Не пингуется сетевой интерфейс
Здравствуйте! Есть следующая конфигурация VMWare Workstation: 1. MS Windows Server 2016 Datacenter (Evaluation ver) # 1.1 Включена роль RRAS (routing) 1.2 В VMWare создан адаптер Host-only 1.3 Настроен сетевой интерфейс: PS C:\Windows\system32> Get-NetIPConfiguration InterfaceAlias : Ethernet1 InterfaceIndex : 10 InterfaceDescription : Intel(R) 82574L Gigabit Network Connection #2 NetProfile.Name : Unidentified network IPv4Address : 10.39.39.3 IPv4DefaultGateway : DNSServer : InterfaceAlias : Ethernet0 InterfaceIndex : 3 InterfaceDescription : Intel(R) 82574L Gigabit Network Connection NetProfile.Name : Unidentified network IPv4Address : 10.39.0.4 IPv4DefaultGateway : DNSServer : 1.4 Все профили файрвола отключены: PS C:\Windows\system32> Get-NetFirewallProfile Name : Domain Enabled : False DefaultInboundAction : NotConfigured DefaultOutboundAction : NotConfigured AllowInboundRules : NotConfigured AllowLocalFirewallRules : NotConfigured AllowLocalIPsecRules : NotConfigured AllowUserApps : NotConfigured AllowUserPorts : NotConfigured AllowUnicastResponseToMulticast : NotConfigured NotifyOnListen : False EnableStealthModeForIPsec : NotConfigured LogFileName : %systemroot%\system32\LogFiles\Firewall\pfirewall.log LogMaxSizeKilobytes : 4096 LogAllowed : False LogBlocked : False LogIgnored : NotConfigured DisabledInterfaceAliases : {NotConfigured} Name : Private Enabled : False DefaultInboundAction : NotConfigured DefaultOutboundAction : NotConfigured AllowInboundRules : NotConfigured AllowLocalFirewallRules : NotConfigured AllowLocalIPsecRules : NotConfigured AllowUserApps : NotConfigured AllowUserPorts : NotConfigured AllowUnicastResponseToMulticast : NotConfigured NotifyOnListen : False EnableStealthModeForIPsec : NotConfigured LogFileName : %systemroot%\system32\LogFiles\Firewall\pfirewall.log LogMaxSizeKilobytes : 4096 LogAllowed : False LogBlocked : False LogIgnored : NotConfigured DisabledInterfaceAliases : {NotConfigured} Name : Public Enabled : False DefaultInboundAction : NotConfigured DefaultOutboundAction : NotConfigured AllowInboundRules : NotConfigured AllowLocalFirewallRules : NotConfigured AllowLocalIPsecRules : NotConfigured AllowUserApps : NotConfigured AllowUserPorts : NotConfigured AllowUnicastResponseToMulticast : NotConfigured NotifyOnListen : False EnableStealthModeForIPsec : NotConfigured LogFileName : %systemroot%\system32\LogFiles\Firewall\pfirewall.log LogMaxSizeKilobytes : 4096 LogAllowed : False LogBlocked : False LogIgnored : NotConfigured DisabledInterfaceAliases : {NotConfigured} По какой-то причине 3-ий интерфейс пингуется, а 10 - нет. Где искать ошибку? Модератор: Тема перенесена из форума "Microsoft SQL Server". ... |
| 04.06.2017, 23:49 |
Как сделана адресация, может не та подсеть? ... |
| 05.06.2017, 13:18 |
netfrog, что это значит? интерфейс принадлежит той же машине с которой идут пакеты пинга. Свой то интерфейс машина должна пинговать. Можно конечно сделать так, чтобы этого не было, но мне оно не нужно было и интерфейс простой такой интерфейс. Я на нем ipv6 и dhcp отключил - мне так нужно. ... |
| 05.06.2017, 14:34 |
4Address : 10.39.39.3 и IPv4Address : 10.39.0.4 могут быть в разных подсетях. Можно увидеть по маске. ... |
| 05.06.2017, 15:02 |
netfrog, ну и что, что они в разных сетях. Я вообще думал, что после того как данные режутся на пакеты проверяется находится ли машина в родной сети (домен коллизий), а потом делается в зависимости от того какой будет ответ принимается решение об использовании способа доставки пакета: напрямую или через маршрутизацию. Если пакет отправляется в родную сеть(и), то просто arp запросом получаем мак машины назначения и транслируем в домен колизий сигнал, а если нужна маршрутизация, то смотрим в таблицу маршрутов и выбираем подходящий, а затем отдаем на "почту", чтоб там дальше разобрались. Эти две сети смотрят с одной машины; не понимаю причем здесь это? Для этой мшины обе сети родные и, как мне кажется машина должна в обе сети запросить мак и отправить в обе сети. Я не ставил по правде говоря эксперемент и в литературе поленился прочитать, но я думаю это разумно. ... |
| 05.06.2017, 21:39 |
jeep81, У вас похоже хост не знает, что у вм есть сетка 10.39.39.0... ... |
| 05.06.2017, 22:12 |
Sergey Orlov, так я же не с хоста, а с гостя пингую гостя же (себя, свой гостевой же интерфейс). ... |
| 05.06.2017, 22:14 |
Создал новый host-only интерфейс - пингуется. Но тот который 10ый так и не пингуется. Не могу бросить этот вопрос. Нужно проанализировать ситуацию. Есть какие-нибудь идеи как можно сравнить два интерфейса и понять в чем отличия? Или понять что здесь не так? ... |
| 05.06.2017, 22:23 |
Для полноты картины: 1. ipaddress PS C:\Users\Administrator> Get-NetIPAddress -ifindex 10 | format-list IPAddress : 10.39.39.3 InterfaceIndex : 10 InterfaceAlias : Ethernet1 AddressFamily : IPv4 Type : Unicast PrefixLength : 24 PrefixOrigin : Manual SuffixOrigin : Manual AddressState : Preferred ValidLifetime : Infinite ([TimeSpan]::MaxValue) PreferredLifetime : Infinite ([TimeSpan]::MaxValue) SkipAsSource : False PolicyStore : ActiveStore 2. ipinterface PS C:\Users\Administrator> Get-NetIPinterface -ifindex 10 | format-list InterfaceIndex : 10 InterfaceAlias : Ethernet1 CompartmentId : 1 AddressFamily : IPv4 Forwarding : Enabled ClampMss : Disabled Advertising : Disabled NlMtu(Bytes) : 1500 AutomaticMetric : Enabled InterfaceMetric : 25 NeighborDiscoverySupported : Yes NeighborUnreachabilityDetection : Enabled BaseReachableTime(ms) : 30000 ReachableTime(ms) : 29500 RetransmitTime(ms) : 1000 DadTransmits : 3 DadRetransmitTime(ms) : 1000 RouterDiscovery : ControlledByDHCP ManagedAddressConfiguration : Enabled OtherStatefulConfiguration : Enabled WeakHostSend : Disabled WeakHostReceive : Disabled IgnoreDefaultRoutes : Disabled AdvertisedRouterLifetime : 00:30:00 AdvertiseDefaultRoute : Disabled CurrentHopLimit : 0 ForceArpNdWolPattern : Disabled DirectedMacWolPattern : Disabled EcnMarking : AppDecide Dhcp : Disabled ConnectionState : Connected PolicyStore : ActiveStore 3. adapter PS C:\Users\Administrator> Get-Netadapter -ifindex 10 | format-list Name : Ethernet1 InterfaceDescription : Intel(R) 82574L Gigabit Network Connection #2 InterfaceIndex : 10 MacAddress : 00-50-56-26-E0-D2 MediaType : 802.3 PhysicalMediaType : 802.3 InterfaceOperationalStatus : Up AdminStatus : Up LinkSpeed(Gbps) : 1 MediaConnectionState : Connected ConnectorPresent : True DriverInformation : Driver Date 2016-04-05 Version 12.15.22.6 NDIS 6.30 ... |
| 05.06.2017, 22:41 |
jeep81, это наверное какой-то глюк или мой пробел в устройстве сетевой архитектуры виртуальных машин. 1. На сетевом интерфейсе ipv4 включил "Obtain an ip address automaticly". 2. Сохранил настройки. 3. Вернул все настройки как было. В результате пинг пошел. ... |
| 05.06.2017, 23:54 |
start [/forum/topic.php?desktop=1&fid=26&tid=1493083]: |
184ms |
51ms |
| others: | 241ms |
| total: | 517ms |
