Помогите с BSOD
постоянно вытетает BSOD. использую WinDbg получил вот это: авторMicrosoft (R) Windows Debugger Version 6.12.0002.633 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Windows\Minidump\011012-16302-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*c:\symbols* http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7601 (Service Pack 1) MP (8 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506 Machine Name: Kernel base = 0xfffff800`03006000 PsLoadedModuleList = 0xfffff800`0324b670 Debug session time: Tue Jan 10 12:00:32.625 2012 (UTC + 4:00) System Uptime: 0 days 0:02:20.625 Loading Kernel Symbols ............................................................... ................................................................ ........................................ Loading User Symbols Loading unloaded module list .... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck 1A, {41790, fffffa8004760df0, ffff, 0} Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+36024 ) Followup: MachineOwner --------- 3: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* MEMORY_MANAGEMENT (1a) # Any other values for parameter 1 must be individually examined. Arguments: Arg1: 0000000000041790, The subtype of the bugcheck. Arg2: fffffa8004760df0 Arg3: 000000000000ffff Arg4: 0000000000000000 Debugging Details: ------------------ BUGCHECK_STR: 0x1a_41790 CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT PROCESS_NAME: mscorsvw.exe CURRENT_IRQL: 0 LAST_CONTROL_TRANSFER: from fffff800030f2150 to fffff80003082c40 STACK_TEXT: fffff880`09347828 fffff800`030f2150 : 00000000`0000001a 00000000`00041790 fffffa80`04760df0 00000000`0000ffff : nt!KeBugCheckEx fffff880`09347830 fffff800`030b6569 : 00000000`00000000 00000000`73007fff fffffa80`00000000 fffff880`00961000 : nt! ?? ::FNODOBFM::`string'+0x36024 fffff880`093479f0 fffff800`0339a221 : fffffa80`073a5f80 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiRemoveMappedView+0xd9 fffff880`09347b10 fffff800`0339a623 : 0000007f`00000000 00000000`72e10000 fffffa80`00000001 fffffa80`10e419e0 : nt!MiUnmapViewOfSection+0x1b1 fffff880`09347bd0 fffff800`03081ed3 : 00000000`00000000 00000000`730049a8 fffffa80`0738b060 00000000`00000001 : nt!NtUnmapViewOfSection+0x5f fffff880`09347c20 00000000`76e915ba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13 00000000`0012acf8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x76e915ba STACK_COMMAND: kb FOLLOWUP_IP: nt! ?? ::FNODOBFM::`string'+36024 fffff800`030f2150 cc int 3 SYMBOL_STACK_INDEX: 1 SYMBOL_NAME: nt! ?? ::FNODOBFM::`string'+36024 FOLLOWUP_NAME: MachineOwner MODULE_NAME: nt IMAGE_NAME: ntkrnlmp.exe DEBUG_FLR_IMAGE_TIMESTAMP: 4e02aaa3 FAILURE_BUCKET_ID: X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+36024 BUCKET_ID: X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+36024 Followup: MachineOwner --------- что с этим дальше делать непойму ... |
| 10.01.2012, 14:07:55 |
Помогите с BSOD
Ноутбук ASUS G73JW ... |
| 10.01.2012, 14:10:32 |
Помогите с BSOD
xteam777, Установи Линух и буде тебе счастие. На крайняк Мас себе купи. Гораздо лучше ... ... |
| 10.01.2012, 15:09:00 |
Помогите с BSOD
я не просил советов по переустановке ос. мне необходима помощь в определении причины ошибки ... |
| 10.01.2012, 15:20:32 |
Помогите с BSOD
Там у вас в дампе упоминается процесс: http://www.gizmonder.com/2011/01/mscorsvwexe.html Почитайте, и удаляйте его совсем. ... |
| 10.01.2012, 16:09:49 |
Помогите с BSOD
спасибо за объяснение. а кроме того чтобы он просто не запускался вариантов нет? меня смутил параметр VISTA_DRIVER_FAULT. Тоесть дело в каком-то из драйверов. Модератор: Тема перенесена из форума "Наши за рубежом". ... |
| 10.01.2012, 16:41:18 |
Помогите с BSOD
Сам решил: проблема была в битом винте, и как только файл подкачки натыкался на битый сектор комп вис или вываливал ВSOD( ... |
| 13.01.2012, 18:15:05 |
Помогите с BSOD
Винт не битый - винт недопроверенный на заводе (а может, контейнер упал при загрузке в трюм...) В целом - нам уже сейчас не лень: - установив "HDD из упаковки" - проверить его MHDD/Victioria - при первоначальной разметке разделов - делать полное форматирование ИБО производителей - всё меньше и меньше... ... |
| 13.01.2012, 20:10:04 |
start [/forum/topic.php?desktop=1&fid=26&tid=1497253]: |
72ms |
56ms |
| others: | 225ms |
| total: | 405ms |
