Net frame work 3.5
А есть у кого-нибудь последняя версия, скаченная или где можно скачать без авторизации на сайте микрософт ? ... |
| 26.07.2010, 17:04 |
Net frame work 3.5
КоргА есть у кого-нибудь последняя версия, скаченная или где можно скачать без авторизации на сайте микрософт ? В визуал студиях вообще сама ставится, там где-то в недрах можно найти ... |
| 26.07.2010, 19:54 |
Net frame work 3.5
у мну в студии на сайт лезет :( ... |
| 26.07.2010, 21:01 |
Net frame work 3.5
не, все таки соединение не причем, на середине установки (вер. 3.5) выдает ошибку. ... |
| 26.07.2010, 21:12 |
Net frame work 3.5
Типа лог: [06/21/10,23:39:39] setup.exe: [2] CSetupManager::RunInstallPhaseAndCheckResults() - RunInstallPhase() returned a NULL piActionResults [06/21/10,23:39:39] setup.exe: [2] CSetupManager::RunInstallFromList() - RunInstallPhaseAndCheckResults failed [2] [06/21/10,23:39:40] setup.exe: [2] ISetupManager::RunInstallLists(IP_PREINSTALL failed in ISetupManager::RunInstallFromThread() [06/21/10,23:39:40] setup.exe: [2] ISetupManager::RunInstallFromThread() failed in ISetupManager::RunInstall() [06/21/10,23:39:40] setup.exe: [2] CSetupManager::Run() - Call to RunInstall() failed [06/21/10,23:39:40] WapUI: [2] DepCheck indicates WIC Installer is not installed. [06/21/10,23:39:41] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0a was not attempted to be installed. [06/21/10,23:39:41] WapUI: [2] DepCheck indicates XPSEPSC Installer was not attempted to be installed. [06/21/10,23:39:41] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a was not attempted to be installed. [06/21/10,23:39:41] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5 'package' was not attempted to be installed. [06/21/10,23:39:41] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5LP - RUS was not attempted to be installed. [06/21/10,23:49:09] Microsoft .NET Framework 2.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [06/21/10,23:49:10] Microsoft .NET Framework 2.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [06/21/10,23:49:11] Microsoft .NET Framework 2.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [06/21/10,23:49:12] Microsoft .NET Framework 2.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [06/21/10,23:49:13] Microsoft .NET Framework 2.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [06/21/10,23:49:14] Microsoft .NET Framework 2.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [06/21/10,23:49:14] Microsoft .NET Framework 2.0a: [2] dlmgr: dlmgr::JobBase::Retry: all retries failed [06/21/10,23:49:14] Microsoft .NET Framework 2.0a: [2] Failed to fetch setup file in CBaseComponent::PreInstall() [06/21/10,23:49:14] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InternalInstallManager() with HRESULT -2147467260. [06/21/10,23:49:14] setup.exe: [2] CSetupManager::RunInstallPhase() - Call to Pre/Install/Post for InstallComponents failed [06/21/10,23:49:15] setup.exe: [2] CSetupManager::RunInstallPhaseAndCheckResults() - RunInstallPhase() returned a NULL piActionResults [06/21/10,23:49:15] setup.exe: [2] CSetupManager::RunInstallFromList() - RunInstallPhaseAndCheckResults failed [2] [06/21/10,23:49:15] setup.exe: [2] ISetupManager::RunInstallLists(IP_PREINSTALL failed in ISetupManager::RunInstallFromThread() [06/21/10,23:49:15] setup.exe: [2] ISetupManager::RunInstallFromThread() failed in ISetupManager::RunInstall() [06/21/10,23:49:15] setup.exe: [2] CSetupManager::Run() - Call to RunInstall() failed [06/21/10,23:49:15] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0a is not installed. [06/21/10,23:49:16] WapUI: [2] DepCheck indicates XPSEPSC Installer was not attempted to be installed. [06/21/10,23:49:16] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a was not attempted to be installed. [06/21/10,23:49:16] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5 'package' was not attempted to be installed. [06/21/10,23:49:16] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5LP - RUS was not attempted to be installed. [06/22/10,18:36:10] RGB Rast: [2] Error: Installation failed for component RGB Rast. MSI returned error code 1601 [06/22/10,18:52:36] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1601 [06/22/10,20:01:20] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1601 [07/26/10,14:38:42] Microsoft .NET Framework 3.0a: [2] Error: Installation failed for component Microsoft .NET Framework 3.0a. MSI returned error code 1601 [07/26/10,14:41:22] Microsoft .NET Framework 3.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [07/26/10,14:41:22] Microsoft .NET Framework 3.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [07/26/10,14:41:23] Microsoft .NET Framework 3.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [07/26/10,14:41:24] Microsoft .NET Framework 3.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [07/26/10,14:41:26] Microsoft .NET Framework 3.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [07/26/10,14:41:27] Microsoft .NET Framework 3.0a: [2] dlmgr: dlmgr::CDownloadJobURLMonImpl::Failed: URLMonError: Download failure (0x800c0006) [07/26/10,14:41:27] Microsoft .NET Framework 3.0a: [2] dlmgr: dlmgr::JobBase::Retry: all retries failed [07/26/10,14:41:28] Microsoft .NET Framework 3.0a: [2] Failed to fetch setup file in CBaseComponent::PreInstall() [07/26/10,14:41:28] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InternalInstallManager() with HRESULT -2147467260. [07/26/10,14:41:28] setup.exe: [2] CSetupManager::RunInstallPhase() - Call to Pre/Install/Post for InstallComponents failed [07/26/10,14:41:28] setup.exe: [2] CSetupManager::RunInstallPhaseAndCheckResults() - RunInstallPhase() returned a NULL piActionResults [07/26/10,14:41:28] setup.exe: [2] CSetupManager::RunInstallFromList() - RunInstallPhaseAndCheckResults failed [2] [07/26/10,14:41:28] setup.exe: [2] ISetupManager::RunInstallLists(IP_PREINSTALL failed in ISetupManager::RunInstallFromThread() [07/26/10,14:41:28] setup.exe: [2] ISetupManager::RunInstallFromThread() failed in ISetupManager::RunInstall() [07/26/10,14:41:28] setup.exe: [2] CSetupManager::Run() - Call to RunInstall() failed [07/26/10,14:41:29] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.0a is not installed. [07/26/10,14:41:29] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5 'package' was not attempted to be installed. [07/26/10,14:41:29] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5LP - RUS was not attempted to be installed. [07/26/10,21:10:45] Microsoft .NET Framework 3.5 'package': [2] Error: Installation failed for component Microsoft .NET Framework 3.5 'package'. MSI returned error code 1601 [07/26/10,21:11:02] WapUI: [2] DepCheck indicates Microsoft .NET Framework 3.5 'package' is not installed. ... |
| 26.07.2010, 21:17 |
Net frame work 3.5
коргу мну в студии на сайт лезет :( Потому что у тебя облегченная версия. В полных версиях все версии разные и полные. Ну разве за обновлениями полезут. Кстати, авторизация на сайте несложна и скачивается нужное легко почему-то у меня. ... |
| 26.07.2010, 21:54 |
start [/forum/topic.php?desktop=1&fid=26&tid=1499533]: |
72ms |
23ms |
| others: | 194ms |
| total: | 321ms |
