Справочник по fstab.
man mount Опции, которые можно давать через -o в mount, указываются (при необходимости) в fstab. ... |
| 13.10.2006, 23:38:53 |
И вообще, в man fstab русским языком написано (специально проверил) ////cut//// It is formatted as a comma separated list of options. It contains at least the type of mount plus any additional options appropriate to the filesystem type. For documentation on the available options for non- nfs file systems, see mount(8). For documentation on all nfs-specific options have a look at nfs(5). Common for all types of file system are the options ‘‘noauto’’ (do not mount when "mount -a" is given, e.g., at boot time), ‘‘user’’ (allow a user to mount), and ‘‘owner’’ (allow device owner to mount), and ‘‘comment’’ (e.g., for use by fstab-main‐ taining programs). The ‘‘owner’’ and ‘‘comment’’ options are Linux- specific. For more details, see mount(8). ///cut//// ... |
| 13.10.2006, 23:41:51 |
start [/forum/topic.php?desktop=1&fid=25&tid=1488929]: |
54ms |
62ms |
| others: | 350ms |
| total: | 539ms |
