Виснет принт-сервер DP-301U на HP 1300
Виснет принт-сервер DP-301U , к нему пресоеденен принтер модели HP 1300. В чем дело? Пинг к нему : Pinging 10.0.0.29 with 1200 bytes of data: Reply from 10.0.0.29: bytes=1200 time=11ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=7ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Reply from 10.0.0.29: bytes=1200 time=8ms TTL=255 Ping statistics for 10.0.0.29: Packets: Sent = 28, Received = 28, Lost = 0 (0% los Approximate round trip times in milli-seconds: Minimum = 7ms, Maximum = 11ms, Average = 7ms больше 1200 байта он не берет, когда не печатает(завесает) пинг к принт-серверу показывает Reply from 10.0.0.29: bytes=32 time=27ms TTL=255 Reply from 10.0.0.29: bytes=32 time=2ms TTL=255 Reply from 10.0.0.29: bytes=32 time=3ms TTL=255 Reply from 10.0.0.29: bytes=32 time=8ms TTL=255 Reply from 10.0.0.29: bytes=32 time=2ms TTL=255 Reply from 10.0.0.29: bytes=32 time=307ms TTL=255 Reply from 10.0.0.29: bytes=32 time=3ms TTL=255 Reply from 10.0.0.29: bytes=32 time=55ms TTL=255 Reply from 10.0.0.29: bytes=32 time=2ms TTL=255 Reply from 10.0.0.29: bytes=32 time=2ms TTL=255 Reply from 10.0.0.29: bytes=32 time=3ms TTL=255 Reply from 10.0.0.29: bytes=32 time=2ms TTL=255 Reply from 10.0.0.29: bytes=32 time=2ms TTL=255 Reply from 10.0.0.29: bytes=32 time=201ms TTL=255 Reply from 10.0.0.29: bytes=32 time=358ms TTL=255 Reply from 10.0.0.29: bytes=32 time=2ms TTL=255 Reply from 10.0.0.29: bytes=32 time=377ms TTL=255 Reply from 10.0.0.29: bytes=32 time=2ms TTL=255 В чем причина? ... |
| 10.01.2006, 16:40:21 |
start [/forum/topic.php?desktop=1&fid=26&tid=1511394]: |
29ms |
34ms |
| others: | 199ms |
| total: | 286ms |
