Программно вкл/выкл Local Security Settings
Подскажите плз, как в XP программно (*.bat или *.vbs) включить/выключить какую-либо локальную политику безопасности IP? (Настройка-Панель управления-Администрирование-Локальная политика безопасности-Политика безопасности IP на локальном компьютере-....) Заранее спасибо ... |
| 04.04.2007, 09:34:07 |
Наверное, тут: cmd.exeC:\>netsh ipsec The following commands are available: Commands in this context: ? - Displays a list of commands. dump - Displays a configuration script. dynamic - Changes to the `netsh ipsec dynamic' context. help - Displays a list of commands. static - Changes to the `netsh ipsec static' context. The following sub-contexts are available: dynamic static To view help for a command, type the command, followed by a space, and then type ?. cmd.exeC:\>netsh netsh>ipsec netsh ipsec>help The following commands are available: Commands inherited from the netsh context: .. - Goes up one context level. aaaa - Changes to the `netsh aaaa' context. abort - Discards changes made while in offline mode. add - Adds a configuration entry to a list of entries. alias - Adds an alias. bridge - Changes to the `netsh bridge' context. bye - Exits the program. commit - Commits changes made while in offline mode. delete - Deletes a configuration entry from a list of entries. dhcp - Changes to the `netsh dhcp' context. diag - Changes to the `netsh diag' context. exit - Exits the program. firewall - Changes to the `netsh firewall' context. interface - Changes to the `netsh interface' context. ipsec - Changes to the `netsh ipsec' context. offline - Sets the current mode to offline. online - Sets the current mode to online. popd - Pops a context from the stack. pushd - Pushes current context on stack. quit - Exits the program. ras - Changes to the `netsh ras' context. routing - Changes to the `netsh routing' context. rpc - Changes to the `netsh rpc' context. set - Updates configuration settings. show - Displays information. unalias - Deletes an alias. wins - Changes to the `netsh wins' context. winsock - Changes to the `netsh winsock' context. Commands in this context: ? - Displays a list of commands. dump - Displays a configuration script. dynamic - Changes to the `netsh ipsec dynamic' context. help - Displays a list of commands. static - Changes to the `netsh ipsec static' context. The following sub-contexts are available: dynamic static To view help for a command, type the command, followed by a space, and then type ?. netsh ipsec> ... |
| 04.04.2007, 10:45:31 |
start [/forum/search_topic.php?author=kotofeich2&author_mode=last_posts&do_search=1]: |
45ms |
45ms |
| others: | 673ms |
| total: | 827ms |
