проблеммы с ATI драйверами (Radeon 9600PRO)
Проблема такова: Немерено глючит десктоп (графика)... такое ощущение что у меня видяха метров на 15... Про просмотр фильмов на весь экран я вобще молчу... (как пошаговая стратегия) хелп плиз. ATI RAdeon 9600PRO Драва от ATI (их с закрытым кодом) glxinfo name of display: :0.0 display: :0 screen: 0 direct rendering: No server glx vendor string: SGI server glx version string: 1.2 server glx extensions: GLX_ARB_multisample, GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGIS_multisample, GLX_SGIX_fbconfig client glx vendor string: ATI client glx version string: 1.3 client glx extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_ATI_pixel_format_float, GLX_ATI_render_texture GLX extensions: GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_ARB_multisample OpenGL vendor string: Mesa project: www.mesa3d.org OpenGL renderer string: Mesa GLX Indirect OpenGL version string: 1.2 (1.5 Mesa 6.2.1) OpenGL extensions: GL_ARB_imaging, GL_ARB_multitexture, GL_ARB_texture_border_clamp, GL_ARB_texture_cube_map, GL_ARB_texture_env_add, GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3, GL_ARB_transpose_matrix, GL_EXT_abgr, GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_texture_env_add, GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3, GL_EXT_texture_lod_bias glu version: 1.3 glu extensions: GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat ---------------------------------------------------------------------- 0x25 24 tc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 1 0 None 0x26 24 tc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 1 0 None 0x27 24 tc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x28 24 tc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x29 24 dc 0 24 0 r y . 8 8 8 0 0 16 0 0 0 0 0 1 0 None 0x2a 24 dc 0 24 0 r y . 8 8 8 0 0 16 8 16 16 16 0 1 0 None 0x2b 24 dc 0 32 0 r y . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x2c 24 dc 0 32 0 r . . 8 8 8 8 0 16 8 16 16 16 16 1 0 None 0x2d 8 pc 0 24 0 c y . 0 0 0 0 0 16 0 0 0 0 0 1 0 None 0x2e 8 gs 0 24 0 c y . 0 0 0 0 0 16 0 0 0 0 0 1 0 None как поставить апаратное ускорение? Вот только dmseg мне в конце вот такую штуку выдаёт... ... ACPI: PCI Interrupt Link [APC4] enabled at IRQ 19 ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [APC4] -> GSI 19 (level, high) -> IRQ 19 [fglrx:firegl_stub_register] *ERROR* Unable to the open some already present DRM kernel module! [fglrx] Maximum main memory to use for locked dma buffers: 678 MBytes. ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [APC4] -> GSI 19 (level, high) -> IRQ 19 [fglrx:firegl_stub_register] *ERROR* Unable to the open some already present DRM kernel module! xorg.conf ... # Graphics device section # ********************************************************************** # Any number of graphics device sections may be present # Standard VGA Device: Section "Device" Identifier "Standard VGA" VendorName "Unknown" BoardName "Unknown" # The chipset line is optional in most cases. It can be used to override # the driver's chipset detection, and should not normally be specified. # Chipset "generic" # The Driver line must be present. When using run-time loadable driver # modules, this line instructs the server to load the specified driver # module. Even when not using loadable driver modules, this line # indicates which driver should interpret the information in this section. Driver "vga" # The BusID line is used to specify which of possibly multiple devices # this section is intended for. When this line isn't present, a device # section can only match up with the primary video device. For PCI # devices a line like the following could be used. This line should not # normally be included unless there is more than one video device # installed. # BusID "PCI:0:10:0" # VideoRam 256 # Clocks 25.2 28.3 EndSection # === ATI device section === Section "Device" Identifier "ATI Graphics Adapter" Driver "fglrx" # ### generic DRI settings ### # === disable PnP Monitor === #Option "NoDDC" # === disable/enable XAA/DRI === Option "no_accel" "no" Option "no_dri" "no" # === misc DRI settings === Option "mtrr" "off" # disable DRI mtrr mapper, driver has its own code for mtrr # ### FireGL DDX driver module specific settings ### # === Screen Management === Option "DesktopSetup" "mirror" Option "HSync2" "unspecified" Option "VRefresh2" "unspecified" Option "ScreenOverlap" "0" # === TV-out Management === Option "TVFormat" "NTSC-M" Option "TVStandard" "VIDEO" Option "TVHSizeAdj" "0" Option "TVVSizeAdj" "0" Option "TVHPosAdj" "0" Option "TVVPosAdj" "0" Option "TVHStartAdj" "0" Option "TVColorAdj" "0" Option "GammaCorrectionI" "0x00000000" Option "GammaCorrectionII" "0x00000000" # === OpenGL specific profiles/settings === Option "Capabilities" "0x00000800" Option "CapabilitiesEx" "0x00000000" # === Video Overlay for the Xv extension === Option "VideoOverlay" "off" # === OpenGL Overlay === # Note: When OpenGL Overlay is enabled, Video Overlay # will be disabled automatically Option "OpenGLOverlay" "off" # === Center Mode (Laptops only) === Option "CenterMode" "off" # === Pseudo Color Visuals (8-bit visuals) === Option "PseudoColorVisuals" "on" # === QBS Management === Option "Stereo" "on" Option "StereoSyncEnable" "1" # === FSAA Management === Option "FSAAEnable" "yes" Option "FSAAScale" "6" Option "FSAADisableGamma" "no" Option "FSAACustomizeMSPos" "no" Option "FSAAMSPosX0" "0.000000" Option "FSAAMSPosY0" "0.000000" Option "FSAAMSPosX1" "0.000000" Option "FSAAMSPosY1" "0.000000" Option "FSAAMSPosX2" "0.000000" Option "FSAAMSPosY2" "0.000000" Option "FSAAMSPosX3" "0.000000" Option "FSAAMSPosY3" "0.000000" Option "FSAAMSPosX4" "0.000000" Option "FSAAMSPosY4" "0.000000" Option "FSAAMSPosX5" "0.000000" Option "FSAAMSPosY5" "0.000000" # === Misc Options === Option "UseFastTLS" "0" Option "BlockSignalsOnLock" "on" Option "UseInternalAGPGART" "yes" Option "ForceGenericCPU" "no" BusID "PCI:2:0:0" # vendor=1002, device=4150 Screen 0 EndSection .... ... |
| 13.12.2005, 22:09:31 |
Удивительно, дрова встали? :-0 А glx в Section module прописан? ... |
| 14.12.2005, 21:51:49 |
проблему решил/всё ок! ... |
| 14.12.2005, 23:37:03 |
start [/forum/topic.php?desktop=1&fid=25&tid=1489952]: |
62ms |
47ms |
| others: | 232ms |
| total: | 392ms |
