Windows 7 папка "C:\\windows\system32\smi\store\machine"
Windows 7 ultimate есть папочка C:\\windows\system32\smi\store\machine в ней файлы SCHEMA.DAT SCHEMA.DAT.LOG1 SCHEMA.DAT.LOG2 и еще некоторые файлы для чего эта папка и что в ней хранится ? ... |
| 26.11.2011, 17:03:23 |
http://www.sevenforums.com/tutorials/107982-clfs-transaction-logs-reset.html The Common Log File System (CLFS) is a general-purpose logging service that can be used by software clients running in user-mode or kernel-mode.(source Using Common Log File System (Windows Driver Kit)) If due to any reason system transaction logs are in an inconsistant state you may have following problems in your system -Windows Update Error 0x80070643,0x8007000B,0x80071A91 -Repeatedly offered the same update,in update history is information about succesfully installed an update,although in Programs and Features>>View Installed Updates there is no this update -Windows Backup Errror 0x80071A91 -System Restore Error 0x80071A91 -Task Scheduler Error Transaction support within the specified file system resource manager is not started or was shut down due to an error and other issues with Task Scheduler -issues with Windows Search service (i.e Event ID 1006 and other) -possibly below methods can help you fix anything 0x80071A91 error in your system and many other unknow poorly documented errors ... |
| 26.11.2011, 17:30:25 |
А в каких случаях эта папка появляется? Есть несколько машин с 7-ой и на одних эта папка есть а на других нету. ... |
| 29.11.2011, 12:24:06 |
Владимир Г.А в каких случаях эта папка появляется? Есть несколько машин с 7-ой и на одних эта папка есть а на других нету. еще раз нагадываем: автор-Windows Update Error 0x80070643,0x8007000B,0x80071A91 -Repeatedly offered the same update,in update history is information about succesfully installed an update,although in Programs and Features>>View Installed Updates there is no this update -Windows Backup Errror 0x80071A91 -System Restore Error 0x80071A91 -Task Scheduler Error Transaction support within the specified file system resource manager is not started or was shut down due to an error and other issues with Task Scheduler -issues with Windows Search service (i.e Event ID 1006 and other) -possibly below methods can help you fix anything 0x80071A91 error in your system and many other unknow poorly documented errors ... |
| 29.11.2011, 16:31:02 |
Владимир Г.Есть несколько машин с 7-ой и на одних эта папка есть а на других нету. -Windows Update Error 0x80070643,0x8007000B,0x80071A91 -Repeatedly offered the same update,in update history is information about succesfully installed an update,although in Programs and Features>>View Installed Updates there is no this update -Windows Backup Errror 0x80071A91 -System Restore Error 0x80071A91 -Task Scheduler Error Transaction support within the specified file system resource manager is not started or was shut down due to an error and other issues with Task Scheduler -issues with Windows Search service (i.e Event ID 1006 and other) -possibly below methods can help you fix anything 0x80071A91 error in your system and many other unknow poorly documented errors Видимо в этих файлах записываются различные ошибки. Значит эта машина самая не стабильная. :) ... |
| 01.12.2011, 05:31:30 |
start [/forum/topic.php?desktop=1&fid=26&tid=1497364]: |
59ms |
34ms |
| others: | 188ms |
| total: | 319ms |
