проблемы eth0 (Mandrake 10)
Realtek 8139 опознался (8139too) eth0 ifconfig eth0 Link encap:Ethernet HWaddr 00:E0:4C:FA:00:48 inet addr:192.168.251.67 Bcast:192.168.251.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:1758 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 b) TX bytes:0 (0.0 b) Interrupt:11 Base address:0x2f00 lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:75 errors:0 dropped:0 overruns:0 frame:0 TX packets:75 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:5516 (5.3 Kb) TX bytes:5516 (5.3 Kb) Код: plaintext 1. 2. 3. 4. 5. 6. ping localhost && свой host_name && свой IP проходит а вот ping на др. маши ping 192.168.251.40 PING 192.168.251.40 (192.168.251.40) 56(84) bytes of data. From 192.168.251.67 icmp_seq=1 Destination Host Unreachable From 192.168.251.67 icmp_seq=2 Destination Host Unreachable From 192.168.251.67 icmp_seq=3 Destination Host Unreachable From 192.168.251.67 icmp_seq=4 Destination Host Unreachable From 192.168.251.67 icmp_seq=5 Destination Host Unreachable From 192.168.251.67 icmp_seq=6 Destination Host Unreachable --- 192.168.251.40 ping statistics --- 9 packets transmitted, 0 received, +6 errors, 100% packet loss, time 7998ms , pipe 4 при этом traceroute 192.168.251.40 1 Linuxtest (192.168.251.67) 2998.679 ms !H 2999.251 ms !H 2999.491 ms !H почему-то кидается на себя же как на gateway при этом tcpdump -n -vv 09:07:28.205936 arp who-has 192.168.251.40 tell 192.168.251.67 09:07:29.205122 arp who-has 192.168.251.40 tell 192.168.251.67 09:07:30.204969 arp who-has 192.168.251.40 tell 192.168.251.67 а вообще tcpdump -n -vv tcpdump: listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes 08:56:09.671459 IP (tos 0x0, ttl 64, id 7, offset 0, flags [DF], length: 219) 192.168.251.67.138 > 192.168.251.255.138: >>> NBT UDP PACKET(138) Res=0x110A ID=0x5660 IP=192 (0xc0).168 (0xa8).251 (0xfb).67 (0x43) Port=138 (0x8a) Length=177 (0xb1) Res2=0x0 SourceName=LINUXTEST NameType=0x00 (Workstation) DestName= WARNING: Short packet. Try increasing the snap length 08:56:09.671473 IP (tos 0x0, ttl 64, id 20, offset 0, flags [DF], length: 96) 192.168.251.67.137 > 192.168.251.255.137: >>> NBT UDP PACKET(137): REGISTRATION; REQUEST; BROADCAST TrnID=0x5661 OpCode=5 NmFlags=0x11 Rcode=0 QueryCount=1 AnswerCount=0 AuthorityCount=0 AddressRecCount=1 QuestionRecords: Name=__MSBROWSE__ NameType=0x01 (Unknown) QuestionType=0x20 QuestionClass=0x1 ResourceRecords: Name=__MSBROWSE__ NameType=0x01 (Unknown) ResType=0x20 ResClass= WARNING: Short packet. Try increasing the snap length 08:59:56.129080 IP (tos 0x0, ttl 64, id 11, offset 0, flags [DF], length: 248) 192.168.251.67.138 > 192.168.251.255.138: >>> NBT UDP PACKET(138) Res=0x110A ID=0x5666 IP=192 (0xc0).168 (0xa8).251 (0xfb).67 (0x43) Port=138 (0x8a) Length=206 (0xce) Res2=0x0 SourceName=LINUXTEST NameType=0x00 (Workstation) DestName= WARNING: Short packet. Try increasing the snap length 08:59:56.129103 IP (tos 0x0, ttl 64, id 12, offset 0, flags [DF], length: 237) 192.168.251.67.138 > 192.168.251.255.138: >>> NBT UDP PACKET(138) Res=0x110A ID=0x5667 IP=192 (0xc0).168 (0xa8).251 (0xfb).67 (0x43) Port=138 (0x8a) Length=195 (0xc3) Res2=0x0 SourceName=LINUXTEST NameType=0x00 (Workstation) DestName= WARNING: Short packet. Try increasing the snap length Отсюда: 1. шо такое WARNING Short packet. Try increasing the snap length и насколько это критично? 2. Почему drop'аются пакеты? 3. Шо где ната подкрутить-докрутить шоб все заработало? TIA _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 30.06.2004, 12:17:52 |
А gateway пингуется? ... |
| 30.06.2004, 15:19:15 |
ниче внешнее не пингуется _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 30.06.2004, 15:46:52 |
Убери GW по умолчанию 3 строка в netstat ... |
| 07.07.2004, 21:59:41 |
Гы... А в другие сети как я ходить буду? Параллельно стоит W2K - настройки там аналогичные - все пашет. _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 07.07.2004, 22:38:51 |
BTW, если кому интерестно или есть желание помочь, более полную инфу можно глянуть на Linuxportal.ru или на www.mandrakeclub.com Правда на последнем топик грозились перенести из Install в Software _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 08.07.2004, 10:03:02 |
м.б. глюки из-за этого dmesg ... OEM ID: INTEL Product ID: I845G APIC at: 0xFEE00000 Unknown bustype I_PCI - ignoring Unknown bustype I_PCI - ignoring Unknown bustype I_PCI - ignoring Unknown bustype I_PCI - ignoring ... init IO_APIC IRQs IO-APIC (apicid-pin) 2-0, 2-5, 2-10, 2-11<3>unknown bus type 3. unknown bus type 0. unknown bus type 0. unknown bus type 0. , 2-20, 2-21, 2-22<3>unknown bus type 0. not connected. ... PCI: Using IRQ router PIIX/ICH [8086/24c0] at 0000:00:1f.0 PCI BIOS passed nonexistent PCI bus 0! PCI BIOS passed nonexistent PCI bus 0! PCI BIOS passed nonexistent PCI bus 0! PCI BIOS passed nonexistent PCI bus 0! PCI BIOS passed nonexistent PCI bus 0! PCI BIOS passed nonexistent PCI bus 0! PCI BIOS passed nonexistent PCI bus 0! PCI BIOS passed nonexistent PCI bus 0! PCI BIOS passed nonexistent PCI bus 3! PCI BIOS passed nonexistent PCI bus 0! ... ICH4: IDE controller at PCI slot 0000:00:1f.1 PCI BIOS passed nonexistent PCI bus 0! ICH4: chipset revision 1 ICH4: not 100% native mode: will probe irqs later ... ??? BTW, пробовал на Knoppix 3.3: теже яйца - тока в профиль. Причем при старте тоже выдает unknown bus type 0 (три раза). А вот Frenzy 0.2 - оБ _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 24.09.2004, 18:23:23 |
A у тебя случаем другой машинки с таким ip в сети нету? А то уж знакомая картина очень ... |
| 25.09.2004, 10:37:09 |
ХренA у тебя случаем другой машинки с таким ip в сети нету? Нет 100%-но. К тому же форточки и Frenzy 0.2 с теми же настройками фунциклируют... _________________ "Helo, word!" - 17 errors 56 warnings ... |
| 27.09.2004, 09:06:57 |
У мнея такая-же проблема. У же 2 недели потерял.... Кто-нибудь знает как??? помогите пожалуйста. ... |
| 06.01.2006, 13:47:47 |
новичок1У мнея такая-же проблема. У же 2 недели потерял.... Кто-нибудь знает как??? помогите пожалуйста. mii-tool запускать пробовали? Он так много говорит в одной только строке "eth0: no link" ... |
| 07.01.2006, 00:21:24 |
mii-tool: eth0: link OK !!! ((( Что теперь делать????? Эта же система в виндоуз все ОК ... |
| 07.01.2006, 15:23:17 |
iptables -L ??? ... |
| 07.01.2006, 18:48:43 |
Все очень просто !!!! и о чень непонятно!!! В BIOS Setup: boot rom - enabled ... |
| 08.01.2006, 02:33:59 |
start [/forum/topic.php?desktop=1&fid=25&tid=1489898]: |
45ms |
| others: | 198ms |
| total: | 299ms |
