Oracle 9.2.0.1 and SuSe 9.1
Hi to All, sorry for English - no Russian keyboard (and Russian driver at all) So I promised to post this info a few times, now I am ready. Maybe something is not clearly - feel free to touch me. So: ---------------------------------------------------------- How to install Oracle 9.2.0.1 on SuSe 9.1 PE I successfully installed Oracle 9.2.0.1 on Suse 9.1 PE. I have pure PC 600 MHz, with 25 GB hard disk. The workflow was the following: 1) Download CD image with SuSe 9.1 from www.suse.com, burn CD 2) Install SuSe 9.1 on PC, during installation skip update 3) Get the document and read it carefully. Follow the instructions from this document. Of course my installation was a little different. Pre-installation steps: 1) Download from metalink.oracle.com and apply path #3006854. It allows to prevent bug of running runInstaller. Код: plaintext 1. 2. 3. 4. 5. 2) Change shmmax parameter. It prevents ORA-27123 error during database creation Код: plaintext 1. 2. The parameter should be 1073741824. Check it Код: plaintext 1. 2. And reboot the machine 3) At first, check your present glibc Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. If you can see GLIBC_2.0 you glibc cannot be used for link oemagent. You should rebuild your glibc package. It allows to link oemagent. At first download from rpm.pbone.net last glibc-2.x.x-x.src.rpm Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. It might the last command was not successful at first time. You should to install a number of packages, which are needed for RPM building. Download and install them from rpm.pbone.net (I used all last for SuSe 9.x) After that try to run the last command again. Код: plaintext 1. 2. And check, your glibc is good right now Код: plaintext 1. 2. 3. 4. 5. 4) Install all packages, recommended for Oracle on Suse: pdksh, gcc_old, libaio, libaio-devel. 5) Install orarun.rmp Код: plaintext 1. 2. 3. 4. 5. 6. 7. This package creates oracle unix account and oinstall, disk (?) group. If you prefer “standard” behavior you should create dba group and oracle account here. Also this package add “false” shell for oracle. It will be better to create /home/oracle folder and assign it to oracle user, change it shell for bash for example and apply some password. Installation of oracle: 1) Run runInstaller. Use all settings as you wish except database creation. Skip it. 2) During the linking you will meet 2 errors, related with ins_oemagent.mk and ins_ctx.mk. Ignore it. 3) When the prompt of running root.sh appeared – to do the following Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. And continue installation. However you ctx error are is fixed yet. You can complete it after installation. 4) The installation should be finished correctly, go to post-installation steps. Post-installation steps: 1) Fix the error with ctx libraries. It has 2 sub-steps. The first is to apply patch #2037255. The second is to edit env_ctx.mk file. So, download the patch from metalink.oracle.com Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 2) Now the oracle installation is fine. Add some minor steps. At first make internal runInstaller available Код: plaintext 1. 2. 3. 3) Create the database instance 4) Make link in $ORACLE_HOME/dbs folder Код: plaintext 1. 2. 3. 5) Edit /etc/oratab file – change “N” to “Y” on your instance name. 6) Edit /etc/sysconfig/oracle file. Change “no” to “yes” against START_ORACLE_DB, START_ORACLE_DB_LISTENER and START_ORACLE_DB_AGENT variables. ENGOY! ... |
| 16.09.2004, 01:06:05 |
маладец & thanx for info. ;-) несколько ремарок. 1. при скачивании Сусе с веба, скачивается Сусе профессионал за исключением нескольких коммерческих рпм_ов. 2. на оракловском форуме мне сказали что оракл 9 лучше использовать, начиная с версии 9.0.4 (багов сильно меньше) 3. http://www.opennet.ru/base/sys/oracle9_install.txt.html отличная статья на русском. в конце статьи линк на металинковские нужные патчи, выложенные на их сервере. с ув. сл зы. ... |
| 16.09.2004, 12:04:25 |
А какая разница приведенной схемы со случаем SuSe 7.2? "В лесу родилась елочка..." ... |
| 16.09.2004, 17:46:47 |
Сходи на сусевый сайт, там есть кой-какая инфа про то как устанавливать на седьмую сусю. А так на первый взгляд наверно можно избежать танцев с бубнами вокруг glibc (как я знаю, glibc-2.3.2-5 экпортит __ctype_ нормально, а не через compat_symbol). Тольки ее уже так просто не найдешь, во-первых, и она так просто не встанет во-вторых. Если "во-первых" еще можно решить (я нашел), то "во-вторых" я думаю пляска очсерьезная. Хотя не пробовал. ... |
| 16.09.2004, 18:00:43 |
2 слава зы По поводу 9.0.4 (или 9. 2 .0.4?)- не знаю, не пробовал. Мога, быть. Я воще перелапатил много доков, в том числе и по 9.2.0.4, и по 9.0.1. Проблемы везде похожие. Щас буду устанавливать 9.2.0.4. Предыдуший опыт установки _в_лоб_ на сусю выдал где-то 10-12 ошибок на линковке, оракл так и не встал. Примерная картина была и при попытке пропатчевать уже работающий 9.2.0.1 и на 9.2.0.4, и на 9.2.0.5 =(. Воще мне и 9.2.0.3 сойдет, но пока не пробовал. Так что буду разбираться. По поводу статьи на русском - можно пользвать, для шапки работает. Был один из моих доков, которые я пользовал. Только на сусе orarun.rpm много чего сам делает. Я думаю его и на шапке можно применить, только поддержку Korn Shell поставить, если ее нема. ... |
| 16.09.2004, 18:18:30 |
Today I patched it up to 9.2.0.3 The pathching went fine, however I lost linstener.ora, tnsnames.ora and some others files =(. I do not know, why... I restored some files manualy and started the listener. However it was impossible to start the agent. Finally I found the following document: some author Clean Start Steps: 1. Start the console. a. Remove all jobs and events registered against the machine the agent is running on. b. As soon as all events and jobs have been removed, the console can be closed again. 2. Stop the Intelligent Agent on the machine. A pre-9.0.1 Agent on Unix can be stopped by issuing the command: $ lsnrctl dbsnmp_stop A 9.0.1 or later Agent on Unix can be stopped by issuing the command: $ agentctl stop After the command has been issued, verify with the 'ps' command that all 'dbsnmp' processes have indeed been stopped. $ ps –ef |grep dbsnmp NOTE: If the Intelligent Agent cannot be stopped, use the 'ps' command to get the process ID's of the DBSNMP processes, and use the 'KILL -9' command to terminate these processes. On Windows NT/2000, use the Control Panel / Services applet, or issue the command line option: C:\> NET STOP "name of the agent service" If you are not sure about the name of the Agent service, issue a 'NET START' command, or check the Services applet for the services that are running. When the agent is stopped, verify with the TaskManager that the dbsnmp processes have indeed been stopped. If the Intelligent Agent can not be stopped via the NET STOP command, the only way to terminate the Agent then, is to use the 'KILL' command. The KILL utility is provided in the Windows NT Resource Kit. C:\> KILL -f DBSNMP 3. Go to the "$ORACLE_HOME/network/agent" directory. In this directory, delete the following files: services.ora *.q *.inp *.jou out* tcl* dbsnmp.ver SERVICES.ORA This file contains all the services the agent has discovered. This file will be recreated the next time the agent starts. *.q These files are the binary representation of all registered and running jobs and events. The agent creates new fresh files on startup when they do not exist. Information about the host the agent is running on is stored in these files. If the name or the IP address of the agent machine changes, these files need to be recreated. *.inp These files are parameter files for registered jobs. *.jou These files are journal files with information the agent will use to execute jobs. out* These files are temporary output files. These files are generated when jobs are being executed and should be automatically removed by the agent after a job finishes. tcl* These files are TCL template scripts, including the specific commands specified in the job send to the agent. There are *.tcl files in other directories – DO NOT delete the other TCL files. They are scripts that ship with the Agent. DBSNMP.VER This file is a text file with the agent version information. This file will also be recreated when the agent starts again. NOTE: DO NOT DELETE the SVPPCART.DAT file that exists with 9.0.1 and later Agents. This file is the definition file for the Agent’s Data Gatherer Cartridge and is not generated by the Agent. 4. Next, go to the "$ORACLE_HOME/network/admin" or "TNS_ADMIN" directory and remove the following files: SNMP_RO.ORA This file contains read-only information about the Agent’s discovered services on the machine. This file should never be manually edited! During startup, this file is read if it exists, and then recreated again with the new discovery information. SNMP_RW.ORA This file contains read-write information about the Agent’s discovered services on the machine. Some of the information in this file can be edited by an administrator to provide additional information like tracing / logging and hostname resolution, etc. During startup, this file is also read if it exists and new discovery information is appended to the file. 5. In order to have a good idea of the things the agent has logged and reported during startup, it is advised to either rename or remove the existing log files the agent has already created. The following files, all located in the "$ORACLE_HOME/network/log" directory and are used during startup of the agent: Pre 9.0.1 Agents: - NMICONF.LOG Discovery log files - NMI.LOG: SQL*Net connection errors - DBSNMPC.LOG: Communication thread logging, if logging is enabled - DBSNMPW.LOG: Working thread logging, if logging is enabled 9.0.1 and later Agents: AGENTSRVC.LOG A Windows NT/2000 file that shows startup errors DBSNMP.LOG Communication and Work thread logging is in one file NMICONF.LOG Discovery log files Oracle<home>90Agent.nohup Agent startup errors. 6. Check the $ORACLE_HOME/network/library directory for any core dumps. If they exist, remove them. 7. Recreate an empty SNMP_RO.ORA file. Add this single line in the file: snmp.visibleservices = () 8. If tracing is needed to debug a certain situation, a new "SNMP_RW.ORA" can be created, with the debug parameters: Pre-9.0.1 Agents: nmi.trace_level=16 nmi.trace_unique=true 9.0.1 or later Agents: dbsnmp.trace_level=16 dbsnmp.trace_unique=true 9. Restart the Agent. After the agent has started, verify the "SERVICES.ORA" file first. If this file contains all the services on the machine, then check the "SNMP_RO.ORA" and "SNMP_RW.ORA" files. Discovery problems can be found in the file "NMICONF.LOG". It was helpful, now I have Oracle 9.2.0.3 on SuSe 9.1, all works fine. I already tested my application on it. ... |
| 17.09.2004, 22:01:56 |
Так, установил оракл 9.2.0.4 на сусю 9.1 SLES. Похоже, но все же несколько иначе: Начало такое же как и для 9.2.0.1, другой сам процесс инсталяции. Installation of oracle: 1) Run runInstaller. Use all settings as you wish except database creation. Skip it. 2) During the linking you will meet 2 errors, related with ins_rdbms.mk and ins_net_client.mk. Ignore it. 3) When the prompt of running root.sh appeared – to do the following Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. However the bug with dnsnmp is not fixed yet. You should to apply 2 patches (#2617419 and #3238244) there. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. and run [src]>su - root >cd $ORACLE_HOME >./root.sh [src] 4) The installation should be finished correctly, go to post-installation steps. Вобщем все, уже рабочая инсталяция. Особых танцев с бубном не надо. ... |
| 22.09.2004, 21:00:00 |
start [/forum/topic.php?desktop=1&fid=25&tid=1491316]: |
53ms |
| others: | 193ms |
| total: | 297ms |
