MS ISA SERVER ЧЕМ и КАК ПРОЧЕСТЬ(ИЗМЕНИТЬ) ЛОГИ
Версия MS ISA Server 2004 © Бомж Inc. ... |
| 12.06.2006, 08:25 |
RTFM Posted via ActualForum NNTP Server 1.3 ... |
| 12.06.2006, 11:19 |
YanisRTFM Posted via ActualForum NNTP Server 1.3 Kakuyu .. ssilku xot podkin ... |
| 12.06.2006, 11:59 |
ISA2004Root\Computer\Monitoring Выбирайешь закладку logging Правее еще закладки Tasks, Help. Тебе нужна вторая Logging ISA Server creates logs of activity on the ISA Server computer. These logs are used to generate reports, and to troubleshoot network issues. You can configure what information should be saved to the logs in various formats: file, SQL, or Microsoft Data Engine (MSDE). The log view can display the Firewall log, Web Proxy log, or both. You can view online logs, which are currently being saved to the log repository, or you can run a query against the repository to see past logs. In both modes, you can define filters to limit the amount of data displayed. How To... You can perform the following task: Filter the display: On the Tasks tab, click Edit Filter Properties. Related Topics For more information, see these topics in ISA Server Help: Reports Logs ISA Server Online Posted via ActualForum NNTP Server 1.3 ... |
| 12.06.2006, 13:05 |
start [/forum/topic.php?desktop=1&fid=26&tid=1510243]: |
159ms |
30ms |
| others: | 232ms |
| total: | 463ms |
