vsftpd
OS ASPlinux v10 FTP: vsftpd Обслуживающая прога /usr/kerberos/sbin/ftpd Такая вот фигня случается [admin@gw ~]$ ftp 192.168.1.1 Connected to 192.168.1.1. 220 gw.home.com FTP server (Version 5.60) ready. 334 Using authentication type GSSAPI; ADAT must follow GSSAPI accepted as authentication type GSSAPI error major: Miscellaneous failure GSSAPI error minor: No credentials cache found GSSAPI error: initializing context GSSAPI authentication failed 334 Using authentication type KERBEROS_V4; ADAT must follow KERBEROS_V4 accepted as authentication type Kerberos V4 krb_mk_req failed: You have no tickets cached Name (192.168.1.1:admin): admin 530 Must perform authentication before identifying USER. Login failed. Remote system type is UNIX. Using binary mode to transfer files. ftp> bye 221 Goodbye. В тоже время дядя Anonymous разгуливает без проблем. В чем фишка не пойму. ... |
| 08.02.2006, 20:47:15 |
start [/forum/topic.php?desktop=1&fid=25&tid=1489793]: |
46ms |
23ms |
| others: | 199ms |
| total: | 294ms |
