как в 64-bit RHEL4 поставить 32-bit xorg-x11-deprecated-libs ?
не запускается оракловый инсталлер, требует 32-bit libXp.so.6, на металинке сказали стаить 32-бит xorg-x11-deprecated-libs, но он конфликтует с 64-bit, что же делать ?? # up2date -i xorg-x11-deprecated-libs --arch=i386 Fetching Obsoletes list for channel: rhel-x86_64-es-4... Fetching rpm headers... ######################################## Name Version Rel ---------------------------------------------------------- xorg-x11-deprecated-libs 6.8.2 1.EL.13.25.1 i386 Testing package set / solving RPM inter-dependencies... ######################################## RPM package conflict error. The message was: Test install failed because of package conflicts: The following packages were added to your selection to satisfy dependencies: Name Version Release -------------------------------------------------------------- xorg-x11-libs 6.8.2 1.EL.13.25.1 expat 1.95.7 4 fontconfig 2.2.3 7 freetype 2.1.9 1.rhel4.4 xorg-x11-Mesa-libGL 6.8.2 1.EL.13.25.1 zlib 1.2.1.2 1.2 file /usr/X11R6/lib/X11/locale/compose.dir from install of xorg-x11-libs-6.8.2-1.EL.13.25.1 conflicts with file from package xorg-x11-libs-6.8.1-23.EL file /usr/X11R6/lib/X11/locale/en_US.UTF-8/XLC_LOCALE from install of xorg-x11-libs-6.8.2-1.EL.13.25.1 conflicts with file from package xorg-x11-libs-6.8.1-23.EL file /usr/X11R6/lib/X11/locale/locale.alias from install of xorg-x11-libs-6.8.2-1.EL.13.25.1 conflicts with file from package xorg-x11-libs-6.8.1-23.EL file /usr/X11R6/lib/X11/locale/locale.dir from install of xorg-x11-libs-6.8.2-1.EL.13.25.1 conflicts with file from package xorg-x11-libs-6.8.1-23.EL ... |
| 25.07.2006, 13:07:24 |
rpm -e xorg-x11-deprecated-libs ... |
| 25.07.2006, 13:22:00 |
start [/forum/topic.php?desktop=1&fid=25&tid=1489253]: |
86ms |
30ms |
| others: | 227ms |
| total: | 385ms |
