Ошибка 1053
Здравствуйте, подскажите пожалуйста, что нужно сделать, если выходит данная ошибка: Event Type: Error Event Source: Userenv Event Category: None Event ID: 1053 Date: 20.07.2010 Time: 8:44:00 User: NT AUTHORITY\SYSTEM Computer: ..... Description: Windows cannot determine the user or computer name. (The system detected a possible attempt to compromise security. Please ensure that you can contact the server that authenticated you. ). Group Policy processing aborted. For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp. ... |
| 20.07.2010, 14:50 |
Ошибка 1053
make123, Event ID 1053 - Userenv Symptoms: your w2k/xp clients may receive this Event ID 1053 - Windows cannot determine the user or computer name. (<error description>). Group Policy processing aborted. Or error: "The specified user does not exist." Resolutions: 1. Make sure that your internal DNS server is the server for the domain you are logging in to. 2. Verify the DNS Settings. This will occur if your DNS server is unable to resolve information about your domain. 3. Delete the problem computer from DNS records and re-create it. ... |
| 20.07.2010, 16:58 |
start [/forum/topic.php?desktop=1&fid=26&tid=1499551]: |
30ms |
| others: | 188ms |
| total: | 262ms |
