Help me with kernel directory on SUSE LINUX ps!
System ask me: What is the location of the directory of C header files that match your running kernel? [/usr/src/linux/include] I'm: /usr/include System: The header files in /usr/include are generally for C libraries, not for the running kernel. If you do not have kernel header files in your /usr/src directory, you probably do not have the kernel-source package installed. Are you sure that /usr/include contains the header files associated with your running kernel? [no] I'm:yes System: The directory of kernel headers (version 2.6.5) does not match your running kernel (version 2.6.5-7.97-default). Even if the module were to compile successfully, it would not load into the running kernel. I don't no other directory Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ... |
| 08.02.2006, 06:57:40 |
install kernel src ... |
| 08.02.2006, 09:35:44 |
start [/forum/topic.php?desktop=1&fid=25&tid=1489805]: |
53ms |
35ms |
| others: | 227ms |
| total: | 351ms |
