smbmount
как под'mount'ить виндовый расшареный ресурс? Есть домен domain.com, в нем маша Test у которой расшарен для всех директорий shara Код: plaintext 1. пытается его найти и выдаетConnection to test@domain.com failed Код: plaintext 1. выдаетprotocol negotiation failed Код: plaintext 1. аналогичноprotocol negotiation failed что ната покрутить-подкрутить, что бы забегало? INFO: Current debug levels: all: True/10 tdb: False/0 printdrivers: False/0 lanman: False/0 smb: False/0 rpc_parse: False/0 rpc_srv: False/0 rpc_cli: False/0 passdb: False/0 sam: False/0 auth: False/0 winbind: False/0 vfs: False/0 idmap: False/0 quota: False/0 acls: False/0 doing parameter log file = /var/log/samba/%m.log doing parameter max log size = 50 doing parameter encrypt passwords = yes doing parameter smb passwd file = /etc/samba/smbpasswd doing parameter username map = /etc/samba/smbusers doing parameter socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192 doing parameter domain logons = yes doing parameter dns proxy = no doing parameter idmap uid = 16777216-33554431 doing parameter idmap gid = 16777216-33554431 doing parameter template shell = /bin/false doing parameter winbind use default domain = no pm_process() returned Yes lp_servicenumber: couldn't find homes set_server_role: role = ROLE_DOMAIN_PDC Attempting to register new charset UCS-2LE Registered charset UCS-2LE Attempting to register new charset UTF-16LE Registered charset UTF-16LE Attempting to register new charset UCS-2BE Registered charset UCS-2BE Attempting to register new charset UTF-16BE Registered charset UTF-16BE Attempting to register new charset UTF8 Registered charset UTF8 Attempting to register new charset UTF-8 Registered charset UTF-8 Attempting to register new charset ASCII Registered charset ASCII Attempting to register new charset 646 Registered charset 646 Attempting to register new charset ISO-8859-1 Registered charset ISO-8859-1 Attempting to register new charset UCS2-HEX Registered charset UCS2-HEX Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE Substituting charset 'UTF-8' for LOCALE opts: username=Administrator/domain.com%123456 opts: ip=192.168.0.3 opts: workgroup=domain.com mount.smbfs started (version 3.0.8pre1-0.pre1.3) added interface ip=62.244.14.18 bcast=62.244.14.19 nmask=255.255.255.252 added interface ip=192.168.0.8 bcast=192.168.0.255 nmask=255.255.255.0 Connecting to 192.168.0.3 at port 445 socket option SO_KEEPALIVE = 0 socket option SO_REUSEADDR = 0 socket option SO_BROADCAST = 0 socket option TCP_NODELAY = 1 socket option IPTOS_LOWDELAY = 0 socket option IPTOS_THROUGHPUT = 0 socket option SO_SNDBUF = 16384 socket option SO_RCVBUF = 16384 socket option SO_SNDLOWAT = 1 socket option SO_RCVLOWAT = 1 socket option SO_SNDTIMEO = 0 socket option SO_RCVTIMEO = 0 3135: session request ok write_socket(3,183) write_socket(3,183) wrote 183 got smb length of 99 size=99 smb_com=0x72 smb_rcls=0 smb_reh=0 smb_err=0 smb_flg=136 smb_flg2=49153 smb_tid=0 smb_pid=3135 smb_uid=0 smb_mid=1 smt_wct=17 smb_vwv[ 0]= 8 (0x8) smb_vwv[ 1]=12815 (0x320F) smb_vwv[ 2]= 256 (0x100) smb_vwv[ 3]= 1024 (0x400) smb_vwv[ 4]= 65 (0x41) smb_vwv[ 5]= 0 (0x0) smb_vwv[ 6]= 256 (0x100) smb_vwv[ 7]= 0 (0x0) smb_vwv[ 8]= 0 (0x0) smb_vwv[ 9]=64768 (0xFD00) smb_vwv[10]= 499 (0x1F3) smb_vwv[11]=24064 (0x5E00) smb_vwv[12]=33769 (0x83E9) smb_vwv[13]=45882 (0xB33A) smb_vwv[14]=50494 (0xC53E) smb_vwv[15]=19457 (0x4C01) smb_vwv[16]= 2303 (0x8FF) smb_bcc=30 [000] 8C 16 FB 47 37 19 EB AF 4C 00 45 00 41 00 44 00 ...G7... L.E.A.D. [010] 45 00 52 00 00 00 50 00 44 00 43 00 00 00 E.R...P. D.C... size=99 smb_com=0x72 smb_rcls=0 smb_reh=0 smb_err=0 smb_flg=136 smb_flg2=49153 smb_tid=0 smb_pid=3135 smb_uid=0 smb_mid=1 smt_wct=17 smb_vwv[ 0]= 8 (0x8) smb_vwv[ 1]=12815 (0x320F) smb_vwv[ 2]= 256 (0x100) smb_vwv[ 3]= 1024 (0x400) smb_vwv[ 4]= 65 (0x41) smb_vwv[ 5]= 0 (0x0) smb_vwv[ 6]= 256 (0x100) smb_vwv[ 7]= 0 (0x0) smb_vwv[ 8]= 0 (0x0) smb_vwv[ 9]=64768 (0xFD00) smb_vwv[10]= 499 (0x1F3) smb_vwv[11]=24064 (0x5E00) smb_vwv[12]=33769 (0x83E9) smb_vwv[13]=45882 (0xB33A) smb_vwv[14]=50494 (0xC53E) smb_vwv[15]=19457 (0x4C01) smb_vwv[16]= 2303 (0x8FF) smb_bcc=30 [000] 8C 16 FB 47 37 19 EB AF 4C 00 45 00 41 00 44 00 ...G7... L.E.A.D. [010] 45 00 52 00 00 00 50 00 44 00 43 00 00 00 E.R...P. D.C... Serverzone is -10800 cli_negprot: SMB signing is mandatory and we have disabled it. 3135: protocol negotiation failed P.S. Обратная операция - доступ с W2K к SAMBA осуществляется без проблем. _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 12.04.2005, 14:45:16 |
start [/forum/topic.php?desktop=1&fid=25&tid=1490745]: |
209ms |
| others: | 228ms |
| total: | 488ms |
