 English Final Retail 11/27/1999 07:00:00 8880 bytes msanalog.vxd: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 12745 bytes msjstick.drv: 4.08.0001.0881 English Final Retail 10/30/2001 08:10:00 2352 bytes dsound.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 475648 bytes dsound3d.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 1331200 bytes dsound.vxd: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 47664 bytes dswave.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 17920 bytes dsdmo.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes dsdmoprp.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 489984 bytes dmusic.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 114688 bytes dmusic16.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 10992 bytes dmusic32.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 28672 bytes dmband.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 26624 bytes dmcompos.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 57856 bytes dmime.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 171008 bytes dmloader.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 32768 bytes dmstyle.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 98304 bytes dmsynth.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 100352 bytes dmscript.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 76288 bytes dx7vb.dll: 4.09.0000.0900 English Final Retail 12/12/2002 00:14:32 602112 bytes dx8vb.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes dxdiagn.dll: 4.09.0000.0902 English Final Retail 5/30/2003 09:00:02 1638400 bytes mfc40.dll: 4.01.0000.6140 English Final Retail 4/23/1999 22:22:00 933888 bytes mfc42.dll: 6.00.8447.0000 English Beta Retail 4/23/1999 22:22:00 995383 bytes wsock32.dll: 4.10.0000.1998 English Final Retail 11/27/2004 22:44:08 40960 bytes amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 65024 bytes devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 134656 bytes dxmasf.dll: 6.04.0007.1121 English Final Retail 9/21/2001 14:44:32 498448 bytes mciqtz.drv: 4.00.0096.0729 English Final Retail 12/12/2002 00:14:32 11776 bytes mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 135168 bytes msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 12800 bytes encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40 241664 bytes qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 257024 bytes qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 311808 bytes qdvd.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 445952 bytes qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1795584 bytes qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1845248 bytes quartz.vxd: 4.00.0000.0501 English Final Retail 12/12/2002 00:14:32 5672 bytes strmdll.dll: 4.01.0000.3925 English Final Retail 4/20/2001 12:14:22 251904 bytes vidx16.dll: 0.00.0000.0000 English Final Retail 4/22/1999 11:28:28 10240 bytes iac25_32.ax: 2.00.0005.0050 English Final Retail 4/23/1999 22:22:00 198656 bytes ir41_32.ax: 4.31.0016.0002 English Final Retail 4/23/1999 22:22:00 857600 bytes ir41_qc.dll: 0.00.0000.0000 English Final Retail 4/23/1999 22:22:00 135168 bytes ir41_qcx.dll: 0.00.0000.0000 English Final Retail 4/23/1999 22:22:00 352256 bytes ir50_32.dll: 5.1026.0015.0041 English Final Retail 4/23/1999 22:22:00 753664 bytes ir50_qc.dll: 5.00.0063.0038 English Final Retail 4/23/1999 22:22:00 212992 bytes ir50_qcx.dll: 5.00.0064.0038 English Final Retail 4/23/1999 22:22:00 196608 bytes ivfsrc.ax: 5.03.0002.0038 English Final Retail 4/23/1999 22:22:00 139264 bytes mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 324608 bytes ks.sys: 4.90.3010.0900 Russian Final Retail 12/12/2002 00:14:32 126464 bytes ksproxy.ax: 4.90.3010.0900 Russian Final Retail 12/12/2002 00:14:32 117760 bytes ksuser.dll: 4.90.3010.0900 Russian Final Retail 12/12/2002 00:14:32 4096 bytes stream.sys: 4.90.3010.0900 Russian Final Retail 12/12/2002 00:14:32 46080 bytes mspclock.sys: 4.90.3010.0900 Russian Final Retail 12/12/2002 00:14:32 5248 bytes mskssrv.sys: 4.90.3010.0900 Russian Final Retail 12/12/2002 00:14:32 7424 bytes swenum.sys: 4.90.3010.0900 Russian Final Retail 12/12/2002 00:14:32 4096 bytes mstee.sys: 4.90.3010.0900 Russian Final Retail 12/12/2002 00:14:32 5504 bytes bdaplgin.ax: 5.03.0000.0900 Russian Final Retail 2/17/2003 09:14:36 16896 bytes bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:36 11392 bytes msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:42 52224 bytes psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:50 354816 bytes psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:52 30208 bytes ipsink.ax: 5.03.0000.0900 Russian Final Retail 2/17/2003 09:14:38 14848 bytes mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:40 56832 bytes ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:48 8448 bytes mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:40 15104 bytes streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:54 14464 bytes msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 09:14:44 481792 bytes slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:54 10880 bytes nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:48 83968 bytes ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:36 16384 bytes vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:54 27648 bytes msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:46 16896 bytes kstvtune.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:15:04 274432 bytes ksxbar.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:40 39936 bytes kswdmcap.ax: 5.03.0000.0900 English Final Retail 2/17/2003 09:15:04 226304 bytes vfwwdm32.dll: 4.10.0000.2222 English Final Retail 4/23/1999 22:22:00 73728 bytes wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:56 18688 bytes wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 09:14:56 47104 bytes msdv.sys: 4.10.2326.0900 English Final Retail 2/17/2003 09:14:42 56832 bytes ------------------------------------ Inactive Display Entries in Registry ------------------------------------ Card name: ABIT R9600XT - Secondary Driver: ATI2DRAG.DRV ---------------------------------- Inactive Sound Entries in Registry ---------------------------------- Card name: VIA AC'97 Enhanced Audio Controller (WDM) Driver: wdmaud.drv ------------------ DirectShow Filters ------------------ WDM Streaming VBI Codecs: CC Decoder,0x00200000,2,1,,4.90.3010.0900 NABTS/FEC VBI Codec,0x00200000,2,1,,4.90.3010.0900 WaveTop (TM) NABTS/CC VBI Codec,0x00200000,1,1,,4.90.3010.0900 CC Decoder,0x00200000,2,1,,4.90.3010.0900 NABTS/FEC VBI Codec,0x00200000,2,1,,4.90.3010.0900 WST Codec,0x00200000,1,1,,4.90.3010.0900 WDM Streaming Capture Devices: VIA AC'97 Audio (WAVE),0x00200000,2,2,,4.90.3010.0900 WDM Streaming Communication Transforms: Tee/Sink-to-Sink Converter,0x00200000,1,1,,4.90.3010.0900 WDM Streaming Data Transforms: Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,4.90.3010.0900 Microsoft DirectMusic SW Synth (WDM),0x00200000,1,1,,4.90.3010.0900 WDM Streaming Mixer Devices: Microsoft Kernel Audio Mixer,0x00200000,2,2,,4.90.3010.0900 WDM Streaming Rendering Devices: VIA AC'97 Audio (WAVE),0x00200000,2,2,,4.90.3010.0900 WDM Streaming Tee/Splitter Devices: Tee/Sink-to-Sink Converter,0x00200000,1,1,,4.90.3010.0900 DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,, WMSpeech Decoder DMO,0x00600800,1,1,, WMV Screen decoder DMO,0x00800001,1,1,, Mpeg4s Decoder DMO,0x00800001,1,1,, Mpeg43 Decoder DMO,0x00800001,1,1,, WMVideo Decoder DMO,0x00800001,1,1,, Mpeg4 Decoder DMO,0x00800001,1,1,, Indeo® video 5.04 Decompression Filter,0x00640000,1,1,IR50_32.DLL,5.1026.0015.0041 Indeo® video 5.04 Compression Filter,0x00200000,1,1,IR50_32.DLL,5.1026.0015.0041 Indeo(R) audio software,0x00500000,1,1,IAC25_32.AX,2.00.0005.0050 Indeo(R) audio software,0x00500000,1,1,IAC25_32.AX,2.00.0005.0050 IVF source filter,0x00600000,0,1,IVFSRC.AX,5.03.0002.0038 Cutlist File Source,0x00200000,0,1,QCUT.DLL,6.01.0005.0217 ClearVideo® Decompression Filter,0x00800000,1,1,CLRAMD.AX,2.00.0000.0001 TrueMotion 2.0 Decompressor,0x00600001,1,1,TM20DEC.AX,2.00.0006.0003 VIVO Audio Decoder Filter,0x00800002,1,1,VVAUDFLT.AX,3.00.0000.0001 VIVO Video Decoder Filter,0x00600001,1,1,VVVIDFLT.AX,3.00.0000.0000 Internal LMRT Renderer,0x00800001,1,0,LMRTREND.DLL,6.01.0005.0124 URL StreamRenderer,0x00600000,1,0,LMRTREND.DLL,6.01.0005.0124 Lyric Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902 Auxiliary Pin Holder,0x00200000,0,0,AUXPIN.AX,1.00.0000.0000 AVI Mux,0x00200000,1,0,QCAP.DLL,6.05.0001.0900 File writer,0x00200000,1,0,QCAP.DLL,6.05.0001.0900 Infinite Pin Tee Filter,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Smart Tee,0x00200000,1,2,QCAP.DLL,6.05.0001.0900 DV Video Decoder,0x00800000,1,1,QDV.DLL,6.05.0001.0900 DV Muxer,0x00400000,0,0,QDV.DLL,6.05.0001.0900 DV Splitter,0x00600000,1,2,QDV.DLL,6.05.0001.0900 SampleGrabber,0x00200000,1,1,QEDIT.DLL,6.05.0001.0900 Null Renderer,0x00200000,1,0,QEDIT.DLL,6.05.0001.0900 BDA MPEG2 Transport Information Filter,0x00200000,1,0,PSISRNDR.AX,6.05.0001.0900 VBI Surface Allocator,0x00600000,1,1,VBISURF.AX,5.03.0000.0900 MPEG-2 Sections and Tables,0x005fffff,1,0,MPEG2DATA.AX,6.05.0001.0900 WST Decoder,0x00600000,1,1,WSTDECOD.DLL,5.03.0000.0900 CyberLink Audio Decoder,0x00601000,1,1,CLAUD.AX,5.00.0000.0924 CyberLink Audio Effect,0x00200000,1,1,CLAUDFX.AX,5.00.0000.0901 CyberLink TimeStretch Filter,0x00200000,1,1,CLAUTS.AX,1.00.0000.0704 CyberLink AudioCD Filter,0x00600000,0,1,CLAUDIOCD.AX,5.00.0000.0905 CyberLink DVD Navigator,0x00600000,0,3,CLNAVX.AX,5.00.0000.0905 CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.AX,5.00.0000.0912 CyberLink Line21 Decoder Filter,0x00200000,0,2,CLLINE21.AX,4.00.0000.3030 AVI/WAV File Source,0x00400000,0,2,QUARTZ.DLL,6.05.0001.0902 AVI Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902 AVI Draw,0x00600064,9,1,QUARTZ.DLL,6.05.0001.0902 Color Space Converter,0x00400001,1,1,QUARTZ.DLL,6.05.0001.0902 VGA 16 Color Ditherer,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902 Full Screen Renderer,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902 Video Renderer,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902 Video Mixing Renderer 9,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902 MPEG Audio Decoder,0x03680001,1,1,QUARTZ.DLL,6.05.0001.0902 MPEG Video Decoder,0x40000001,1,1,QUARTZ.DLL,6.05.0001.0902 MPEG-I Stream Splitter,0x00600000,1,2,QUARTZ.DLL,6.05.0001.0902 File Source (Async.),0x00400000,0,1,QUARTZ.DLL,6.05.0001.0902 QuickTime Movie Parser,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902 QT Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902 AVI Splitter,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902 Wave Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902 ACM Wrapper,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902 MIDI Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902 SAMI (CC) Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902 Internal Script Command Renderer,0x00800001,1,0,QUARTZ.DLL,6.05.0001.0902 Multi-file Parser,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902 File stream renderer,0x00400000,1,1,QUARTZ.DLL,6.05.0001.0902 File Source (URL),0x00400000,0,1,QUARTZ.DLL,6.05.0001.0902 MJPEG Decompressor,0x00600000,1,1,QUARTZ.DLL,6.05.0001.0902 Line 21 Decoder 2,0x00600002,1,1,QUARTZ.DLL,6.05.0001.0902 MPEG-2 Demultiplexer,0x00600000,1,1,MPG2SPLT.AX,6.05.0001.0900 MPEG-2 Splitter,0x005fffff,1,0,MPG2SPLT.AX,6.05.0001.0900 AC3 Parser Filter,0x00600000,1,1,MPG2SPLT.AX,6.05.0001.0900 Windows Media source filter,0x00600000,0,2,WMPASF.DLL,9.00.0000.2980 ASF DIB Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 ASF ACM Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 ASF ICM Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 ASF URL Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 ASF JPEG Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 ASF DJPEG Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 ASF embedded stuff Handler,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 ASX file Parser,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 ASX v.2 file Parser,0x00600000,1,0,WMPASF.DLL,9.00.0000.2980 XML Playlist,0x00400000,1,0,WMPASF.DLL,9.00.0000.2980 .RAM file Parser,0x00600000,1,0,WMPASF.DLL,9.00.0000.2980 NSC file Parser,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 Windows Media Multiplexer,0x00600000,1,1,WMPASF.DLL,9.00.0000.2980 File Source (Netshow URL),0x00400000,0,1,WMPASF.DLL,9.00.0000.2980 Windows Media Update Filter,0x00400000,1,0,WMPASF.DLL,9.00.0000.2980 MPEG Layer-3 Decoder,0x00810000,1,1,L3CODECX.AX,1.05.0000.0050 Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,MPG4DS32.AX,4.01.0000.3854 Windows Media Audio Decoder,0x00800001,1,1,MSADDS32.AX,4.01.0000.3854 ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,ACELPDEC.AX,1.04.0000.0000 Overlay Mixer,0x00200000,0,0,QDVD.DLL,6.05.0001.0902 Overlay Mixer2,0x00400000,1,1,QDVD.DLL,6.05.0001.0902 Line 21 Decoder,0x00600000,1,1,QDVD.DLL,6.05.0001.0902 DVD Navigator,0x00200000,0,2,QDVD.DLL,6.05.0001.0902 WM ASF Reader,0x00400000,0,0,QASF.DLL,9.00.0000.2980 WM ASF Writer,0x00400000,0,0,QASF.DLL,9.00.0000.2980 Indeo® video 4.3 Decompression Filter,0x00640000,1,1,IR41_32.AX,4.31.0016.0002 Indeo® video 4.3 Compression Filter,0x00200000,1,1,IR41_32.AX,4.31.0016.0002 Voxware MetaSound Audio Decoder,0x00999999,1,1,VOXMSDEC.AX,1.00.0000.0011 Voxware MetaVoice Audio Decoder,0x00999998,1,1,VOXMVDEC.AX,1.00.0000.0011 Video Compressors: MSScreen 9 encoder DMO,0x00600800,1,1,, WMVideo9 Encoder DMO,0x00600800,1,1,, DV Video Encoder,0x00200000,0,0,QDV.DLL,6.05.0001.0900 Indeo® video 5.04 Compression Filter,0x00100000,1,1,IR50_32.DLL,5.1026.0015.0041 MJPEG Compressor,0x00200000,0,0,QUARTZ.DLL,6.05.0001.0902 VDOnet VDOWave,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Cinepak Codec by Radius,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Intel Indeo(R) Video R3.2,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Microsoft Video 1,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Microsoft RLE,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Microsoft H.263 Video Codec,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Microsoft H.261 Video Codec,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Indeo® video 5.04,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,QCAP.DLL,6.05.0001.0900 Audio Capture Sources: VIA AC'97 Audio (WAVE),0x00200000,0,0,QCAP.DLL,6.05.0001.0900 Audio Compressors: WMAudio Encoder DMO,0x00600800,1,1,, WM Speech Encoder DMO,0x00600800,1,1,, Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 PCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 IMA ADPCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Microsoft ADPCM,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 GSM 6.10,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 CCITT A-Law,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 CCITT u-Law,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 DSP Group TrueSpeech(TM),0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Microsoft G.723.1,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 IAC2,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 MPEG Layer-3,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 ACELP.net,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Voxware MetaSound,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Voxware MetaVoice,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Voxware v1.1.6/1.1.8 File-Mode Codecs,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Voxware v1.1.8 Bitstream-Mode Codecs,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Mobile Voice,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Windows Media Audio V1,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Windows Media Audio V2,0x00200000,1,1,QUARTZ.DLL,6.05.0001.0902 Audio Renderers: VIA AC'97 Audio (WAVE),0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902 CyberLink Audio Renderer,0x00200000,1,0,CLADR.AX,5.00.0000.0807 Default WaveOut Device,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902 DirectSound: VIA AC'97 Audio (WAVE),0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902 Default DirectSound Device,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902 Midi Renderers: Microsoft GS Wavetable SW Synth,0x00200000,1,0,QUARTZ.DLL,6.05.0001.0902 Default MidiOut Device,0x00800000,1,0,QUARTZ.DLL,6.05.0001.0902 BDA Receiver Component: BDA MPE Filter,0x00600000,1,1,,4.90.3010.0900 BDA Slip De-Framer,0x00600000,1,1,,4.90.3010.0900 BDA Rendering Filters: BDA IP Sink,0x00200000,1,1,,4.90.3010.0900 WDM Streaming System Devices: VIA AC'97 Audio (WAVE),0x00000000,0,0,, BDA Network Providers: Microsoft ATSC Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900 Microsoft DVBS Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900 Microsoft DVBT Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900 Microsoft DVBC Network Provider,0x00200000,0,1,MSDVBNP.AX,6.05.0001.0900 BDA Transport Information Renderers: BDA MPEG2 Transport Information Filter,0x00600000,1,0,PSISRNDR.AX,6.05.0001.0900 MPEG-2 Sections and Tables,0x00600000,1,0,MPEG2DATA.AX,6.05.0001.0900 ... |
| 28.11.2004, 21:49:29 |
Не на максимальных настройках. P.S. Девайс - это устройство, плата расширения. ... |
| 28.11.2004, 23:08:23 |
Ja izvinjajusj, ne dumal, shto stoljko texta vijdet Ja znaju tochno, shto doom 3 i na 128 Mb operativki pojdjot, prichjom tochno! A voobshe ja naradovatjsa ne mogu %) Ja voobshe iz nebogatoj semji, i preobretenije takogo kompa - eto sobitie :) Sejchas podsoedinil k kompiku Pocket PC, postavil kameru (Sony Handicam), podsoedinil k Sony Centru, a rjadom postavil telek Sony :) Vobshem sizhu tut kak Morfius i naradovatjsa ne mogu :)) Dazhe mishka opticheskaja, aga A kogda ja uvidel, shto moj sistemnij block szadi sinim cvetom svetitsa - detskomu vostorgu ne bilo predela Vi predstavte - ja sidel na Pentium MMX 200Mhz, Video 8 Mb, RAM 140. ) A sejchas vsjo prjamo tak letaet Igri kachaju sejchas, ih u menja voobshe netu. Nu blin, takije igri zanimajut tak mnogo...po 3 Gb.... V eMule kachaju, tak shto posochuvstvujte v etom plane mne :) Chuvstvuju, shto Max Payne 1 pervim zakachaetsa :) Kuljnaja igra? ^)) Eh..... Rebjat, mne interesno, vot vi ljudi ponimajushie.....chem ploh proc Sempron? Chem ploha moja video karta? ... |
| 29.11.2004, 00:14:45 |
Mulat, на times нафлудил теперь здесь флудишь? ... |
| 29.11.2004, 11:34:35 |
Раз купил - значит ставь Дума и пробуй. Захочешь - поиграешь, не понравится - значит не поиграешь. ... |
| 29.11.2004, 11:50:44 |
Оперативки маловато будет постоянный свопинг. Даже на среднем качестве. ... |
| 29.11.2004, 18:08:22 |
2 Mulat Даже в Bugs Report столько инфы не кидают :). ... |
| 29.11.2004, 18:09:35 |
Лучше поставь Win XP Pro Sp1. ... |
| 29.11.2004, 18:10:32 |
Н-да, не читал весь пост ;) но: >>AMD Sempron(tm) , MMX, 3DNow, ~1.7GHz вроде нормально >>Оperating System: Windows 98 (4.10, Build 2222) A Под это Дум 3 кажется не пашет, хочет 2000 или XP, >>Memory: 256MB RAM а этого желательно 512MB. >>RADEON 9600 XT AGP Pro ну а это для Дум-а самое важное, посмотри по интернету, подходит или нет. ... |
| 01.12.2004, 16:47:41 |
start [/forum/topic.php?desktop=1&fid=26&tid=1514382]: |
44ms |
55ms |
| others: | 232ms |
| total: | 383ms |
