Процессы в Task Manager
Вот тут шерстил у себя на компе Процессы в Task Manager. Учился. Для себя составил табличку что чего означает и что с этим делать. Хотя это всё в инете есть, но может кому пригодится. Пользуйтесь. Действие Файл Описание alg.exe Application Layer Gateway service is a component of of Windows OS. It is required if you use a 3rd party firewall or Internet Connection Sharing (ICS) to connect to the internet. Do not end this program in task manager - you will lose all internet connectivity until next restart or login. agrsmmsg.exe is a process installed alongside SoftModem Assistant and provides additional configuration options for these devices. This program is non-essential process to the running of the system. but should not be terminated unless suspected to be causing problems.To be killed ccevtmgr.exe is a part of the Norton Internet Security Suite. This process acts as a logger for the AntiVirus and firewall application installed. This program is important for the stable and secure running of your computer and should not be terminated. csrss.exe is the main executable for the Microsoft Client/Server Runtime Server Subsystem. This process manages most graphical commands in Windows. This program is important for the stable and secure running of your computer and should not be terminated. ctfmon.exe monitors the active windows and provides text input service support for speech recognition handwriting recognition keyboard translation and other alternative user input technologies. dit.exe is an application which assigns icons and names to flash memory cards. This program is a non-essential system process but should not be terminated unless suspected to be causing problems.To be stopped fxssvc.exe is a program belonging to the Microsoft Fax application which deals primarily with the faxing function. This program is non-essential process to the running of the system but should not be terminated unless suspected to be causing problems.To be killed jucheck.exe Sun Java UpdateChecker ModuleTo be stopped juched.exe This is Sun's Java automatic update utility. If you would like to disable this scheduler then go to your control panel and click on the java module. The go to the updates tab and uncheck "check for updates automatically" lsass.exe It generates the process responsible for authenticating users for the Winlogon service. This process is performed by using authentication packages such as the default Msgina.dll. If authentication is successful Lsass generates the user's access token which is used to launch the initial shell. Other processes that the user initiates inherit this token.To be killed msiexec.exe belongs to the Windows Installer Component and is used to install new programs that use Windows Installer package files (MSI). This program is important for the stable and secure running of your computer and should not be terminated.To be killed nopdb.exe belongs to Norton Speed Disk. It is used to schedule when the Speed Disk application should run. This program is should not be terminated unless suspected to be causing problems. nvsvc32.exe is a process that belongs to the NVIDIA graphics card drivers. This process should not be removed to ensure that your graphics card drivers is working properly. services.exe This is the Services Control Manager which is responsible for running ending and interacting with system services. smss.exe This is the session manager subsystem which is responsible for starting the user session. This process is initiated by the system thread and is responsible for various activities including launching the Winlogon and Win32 (Csrss.exe) processes and setting system variables. After it has launched these processes it waits for either Winlogon or Csrss to end. If this happens "normally" the system shuts down; if it happens unexpectedly Smss.exe causes the system to stop responding (hang). spoolsv.exe is a Microsoft Windows system executable which handles the printing process to your local printers. This program is important for the stable and secure running of your computer and should not be terminated. Svchost.exe "(Generic Host Process for Win32 Services) is an integral part of Windows OS. It cannot be stopped or restarted manually. It manages 32-bit DLLs and other services. At startup Svchost.exe checks the services portion of the registry to construct a list of services that it needs to load. In normal conditions multiple instances of Svchost.exe run at the same time. Each Svchost.exe session can contain a grouping of services so that separate services can be run depending on how and where Svchost.exe is started."To be killed symwsc.exe is a process belonging to the Symantec Security Center. This program is important for the stable and secure running of your computer and should not be terminated. winlogon.exe The process "winlogon.exe" runs in the background. It's a part of the Windows Login subsystem. Winlogon is necessary for user authorization and checks the Windows XP activation code. Использованы материалы со следующих сайтов: http://www.liutilities.com/products/wintaskspro/processlibrary http://www.neuber.com/taskmanager/process http://process.networktechs.com ... |
| 27.01.2006, 06:08 |
На компьютере стоят Norton и Java. Все сервисы для удаления от них. Проще их удалить. сервиса mdm я почему-то не увидел. сервиса reset5 тоже нету -- Posted via ActualForum NNTP Server 1.3 ... |
| 27.01.2006, 06:46 |
Green2 На компьютере стоят Norton и Java. Все сервисы для удаления от них. Проще их удалить. сервиса mdm я почему-то не увидел. сервиса reset5 тоже нету -- А они действительно нужны? Может я их давно-давно уже грохнул. Пока работаю счастливо без них. ... |
| 30.01.2006, 02:08 |
start [/forum/topic.php?desktop=1&fid=26&tid=1511252]: |
57ms |
52ms |
| others: | 224ms |
| total: | 387ms |
