Ошибка после обновления ядра L 99 99 99 99 99 99 99 99 99... 99
хе, вот такая чтука после обновления ядра. что это за код ошибки 99? исправить нераально? только reinstall linux? ... |
| 30.10.2004, 03:11:32 |
Читаем документацию L error The first stage boot loader has been loaded and started, but it can't load the second stage boot loader. The two-digit error codes indicate the type of problem. (See also the LILO Disk Error Codes section, below.) This condition usually indicates a media failure or bad disk parameters in the IPCop PC's BIOS. -------------------- The boot process takes place in two stages. The first stage loader is a single sector, and is loaded by the BIOS or by the loader in the MBR. It loads the multi-sector second stage loader, but is very space limited. When the first stage loader gets control, it types the letter "L"; when it is ready to transfer control to the second stage loader it types the letter "I". If any error occurs, like a disk read error, it will put out a hexadecimil error code, and then it will re-try the operation. All hex error codes are BIOS return values, except for the lilo-generated 40, 99 and 9A. A partial list of error codes follows: 00 no error 01 invalid disk command 0A bad sector flag 0B bad track flag 20 controller failure 40 seek failure (BIOS) 40 cylinder>1023 (LILO) 99 invalid second stage index sector (LILO) 9A no second stage loader signature (LILO) AA drive not ready FF sense operation failed Возможно вот это поможет: Чье то сообщение ... |
| 30.10.2004, 08:13:22 |
start [/forum/topic.php?desktop=1&fid=25&tid=1491251]: |
57ms |
27ms |
| others: | 241ms |
| total: | 357ms |
