Управление терминальными сессиями через командную строку (telnet)
Хочу замутить такую весч, а как, не знаю. Может, кто-нить сталкивался? ... |
| 20.07.2007, 17:44:44 |
Managing Terminal Services from the command lineYou can manage users, sessions, processes, and terminal servers by using command-line utilities. The following table lists the Terminal Services administrative utilities that you can invoke from the command line. Command Function change logon Disables, temporarily, logons to a terminal server. change port Changes COM port mappings for MS-DOS program compatibility. change user Changes the .ini file mapping for the current user. cprofile Removes user-specific file associations from a user profile. flattemp Enables or disables flat temporary directories. logoff Logs off a user from a session and deletes the session from the server. msg Sends a message to a user or group of users. mstsc Displays the Remote Desktop Connection to establish a connection with a Terminal Server. query process Displays information about processes running on a terminal server. query session Displays information about sessions on a terminal server. query termserver Displays a list of all terminal servers on the network. query user Displays information about user sessions on a terminal server. register Registers applications to execute in a global context on the system. reset session Resets a session to known initial values. shadow Monitors another user's session. tscon Connects to another existing terminal server session. tsdiscon Disconnects a client from a terminal server session. tskill Ends a process. tsprof Copies user configuration and changes profile path. tsshutdn Shuts down a terminal server. ... |
| 20.07.2007, 18:01:11 |
Спасибо, очень кстати. Не догадался искать по-английски. А где почитать про то, под какой учеткой должна запускаться служба telnet? По умолчанию почему-то запускается под "NT_AUTHORITY\LocalService". Но в таком случае при попытке, например, сделать в телнете tasklist на другую машину, говорит, что RPC недоступен, хотя при других способах входа в систему он доступен. Если я запущу телнет под админской учеткой, что будет? ... |
| 23.07.2007, 12:32:50 |
start [/forum/topic.php?desktop=1&fid=26&tid=1506867]: |
31ms |
31ms |
| others: | 205ms |
| total: | 299ms |
