WMWare 14 как мне ее запустит на второй машине
мне скачали полностью папку моей виртуаьной машины не экспортировали, как мне ее запустить на другой машине, в PC Windows 10, в WM OS WIN 10 файлы все на месте, первая попытка отпрвила меня в этот лист This host supports Intel VT-x, but Intel VT-x is disabled. Intel VT-x might be disabled if it has been disabled in the BIOS/firmware settings or the host has not been power-cycled since changing this setting. (1) Verify that the BIOS/firmware settings enable Intel VT-x and disable 'trusted execution.' (2) Power-cycle the host if either of these BIOS/firmware settings have been changed. (3) Power-cycle the host if you have not done so since installing VMware Workstation. (4) Update the host's BIOS/firmware to the latest version. This host does not support "Intel EPT" hardware assisted MMU virtualization. Module 'CPUIDEarly' power on failed. Failed to start the virtual machine. ... |
| 18.10.2019, 20:14 |
start [/forum/topic.php?desktop=1&fid=26&tid=1492335]: |
165ms |
| others: | 240ms |
| total: | 463ms |
