Windows.Update не работает (8.1)
Всё было нормально. Проблема возникла когда не смог заинсталить последний SSMS. Вылетало на установке .NET Framework 4.7.2. Ошибка: 0x80070003 Failed to execute EXE package Install, path: C:\ProgramData\Package Cache\D3A416DC5FC75758D41B4C0158ACA69270D2A904\redist\NDP472-KB4054530-x86-x64-AllOS-ENU.exe arguments: '"C:\ProgramData\Package Cache\D3A416DC5FC75758D41B4C0158ACA69270D2A904\redist\NDP472-KB4054530-x86-x64-AllOS-ENU.exe" /q /norestart /chainingpackage SSMS-Setup-ENU /log %localappdata%\temp\SsmsSetup\DotNet47' Попробовал установить .NET Framework 4.7.2 вручную. Загрузил и запустил "NDP472-KB4054531-Web.exe" Вылетело с дурацкой ошибкой "The system cannot find the path specified" ЛогиOS Version = 6.3.9600, SP = 0.0, Platform 2 OS Description = Win81 - x64 Enterprise Edition MSI = 5.0.9600.17905 Windows servicing = 6.3.9600.18384 CommandLine = C:\60b35b6be4fed408d8\\Setup.exe /x86 /x64 /web TimeZone = Eastern Standard Time Initial LCID = 1033 Using Simultaneous Download and Install mechanism Operation: Installing Package Name = Microsoft .NET Framework 4.7.2 Setup Package Version = 4.7.03081 User Experience Data Collection Policy: AlwaysUploaded Number of applicable items: 6 Exe (C:\60b35b6be4fed408d8\SetupUtility.exe) succeeded. Exe Log File: dd_SetupUtility.txt Exe (C:\60b35b6be4fed408d8\SetupUtility.exe) succeeded. Exe Log File: dd_SetupUtility.txt Exe (C:\60b35b6be4fed408d8\Windows8.1-KB4054566-x64.cab) failed with 0x3 - The system cannot find the path specified. . Exe (C:\60b35b6be4fed408d8\Windows8.1-KB4054566-x64.cab) failed with 0x3 - The system cannot find the path specified. . Exe (C:\60b35b6be4fed408d8\Windows8.1-KB4054566-x64.cab) failed with 0x3 - The system cannot find the path specified. . Exe (C:\60b35b6be4fed408d8\Windows8.1-KB4054566-x64.cab) failed with 0x3 - The system cannot find the path specified. . Final Result: Installation failed with error code: (0x00000003), "The system cannot find the path specified. " (Elapsed time: 0 00:03:13). Далее я попробовал загрузить "Windows8.1-KB4054566-x64.cab" в ручную C:\Windows\System32\DISM.exe /Online /Add-Package /PackagePath:c:\temp\Windows8.1-KB4054566-x64.cab ВыдалоError: 3 The directory C:\Windows does not appear to be a valid Windows directory. Ensure that the /WinDir option that is specified is valid. For more information, refer to the help by running DISM.exe /WinDir /?. The DISM log file can be found at C:\Windows\Logs\DISM\dism.log Log2019-02-23 19:37:16, Warning DISM DISM OS Provider: PID=6128 TID=892 Failed to bind the online servicing stack - CDISMOSServiceManager::get_ServicingStackDirectory(hr:0x80070003) 2019-02-23 19:37:16, Error DISM DISM OS Provider: PID=6128 TID=892 Unable to retrieve servicing stack folder for DLL search path modification. - CDISMOSServiceManager::SetDllSearchPath(hr:0x80070003) Тогда попробовал сделать Update. Нашло 6 апдейтов. Попробовал ставить по одному, но оно подвисает на 5%. Попробовал Получить историю. Последний норамльный апдейт был в Сентябре 2016го. В прошлом декабре я похоже пытался делать апдейт, но оно почему-то инсталит 2 не критических апдейта по кругу. Код: powershell 1. 2. 3. 4. 5. Что делать? Спасибо. ... |
| 24.02.2019, 04:12:26 |
Запустить спасательную прогу от мелкософта https://support.microsoft.com/en-us/help/4027322/windows-update-troubleshooter ... |
| 27.02.2019, 10:43:59 |
aleks222Запустить спасательную прогу от мелкософта https://support.microsoft.com/en-us/help/4027322/windows-update-troubleshooter Я её уже пробовал неделю назад. Она постоянно находит 3 ошибки. Все три вроде-бы фиксит, но висит какая-то тупая ошибка "Access to the path 'C:\Windows\softwaredistribution' is denied." авторWindows Update error 0x80070057(2019-02-27-T- 12_30_19P) Fixed Resetting Windows Update data store Completed DataStoreAndWULogFiles.zip 91.95MB File Name: DataStoreAndWULogFiles.zip Error1 Access to the path 'C:\Windows\softwaredistribution' is denied. Удалил папку C:\Windows\softwaredistribution, оно её пересоздало. Вот уже час ищет апдейты. Напишу чем кончилось. ... |
| 28.02.2019, 07:00:15 |
Вот уже почти полсуток ищет апдейты. Убил его и перезапустил. Оказалось, что всё уже найдено. Дела. Попытался заинсталить апдейт на 3 мега. Похоже та-же байда. Остановилось на 5% Вот думаю может запустить сетап винды и она сама пофиксит? ... |
| 28.02.2019, 15:15:58 |
SandalTree, попробуй выполнить sfc /scannow DISM.exe /Online /Cleanup-image /Restorehealth ... |
| 28.02.2019, 15:58:58 |
вадяSandalTree, попробуй выполнить sfc /scannow DISM.exe /Online /Cleanup-image /Restorehealth Спасибо за участие, но этот этам я прошёл давным давно. Cмотри мой первый пост. Похоже это конкретный баг. DISM не опознаёт виндовс директорию. Сейчас снова на том-же месте. ... |
| 01.03.2019, 03:08:07 |
SandalTree, Formatting and reinstalling Windows rules! ... |
| 01.03.2019, 03:20:16 |
SandalTree, от какого юзера пробуешь делать? ... |
| 01.03.2019, 16:07:19 |
вадяSandalTree, от какого юзера пробуешь делать?Administrator. Пробую прогнать CHKDSK уже 12 часов висит собака. Надеюсь когда закончится это пофиксит проблему. ... |
| 01.03.2019, 17:51:01 |
SandalTreeвадяSandalTree, от какого юзера пробуешь делать?Administrator. Пробую прогнать CHKDSK уже 12 часов висит собака. Надеюсь когда закончится это пофиксит проблему. похоже на битый диск..... ... |
| 03.03.2019, 00:56:36 |
SandalTree, я б ещё подключил диск к дркгой машине и проверил авастом на этапе до загрузки системы (именно у аваста такое есть) ... |
| 03.03.2019, 00:59:30 |
вадяSandalTreeпропущено... Administrator. Пробую прогнать CHKDSK уже 12 часов висит собака. Надеюсь когда закончится это пофиксит проблему. похоже на битый диск..... Один раз удалось загрузиться. CHKDSK вроде не нашло никаких ошибок, но написало про чего-то там в загрузчике (не сохранил). Я-б тоже подумал что диск битый, если-бы он не был виртуальным. Вобщем пришлось таки похерить эту машину, которая почти 3 года мне служила. вадяSandalTree, я б ещё подключил диск к дркгой машине и проверил авастом на этапе до загрузки системы (именно у аваста такое есть) Подключил его к другой виртуалке, но Аваст не хочу ставить. До того вроде ничего не находило. ... |
| 06.03.2019, 19:36:20 |
start [/forum/topic.php?desktop=1&fid=26&tid=1492505]: |
93ms |
42ms |
| others: | 202ms |
| total: | 380ms |
