powered by simpleCommunicator - 2.0.60     © 2026 Programmizd 02
Форумы / Unix-системы [игнор отключен] [закрыт для гостей] / Настройка видяшки
6 сообщений из 6, страница 1 из 1
Настройка видяшки
    #32867539
Колбаскин
Уважаемые Линукс-гуры. Помогите чайнику настроить X-Window. При запуске ругается и выпадает в консоль.
Вот конфиг.
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
105.
106.
107.
108.
109.
110.
111.
112.
113.
114.
115.
116.
117.
118.
119.
120.
121.
122.
123.
124.
# XFree86  4  configuration created by pyxf86config
Section "ServerLayout"
	Identifier     "Default Layout"
	Screen       0   "Screen0"  0   0
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
# RgbPath is the location of the RGB database.  Note, this is the name of the
# file minus the extension (like ".txt" or ".db").  There is normally
# no need to change the default.
# Multiple FontPath entries are allowed (they are concatenated together)
# By default, Red Hat  6 . 0  and later now use a font server independent of
# the X server to render fonts.
	RgbPath      "/usr/X11R6/lib/X11/rgb"
	FontPath     "unix/:7100"
EndSection
Section "Module"
	Load  "dbe"
	Load  "extmod"
	Load  "fbdevhw"
	Load  "glx"
	Load  "record"
	Load  "freetype"
	Load  "type1"
	Load  "dri"
EndSection
Section "InputDevice"
# Specify which keyboard LEDs can be user-controlled (eg, with xset( 1 ))
#	Option	"Xleds"		"1 2 3"
# To disable the XKEYBOARD extension, uncomment XkbDisable.
#	Option	"XkbDisable"
# To customise the XKB settings to suit your keyboard, modify the
# lines below (which are the defaults).  For example, for a non-U.S.
# keyboard, you will probably want to use:
#	Option	"XkbModel"	"pc102"
# If you have a US Microsoft Natural keyboard, you can use:
#	Option	"XkbModel"	"microsoft"
# Then to change the language, change the Layout setting.
# For example, a german layout can be obtained with:
#	Option	"XkbLayout"	"de"
# or:
#	Option	"XkbVariant"	"nodeadkeys"
# If you'd like to switch the positions of your capslock and
# control keys, use:
#	Option	"XkbOptions"	"ctrl:swapcaps"
# Or if you just want both to be control, use:
#	Option	"XkbOptions"	"ctrl:nocaps"
	Identifier  "Keyboard0"
	Driver      "keyboard"
	Option	    "XkbRules" "xfree86"
	Option	    "XkbModel" "pc105"
	Option	    "XkbLayout" "ru,us"
	Option	    "XkbOptions" "grp:shift_toggle,grp_led:scroll"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "IMPS/2"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5"
	Option	    "Emulate3Buttons" "no"
EndSection
# If the normal CorePointer mouse is not a USB mouse then
# this input device can be used in AlwaysCore mode to let you
# also use USB mice at the same time.
	Identifier  "DevInputMice"
	Driver      "mouse"
EndSection
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "F700P"
	DisplaySize   330 	 250
	HorizSync     30 . 0  -  98 . 0
	VertRefresh   50 . 0  -  160 . 0
	Option	    "dpms"
EndSection
Section "Device"
	Identifier  "Videocard0"
	Driver      "vga"
	VendorName  "Videocard vendor"
	BoardName   "Rendition Verite 2x00"
	VideoRam     8192
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Videocard0"
	Monitor    "Monitor0"
	DefaultDepth      32
	SubSection "Display"
		Depth      16
		Modes    "1024x768" "800x600" "640x480"
	EndSubSection
EndSection
Section "DRI"
	Group         0
	Mode          0666
EndSection
Вот лог ошибок.
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
27.
28.
29.
30.
31.
32.
33.
34.
35.
36.
37.
38.
39.
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
51.
52.
53.
54.
55.
56.
57.
58.
59.
60.
61.
62.
63.
64.
65.
66.
67.
68.
69.
70.
71.
72.
73.
74.
75.
76.
77.
78.
79.
80.
81.
82.
83.
84.
85.
86.
87.
88.
89.
90.
91.
92.
93.
94.
95.
96.
97.
98.
99.
100.
101.
102.
103.
104.
105.
106.
107.
108.
109.
110.
111.
112.
113.
114.
115.
116.
117.
118.
119.
120.
121.
122.
123.
124.
125.
126.
127.
128.
129.
130.
131.
132.
133.
134.
135.
136.
137.
138.
139.
140.
141.
142.
143.
144.
145.
146.
147.
148.
149.
150.
151.
152.
153.
154.
155.
156.
157.
158.
159.
160.
161.
162.
163.
164.
165.
166.
167.
168.
169.
170.
171.
172.
173.
174.
175.
176.
177.
178.
179.
180.
181.
182.
183.
184.
185.
186.
187.
188.
189.
190.
191.
192.
193.
194.
195.
196.
197.
198.
199.
200.
201.
202.
203.
204.
205.
206.
207.
208.
209.
210.
211.
212.
213.
214.
215.
216.
217.
218.
219.
220.
221.
222.
223.
224.
225.
226.
227.
228.
229.
230.
231.
232.
233.
234.
235.
236.
237.
238.
239.
240.
241.
242.
243.
244.
245.
246.
247.
248.
249.
250.
251.
252.
253.
254.
255.
256.
257.
258.
259.
260.
261.
262.
263.
264.
265.
266.
267.
268.
269.
270.
271.
272.
273.
274.
275.
276.
277.
278.
279.
280.
281.
282.
283.
284.
285.
286.
287.
288.
289.
290.
291.
292.
293.
294.
295.
296.
297.
298.
299.
300.
301.
302.
303.
304.
305.
306.
307.
308.
309.
310.
311.
312.
XFree86 Version  4 . 3 . 0  (Red Hat Linux release:  4 . 3 . 0 - 2 )
Release Date:  27  February  2003
X Protocol Version  11 , Revision  0 , Release  6 . 6
Build Operating System: Linux  2 . 4 . 20 -3bigmem i686 [ELF]
Build Date:  27  February  2003
Build Host: porky.devel.redhat.com
	Before reporting problems, check http://www.XFree86.Org/
	to make sure that you have the latest version.
Module Loader present
OS Kernel: Linux version  2 . 4 . 20 - 8  (bhcompile@stripples.devel.redhat.com) (gcc version  3 . 2 . 2   20030222  (Red Hat Linux  3 . 2 . 2 - 5 )) # 1  Thu Mar  13   17 : 18 : 24  EST  2003
Markers: (--) probed, (**) from config file, (==) default setting,
         (++) from command line, (!!) notice, (II) informational,
         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.1.log", Time: Mon May   6   23 : 41 : 30   2002
(==) Using config file: "/etc/X11/XF86Config"
(==) ServerLayout "Default Layout"
(**) |-->Screen "Screen0" (0)
(**) |   |-->Monitor "Monitor0"
(**) |   |-->Device "Videocard0"
(**) |-->Input Device "Mouse0"
(**) |-->Input Device "Keyboard0"
(**) Option "XkbRules" "xfree86"
(**) XKB: rules: "xfree86"
(**) Option "XkbModel" "pc105"
(**) XKB: model: "pc105"
(**) Option "XkbLayout" "ru,us"
(**) XKB: layout: "ru,us"
(**) Option "XkbOptions" "grp:shift_toggle,grp_led:scroll"
(**) XKB: options: "grp:shift_toggle,grp_led:scroll"
(==) Keyboard: CustomKeycode disabled
(**) FontPath set to "unix/:7100"
(**) RgbPath set to "/usr/X11R6/lib/X11/rgb"
(==) ModulePath set to "/usr/X11R6/lib/modules"
(++) using VT number  7
(II) Open APM successful
(II) Module ABI versions:
	XFree86 ANSI C Emulation:  0 . 2
	XFree86 Video Driver:  0 . 6
	XFree86 XInput driver :  0 . 4
	XFree86 Server Extension :  0 . 2
	XFree86 Font Renderer :  0 . 4
(II) Loader running on linux
(II) LoadModule: "bitmap"
(II) Loading /usr/X11R6/lib/modules/fonts/libbitmap.a
(II) Module bitmap: vendor="The XFree86 Project"
	compiled for  4 . 3 . 0 , module version =  1 . 0 . 0
	Module class: XFree86 Font Renderer
	ABI class: XFree86 Font Renderer, version  0 . 4
(II) Loading font Bitmap
(II) LoadModule: "pcidata"
(II) Loading /usr/X11R6/lib/modules/libpcidata.a
(II) Module pcidata: vendor="The XFree86 Project"
	ABI class: XFree86 Video Driver, version  0 . 6
(II) PCI: Probing config type using method  1
(II) PCI: Config type is  1
(II) PCI: stages = 0x03, oldVal1 = 0x80003850, mode1Res1 = 0x80000000
(II) PCI: PCI scan (all values are in hex)
(II) PCI:  00 : 00 : 0 : chip  1106 , 0305  card  0000 , 0000  rev  03  class  06 , 00 , 00  hdr  00
(II) PCI:  00 : 01 : 0 : chip  1106 , 8305  card  0000 , 0000  rev  00  class  06 , 04 , 00  hdr  01
(II) PCI:  00 : 07 : 0 : chip  1106 , 0686  card  1106 , 0000  rev  40  class  06 , 01 , 00  hdr  80
(II) PCI:  00 : 07 : 1 : chip  1106 , 0571  card  0000 , 0000  rev  06  class  01 , 01 ,8a hdr  00
(II) PCI:  00 : 07 : 2 : chip  1106 , 3038  card  0925 , 1234  rev  16  class 0c, 03 , 00  hdr  00
(II) PCI:  00 : 07 : 3 : chip  1106 , 3038  card  0925 , 1234  rev  16  class 0c, 03 , 00  hdr  00
(II) PCI:  00 : 07 : 4 : chip  1106 , 3057  card  1106 , 3057  rev  40  class  06 , 80 , 00  hdr  00
(II) PCI:  00 : 07 : 5 : chip  1106 , 3058  card  1106 , 3058  rev  50  class  04 , 01 , 00  hdr  00
(II) PCI:  01 : 00 : 0 : chip  1163 , 2000  card  1163 , 2000  rev  06  class  03 , 00 , 00  hdr  00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus  0 : bridge is at ( 0 : 0 : 0 ), ( 0 , 0 , 1 ), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus  0  I/O range:
	[ 0 ] - 1 	 0 	0x00000000 - 0x0000ffff (0x10000) IX
(II) Bus  [b]0  non-prefetchable memory range:
	[ 0 ] - 1 	 0 	0x00000000 - 0xffffffff (0x0) MX
(II) Bus  [b]0  prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus  [b]1 : bridge is at ( 0 : 1 : 0 ), ( 0 , 1 , 1 ), BCTRL: 0x000c (VGA_EN is set)
(II) Bus  1  I/O range:
	[ 0 ] - 1 	 0 	0x0000c000 - 0x0000c0ff (0x100) IX
	[ [b]1 ] - 1 	 0 	0x0000c400 - 0x0000c4ff (0x100) IX
	[ [b]2 ] - 1 	 0 	0x0000c800 - 0x0000c8ff (0x100) IX
	[ [b]3 ] - 1 	 0 	0x0000cc00 - 0x0000ccff (0x100) IX
(II) Bus  [b]1  non-prefetchable memory range:
	[ 0 ] - 1 	 0 	0xe1000000 - 0xe2ffffff (0x2000000) MX
(II) Bus  [b]1  prefetchable memory range:
	[ 0 ] - 1 	 0 	0xe3000000 - 0xe3ffffff (0x1000000) MX
(II) PCI-to-ISA bridge:
(II) Bus - [b]1 : bridge is at ( 0 : 7 : 0 ), ( 0 ,- 1 ,- 1 ), BCTRL: 0x0008 (VGA_EN is set)
(--) PCI:*(1:0:0) Rendition Verite V2000/V2100/V2200 rev 6, Mem @ 0xe3000000/24, 0xe2000000/18, I/O @ 0xc000/8
(II) Addressable bus resource ranges are
	[ [b]1 ] - 1 	 0 	0x00000000 - 0x0000ffff (0x10000) IX
(II) OS-reported resource ranges:
	[ [b]0 ] - 1 	 0 	0xffe00000 - 0xffffffff (0x200000) MX(B)
	[ [b]1 ] - 1 	 0 	0x00100000 - 0x3fffffff (0x3ff00000) MXE(B)
	[ [b]2 ] - 1 	 0 	0x000f0000 - 0x000fffff (0x10000) MX
	[ [b]3 ] - 1 	 0 	0x000c0000 - 0x000effff (0x30000) MX
	[ [b]4 ] - 1 	 0 	0x00000000 - 0x0009ffff (0xa0000) MX
	[ [b]5 ] - 1 	 0 	0x0000ffff - 0x0000ffff (0x1) IX
	[ [b]6 ] - 1 	 0 	0x00000000 - 0x000000ff (0x100) IX
(II) PCI Memory resource overlap reduced 0xe0000000 from 0xe0ffffff to 0xdfffffff
(II) Active PCI resource ranges:
	[ [b]0 ] - 1 	 0 	0xe0000000 - 0xdfffffff (0x0) MXO
	[ [b]1 ] - 1 	 0 	0xe2000000 - 0xe203ffff (0x40000) MX(B)
	[ [b]2 ] - 1 	 0 	0xe3000000 - 0xe3ffffff (0x1000000) MX(B)
	[ [b]3 ] - 1 	 0 	0x0000e400 - 0x0000e403 (0x4) IX
	[ [b]4 ] - 1 	 0 	0x0000e000 - 0x0000e003 (0x4) IX
	[ [b]5 ] - 1 	 0 	0x0000dc00 - 0x0000dcff (0x100) IX
	[ [b]6 ] - 1 	 0 	0x0000d800 - 0x0000d81f (0x20) IX
	[ [b]7 ] - 1 	 0 	0x0000d400 - 0x0000d41f (0x20) IX
	[ [b]8 ] - 1 	 0 	0x0000d000 - 0x0000d00f (0x10) IX
	[ [b]9 ] - 1 	 0 	0x0000c000 - 0x0000c0ff (0x100) IX(B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
	[ [b]5 ] - 1 	 0 	0xe0000000 - 0xdfffffff (0x0) MXO
	[ [b]6 ] - 1 	 0 	0xe2000000 - 0xe203ffff (0x40000) MX(B)
	[ [b]7 ] - 1 	 0 	0xe3000000 - 0xe3ffffff (0x1000000) MX(B)
	[ [b]8 ] - 1 	 0 	0x0000ffff - 0x0000ffff (0x1) IX
	[ [b]9 ] - 1 	 0 	0x00000000 - 0x000000ff (0x100) IX
	[ [b]10 ] - 1 	 0 	0x0000e400 - 0x0000e403 (0x4) IX
	[ [b]11 ] - 1 	 0 	0x0000e000 - 0x0000e003 (0x4) IX
	[ [b]12 ] - 1 	 0 	0x0000dc00 - 0x0000dcff (0x100) IX
	[ [b]13 ] - 1 	 0 	0x0000d800 - 0x0000d81f (0x20) IX
	[ [b]14 ] - 1 	 0 	0x0000d400 - 0x0000d41f (0x20) IX
	[ [b]15 ] - 1 	 0 	0x0000d000 - 0x0000d00f (0x10) IX
	[ [b]16 ] - 1 	 0 	0x0000c000 - 0x0000c0ff (0x100) IX(B)
(II) LoadModule: "dbe"
(II) Loading /usr/X11R6/lib/modules/extensions/libdbe.a
(II) Module dbe: vendor="The XFree86 Project"
	compiled for  [b]4 . 3 . 0 , module version =  1 . 0 . 0
	Module class: XFree86 Server Extension
	ABI class: XFree86 Server Extension, version  0 . 2
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/X11R6/lib/modules/extensions/libextmod.a
(II) Module extmod: vendor="The XFree86 Project"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension FontCache
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "fbdevhw"
(II) Loading /usr/X11R6/lib/modules/linux/libfbdevhw.a
(II) Module fbdevhw: vendor="The XFree86 Project"
	compiled for  4 . 3 . 0 , module version =  0 . 0 . 2
(II) LoadModule: "glx"
(II) Loading /usr/X11R6/lib/modules/extensions/libglx.a
(II) Module glx: vendor="The XFree86 Project"
(II) Loading sub module "GLcore"
(II) LoadModule: "GLcore"
(II) Loading /usr/X11R6/lib/modules/extensions/libGLcore.a
(II) Module GLcore: vendor="The XFree86 Project"
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/X11R6/lib/modules/extensions/librecord.a
(II) Module record: vendor="The XFree86 Project"
	compiled for  4 . 3 . 0 , module version =  1 . 13 . 0
(II) Loading extension RECORD
(II) LoadModule: "freetype"
(II) Loading /usr/X11R6/lib/modules/fonts/libfreetype.a
(II) Module freetype: vendor="The XFree86 Project"
	compiled for  4 . 3 . 0 , module version =  2 . 0 . 2
(II) Loading font FreeType
(II) LoadModule: "type1"
(II) Loading /usr/X11R6/lib/modules/fonts/libtype1.a
(II) Module type1: vendor="The XFree86 Project"
	compiled for  4 . 3 . 0 , module version =  1 . 0 . 2
(II) Loading font Type1
(II) Loading font CID
(II) LoadModule: "dri"
(II) Loading /usr/X11R6/lib/modules/extensions/libdri.a
(II) Module dri: vendor="The XFree86 Project"
(II) Loading sub module "drm"
(II) LoadModule: "drm"
(II) Loading /usr/X11R6/lib/modules/linux/libdrm.a
(II) Module drm: vendor="The XFree86 Project"
(II) Loading extension XFree86-DRI
(II) LoadModule: "vga"
(II) Loading /usr/X11R6/lib/modules/drivers/vga_drv.o
(II) Module vga: vendor="The XFree86 Project"
	compiled for  4 . 3 . 0 , module version =  4 . 0 . 0
	Module class: XFree86 Video Driver
(II) LoadModule: "mouse"
(II) Loading /usr/X11R6/lib/modules/input/mouse_drv.o
(II) Module mouse: vendor="The XFree86 Project"
	Module class: XFree86 XInput Driver
	ABI class: XFree86 XInput driver, version  0 . 4
(II) VGA: Generic VGA driver (version  4 . 0 ) for chipsets: generic
(II) Primary Device is: PCI  01 : 00 : 0
(--) Assigning device section with no busID to primary device
(--) Chipset generic found
(II) resource ranges after xf86ClaimFixedResources() call:
	[ 0 ] - 1 	 0 	0xffe00000 - 0xffffffff (0x200000) MX(B)
(II) resource ranges after probing:
	[ [b]8 ]  0 	 0 	0x000a0000 - 0x000affff (0x10000) MS
	[ [b]9 ]  0 	 0 	0x000b0000 - 0x000b7fff (0x8000) MS
	[ [b]10 ]  0 	 0 	0x000b8000 - 0x000bffff (0x8000) MS
	[ [b]11 ] - 1 	 0 	0x0000ffff - 0x0000ffff (0x1) IX
	[ [b]12 ] - 1 	 0 	0x00000000 - 0x000000ff (0x100) IX
	[ [b]13 ] - 1 	 0 	0x0000e400 - 0x0000e403 (0x4) IX
	[ [b]14 ] - 1 	 0 	0x0000e000 - 0x0000e003 (0x4) IX
	[ [b]15 ] - 1 	 0 	0x0000dc00 - 0x0000dcff (0x100) IX
	[ [b]16 ] - 1 	 0 	0x0000d800 - 0x0000d81f (0x20) IX
	[ [b]17 ] - 1 	 0 	0x0000d400 - 0x0000d41f (0x20) IX
	[ [b]18 ] - 1 	 0 	0x0000d000 - 0x0000d00f (0x10) IX
	[ [b]19 ] - 1 	 0 	0x0000c000 - 0x0000c0ff (0x100) IX(B)
	[ [b]20 ]  0 	 0 	0x000003b0 - 0x000003bb (0xc) IS
	[ [b]21 ]  0 	 0 	0x000003c0 - 0x000003df (0x20) IS
(II) Setting vga for screen  [b]0 .
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/X11R6/lib/modules/linux/libint10.a
(II) Module int10: vendor="The XFree86 Project"
(II) VGA( 0 ): initializing int10.
(II) VGA( 0 ): Primary V_BIOS segment is: 0xc000
(EE) VGA( 0 ): No Display subsection in Screen section "Screen0" for depth/fbbpp  32 / 32
(II) UnloadModule: "vga"
(II) UnloadModule: "int10"
(II) Unloading /usr/X11R6/lib/modules/linux/libint10.a
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.1.log".
Please report problems to xfree86@xfree86.org.
Заранее благодарен.
Настройка видяшки
    #32867554
Somebody2
Код: plaintext
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Section "Screen"
	Device     "Videocard0"
	Monitor    "Monitor0"
	DefaultDepth      32
		Depth      16
	EndSubSection
EndSection
Код: plaintext
1.
Настройка видяшки
    #32867667
Колбаскин
Не понял. Что мне делать-то?
Настройка видяшки
    #32867740
Somebody2
КолбаскинНе понял. Что мне делать-то?
А так :
DefaultDepth 32
Depth 16
(EE) VGA(0): No Display subsection in Screen section "Screen0" for depth /fbbpp 32/32
Настройка видяшки
    #32870143
Колбаскин
Во дела! Поставил 16,16 - не работает, 32,32 - не работает.
Зато для 8 битного цвета заработала! Но вкаком режиме!! 320х240.
Это не то! Мне так не надо!
Линукс гуры! Спасайте!!
Настройка видяшки
    #32870217
blackrook
Ну Вам же ясно говорят:
Код: plaintext
Если у Вас DefaultDepth 32 то и SubSection "Display" создайте Depth 32
и Modes "1024 x 768" где х через пробелы, у меня, например, по-другому не работало
