Обновление directX выполнена с ошибкой
У меня на Windows 7 установлен directX 11. При запуске его обновления с помощью программы dxwebsetup.exe возникает следующая ошибка (см файл ErrorDirectX.bmp) Лог ошибки в файле DXError.log: [01/30/16 11:44:41] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 6124, function: CFusion::CFusion Failed API: LoadLibraryShim() Error: (0x80070006) - Неверный дескриптор. -------------------- [01/30/16 11:44:41] module: dxupdate(Nov 19 2010), file: dxupdate.cpp, line: 2969, function: IsMDXInUse Unable to initialize MDXCheck. -------------------- [01/30/16 11:44:41] module: dsetup32(Mar 30 2011), file: dxupdate.cpp, line: 280, function: CSetup::InstallPlugIn DirectXUpdateInstallPlugIn() failed. А лог в файле DirectX.log 01/30/16 11:44:41: dsetup32: === SetupForDirectX() start === 01/30/16 11:44:41: dsetup32: Mar 30 2011 04:38:03 01/30/16 11:44:41: dsetup32: SetupForDirectX(): query dxsetup command: result = 2. 01/30/16 11:44:41: dsetup32: DXSetupCommand = 0. 01/30/16 11:44:41: DXWSetup: DSetupCallback(): Phase = 0, Steps = 0 01/30/16 11:44:41: dsetup32: Installing on Windows 6.1.7601 01/30/16 11:44:41: dsetup32: DirectXSetupIsJapanese == 0 01/30/16 11:44:41: dsetup32: DirectXSetupIsJapanNec == 0 01/30/16 11:44:41: dsetup32: IsIA64(): not IA64. 01/30/16 11:44:41: dsetup32: CLR version number = 2.0.50727 01/30/16 11:44:41: dsetup32: CLR version number = 4.0.30319 01/30/16 11:44:41: dsetup32: DXCheckTrust(): C:\Windows\system32\DirectX\WebSetup\dxupdate.cab is trusted. 01/30/16 11:44:41: dsetup32: GetCDXUpdate(): Extracting dxupdate.dll from C:\Windows\system32\DirectX\WebSetup\dxupdate.cab. 01/30/16 11:44:41: dsetup32: Extracted file E:\TEMP\DX1C96.tmp\dxupdate.dll from cab 01/30/16 11:44:41: dsetup32: Extracted file E:\TEMP\DX1C96.tmp\dxupdate.inf from cab 01/30/16 11:44:41: dsetup32: Extracted file E:\TEMP\DX1C96.tmp\dxupdate.cif from cab 01/30/16 11:44:41: dsetup32: GetCDXUpdate(): Loading dxupdate.dll in E:\TEMP\DX1C96.tmp\. 01/30/16 11:44:41: dsetup32: DirectXSetupIsJapanese == 0 01/30/16 11:44:41: dsetup32: DirectXSetupIsJapanNec == 0 01/30/16 11:44:41: dsetup32: IsWow64(): running on Wow64. 01/30/16 11:44:41: dxupdate: ----- 01/30/16 11:44:41: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In dxdllreg_x86.cab does not exist. 01/30/16 11:44:41: dxupdate: ----- 01/30/16 11:44:41: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_1_x86.cab does not exist. 01/30/16 11:44:41: dxupdate: ----- 01/30/16 11:44:41: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_1_x64.cab does not exist. 01/30/16 11:44:41: dxupdate: ----- 01/30/16 11:44:41: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_2_x86.cab does not exist. 01/30/16 11:44:41: dxupdate: ----- 01/30/16 11:44:41: dxupdate: DirectXUpdateInstallPlugIn(): Plug-In RGB9Rast_2_x64.cab does not exist. 01/30/16 11:44:41: dxupdate: ----- 01/30/16 11:44:41: dxupdate: DirectXUpdateInstallPlugIn(): DXUPDATE_MANAGEDDX 01/30/16 11:44:41: dxupdate: DirectXUpdateInstallPlugIn(): Checking for MDX_1.0.2902.0_x86.cab... 01/30/16 11:44:41: dxupdate: DXCheckTrust(): C:\Windows\system32\DirectX\WebSetup\MDX_1.0.2902.0_x86.cab is trusted. 01/30/16 11:44:41: dxupdate: Extracted file E:\TEMP\DX1C96.tmp\mdx_1.0.2902.0_x86.inf from cab 01/30/16 11:44:41: dxupdate: DirectXUpdateGetSetupInformation(): DirectX Version: 4.09.00.0904.0 01/30/16 11:44:41: dxupdate: CheckDependency(): no dependency. 01/30/16 11:44:41: dxupdate: DirectXUpdateGetSetupInformation(): Section [4.09.00.0904.0-4.09.00.0904.0_WinNT@64] is being installed. 01/30/16 11:44:41: dxupdate: CFusion::CFusion(): LoadLibraryShim() failed, error = 0x80070006. 01/30/16 11:44:41: dxupdate: IsMDXInUse(): Unable to initialize MDXCheck. 01/30/16 11:44:41: dsetup32: CSetup::InstallPlugIn(): DirectXUpdateInstallPlugIn() failed. 01/30/16 11:44:41: DXWSetup: DSetupCallback(): Phase = 0, Steps = 0 01/30/16 11:44:41: dsetup32: start finalizing: phase: 0 - 0, total: 0 - 0 01/30/16 11:44:41: DXWSetup: DSetupCallback(): Phase = 3, Steps = 0 01/30/16 11:44:41: dsetup32: Installation ended with value -9 = Internal or unsupported error 01/30/16 11:50:14: DXWSetup: WM_APP_ENDINSTALL 01/30/16 11:50:14: DXWSetup: CDXWSetup::~CDXWSetup() 01/30/16 11:50:16: DXWSetup: CreatePropertySheet() returns -9. 01/30/16 11:50:16: DXWSetup: Deleted file C:\Windows\system32\directx\websetup\dsetup.dll. 01/30/16 11:50:16: DXWSetup: Deleted file C:\Windows\system32\directx\websetup\dsetup32.dll. Как мне устранить эту проблему? ... |
| 30.01.2016, 12:02 |
start [/forum/topic.php?desktop=1&fid=26&tid=1493660]: |
179ms |
48ms |
| others: | 237ms |
| total: | 512ms |
