OpenVPN статические IP адреса
Уважаемые гуру! Коллеги! Прошу помощи. Поднял сервер VPN (впервые) на ОС Windows. Нужны статические айпишники для клиентов. Конфиг сервера: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. Код: plaintext 1. 2. 3. 4. 5. 6. Код: plaintext ... |
| 20.04.2011, 21:06 |
В OpenVPN можно сделать привязку IP к сертификату. Вот пример Using a Client Configuration Directory with Per-Client Configurations Another striking feature of OpenVPN is the fact that we can have client configurations pushed through the tunnel on creation and use client-specific configurations, which are simply set by the subject line of the client's certificate. An appropriate server configuration file may look like the following: port 443 dev tun0FIT ca /etc/openvpn/certs/ca.crt cert /etc/openvpn/certs/firewall.crt key /etc/openvpn/certs/firewall.key dh /etc/openvpn/certs/dh2048.pem tls-auth /etc/openvpn/certs/ta.key 0 auth SHA1 cipher AES-256-CBC tls-cipher DHE-RSA-AES256-SHA server 10.179.0.0 255.255.0.0 ifconfig-pool-persist /etc/openvpn/ipp.txt client-config-dir clients keepalive 10 120 resolv-retry 86400 comp-lzo status /var/log/openvpn/status.log log /var/log/openvpn/main.log tls-server verb 3 There are three lines that are relevant in this context: 1. server 10.179.0.0 255.255.0.0: This tells OpenVPN on this machine to act as a server and automatically distribute IP addresses to clients connecting. 2. ifconfig-pool-persist /etc/openvpn/ipp.txt: This makes OpenVPN keep a list of certificate to IP relationships, so that a client connecting will (probably) always have the same IP. 3. client-config-dir clients: This has OpenVPN look in the directory "clients" for a client-specific configuration file when a client connects. Используя настройку в файле ipp.txt можно сделать привязку IP к сертификту. Конфиг UNIX-вый. ... |
| 22.04.2011, 15:04 |
Посмотри книгу OpenVPN Building and Integrating Virtual Private Networks Learn how to build secure VPNs using this powerful Open Source application Markus Feilner Рекомендую. ... |
| 22.04.2011, 15:08 |
start [/forum/topic.php?desktop=1&fid=26&tid=1498318]: |
161ms |
52ms |
| others: | 251ms |
| total: | 511ms |
