DNS server
Все нормально работает, но в Евентах такая запись появляется. Что не так? The DNS server was unable to complete directory service enumeration of zone EHC.KZ. This DNS server is configured to use information obtained from Active Directory for this zone and is unable to load the zone without it. Check that the Active Directory is functioning properly and repeat enumeration of the zone. The extended error debug information (which may be empty) is "". The event data contains the error. Зона автоматом создавалась. ... |
| 12.10.2007, 20:39:24 |
DNS server
dcdiag и netdiag на контроллере ... |
| 12.10.2007, 20:50:19 |
DNS server
D:\>dcdiag Domain Controller Diagnosis Performing initial setup: Done gathering initial info. Doing initial required tests Testing server: Default-First-Site-Name\MAIN Starting test: Connectivity ......................... MAIN passed test Connectivity Doing primary tests Testing server: Default-First-Site-Name\MAIN Starting test: Replications ......................... MAIN passed test Replications Starting test: NCSecDesc ......................... MAIN passed test NCSecDesc Starting test: NetLogons ......................... MAIN passed test NetLogons Starting test: Advertising ......................... MAIN passed test Advertising Starting test: KnowsOfRoleHolders ......................... MAIN passed test KnowsOfRoleHolder Starting test: RidManager ......................... MAIN passed test RidManager Starting test: MachineAccount ......................... MAIN passed test MachineAccount Starting test: Services ......................... MAIN passed test Services Starting test: ObjectsReplicated ......................... MAIN passed test ObjectsReplicated Starting test: frssysvol ......................... MAIN passed test frssysvol Starting test: frsevent ......................... MAIN passed test frsevent Starting test: kccevent ......................... MAIN passed test kccevent Starting test: systemlog An Error Event occured. EventID: 0x00000457 Time Generated: 10/12/2007 22:09:33 (Event String could not be retrieved) An Error Event occured. EventID: 0x00000457 Time Generated: 10/12/2007 22:09:34 (Event String could not be retrieved) An Error Event occured. EventID: 0x00000457 Time Generated: 10/12/2007 22:09:34 (Event String could not be retrieved) An Error Event occured. EventID: 0x00000457 Time Generated: 10/12/2007 22:21:58 (Event String could not be retrieved) An Error Event occured. EventID: 0x00000457 Time Generated: 10/12/2007 22:21:59 (Event String could not be retrieved) An Error Event occured. EventID: 0x00000457 Time Generated: 10/12/2007 22:21:59 (Event String could not be retrieved) ......................... MAIN failed test systemlog Starting test: VerifyReferences ......................... MAIN passed test VerifyReferences Running partition tests on : ForestDnsZones Starting test: CrossRefValidation ......................... ForestDnsZones passed test CrossRe Starting test: CheckSDRefDom ......................... ForestDnsZones passed test CheckSD Running partition tests on : DomainDnsZones Starting test: CrossRefValidation ......................... DomainDnsZones passed test CrossRe Starting test: CheckSDRefDom ......................... DomainDnsZones passed test CheckSD Running partition tests on : Schema Starting test: CrossRefValidation ......................... Schema passed test CrossRefValidat Starting test: CheckSDRefDom ......................... Schema passed test CheckSDRefDom Running partition tests on : Configuration Starting test: CrossRefValidation ......................... Configuration passed test CrossRef Starting test: CheckSDRefDom ......................... Configuration passed test CheckSDR Running partition tests on : EHC Starting test: CrossRefValidation ......................... EHC passed test CrossRefValidation Starting test: CheckSDRefDom ......................... EHC passed test CheckSDRefDom Running enterprise tests on : EHC.KZ Starting test: Intersite ......................... EHC.KZ passed test Intersite Starting test: FsmoCheck ......................... EHC.KZ passed test FsmoCheck D:\>netdiag ................................ Computer Name: MAIN DNS Host Name: main.EHC.KZ System info : Microsoft Windows Server 2003 R2 (Build 3790) Processor : EM64T Family 6 Model 15 Stepping 6, GenuineIntel List of installed hotfixes : KB921503 KB924667-v2 KB925398_WMP64 KB925902 KB926122 KB926139 KB927891 KB929123 KB930178 KB932168 KB932596 KB933360 KB935839 KB935840 KB935966 KB936021 KB936357 KB936782 KB937143 KB937143-IE7 KB938127 KB938127-IE7 Q147222 Netcard queries test . . . . . . . : Passed Per interface results: Adapter : Local Area Connection 2 Netcard queries test . . . : Passed Host Name. . . . . . . . . : main IP Address . . . . . . . . : 192.168.100.2 Subnet Mask. . . . . . . . : 255.255.255.0 Default Gateway. . . . . . : 192.168.100.1 NetBIOS over Tcpip . . . . : Disabled Dns Servers. . . . . . . . : 192.168.100.2 82.200.130.10 AutoConfiguration results. . . . . . : Passed Default gateway test . . . : Passed WINS service test. . . . . : Skipped NetBT is disable on this interface. [Test skipped]. Global results: Domain membership test . . . . . . : Passed NetBT transports test. . . . . . . : Skipped There are no interfaces that have NetBT enabled. [Test skipped] Autonet address test . . . . . . . : Passed IP loopback ping test. . . . . . . : Passed Default gateway test . . . . . . . : Passed NetBT name test. . . . . . . . . . : Skipped There are no interfaces that have NetBT enabled. [Test skipped] Winsock test . . . . . . . . . . . : Passed DNS test . . . . . . . . . . . . . : Passed PASS - All the DNS entries for DC are registered on DNS server '192.168.10 2'. [WARNING] The DNS entries for this DC are not registered correctly on DNS rver '82.200.130.10'. Please wait for 30 minutes for DNS server replication. Redir and Browser test . . . . . . : Skipped There are no interfaces that have NetBT enabled. [Test skipped] DC discovery test. . . . . . . . . : Passed DC list test . . . . . . . . . . . : Passed Trust relationship test. . . . . . : Skipped Kerberos test. . . . . . . . . . . : Passed LDAP test. . . . . . . . . . . . . : Passed Bindings test. . . . . . . . . . . : Passed WAN configuration test . . . . . . : Skipped No active remote access connections. Modem diagnostics test . . . . . . : Passed IP Security test . . . . . . . . . : Skipped Note: run "netsh ipsec dynamic show /?" for more detailed information The command completed successfully D:\> ... |
| 12.10.2007, 21:19:47 |
start [/forum/topic.php?desktop=1&fid=26&tid=1506183]: |
81ms |
35ms |
| others: | 198ms |
| total: | 352ms |
