Ошибка в IIS
имеется ошибка в IIS. не пойму, что нужно для исправления. error - 5002 - WAS. Содержание : The description for Event ID 5002 from source Microsoft-Windows-WAS cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer. If the event originated on another computer, the display information had to be saved with the event. The following information was included with the event: CCM Client Notification Proxy Pool ... |
| 08.10.2015, 09:13 |
start [/forum/topic.php?desktop=1&fid=26&tid=1493833]: |
74ms |
42ms |
| others: | 250ms |
| total: | 414ms |
