pop3 problema
u menya freebsd 6.1 i ustonovil postfix mail server no u menya pop3 ne startuyet ya dayu komandu (courier-imap-pop3d.sh start) otvechayet mne (Starting courier_imap_pop3d.) no ya dayu komandu s opciyey (status) (courier_imap_pop3d is not running.) dayot takuyu oshibku pomaqite rzabratsya ... |
| 08.11.2006, 11:57:09 |
pop3 problema
vot moyi nastroyki (# cat /usr/local/etc/courier-imap/pop3d PIDFILE=/var/run/pop3d.pid MAXDAEMONS=40 MAXPERIP=4 POP3AUTH="CRAM-MD5 PLAIN LOGIN CRAM-SHA1 CRAM-SHA256" POP3AUTH_ORIG="CRAM-MD5 PLAIN LOGIN CRAM-SHA1 CRAM-SHA256" POP3AUTH_TLS="" POP3AUTH_TLS_ORIG="" POP3_PROXY=0 PORT=110 ADDRESS=(zdes moya vneshnaya ip) TCPDOPTS="-nodnslookup -noidentlookup" LOGGEROPTS="-name=pop3d" POP3DSTART=YES MAILDIRPATH=Maildir ) kataloqa Maildir qde sozdavat? ... |
| 08.11.2006, 12:00:31 |
pop3 problema
В rc.conf прописал запуск couier-imap? ... |
| 08.11.2006, 12:51:33 |
pop3 problema
da v rc.conf dobavil vot moya rc.conf (mysql_enable="YES" courier_authdaemond_enable="YES" courier_imap_pop3d_enable="YES" sendmail_enable="NO" sendmail_submit_enable="NO" sendmail_outbound_enable="NO" sendmail_msp_queue_enable="NO" apache_enable="YES" ) ... |
| 08.11.2006, 13:23:23 |
pop3 problema
izvenite za qlupoy vapros qde xranitsya pop3 logi? ... |
| 09.11.2006, 12:34:13 |
pop3 problema
Смотри здесь /var/log/messages /var/log/debug /var/log/maillog ... |
| 09.11.2006, 17:47:39 |
pop3 problema
vot mayi logi (maillog) (Nov 10 10:03:20 mail authdaemond: modules="authmysql", daemons=5 Nov 10 10:03:20 mail authdaemond: Installing libauthmysql Nov 10 10:03:21 mail authdaemond: Installation complete: authmysql Nov 10 10:03:23 mail postfix/postfix-script: starting the Postfix mail system Nov 10 10:03:23 mail postfix/master[596]: daemon started -- version 2.2.9, configuration /usr/local/etc/postfix) ... |
| 10.11.2006, 08:11:20 |
pop3 problema
poprobaval takje telnetom [color=red ]( telnet localhost 110 Trying ::1... telnet: connect to address ::1: Connection refused Trying 127.0.0.1... Connected to localhost.domain.az. Escape character is '^]'. +OK Hello there. user alex@domain.az +OK Password required. pass 123321 -ERR chdir domain.az/alex@domain.az/ failed Connection closed by foreign host. ya proveryala no u menya [color=red ](/var/spool/mail/) vnutri etovo drektoriyi pusto kak mne ispravit eto? v cem problema? ... |
| 10.11.2006, 08:15:59 |
pop3 problema
me kajetsya cto postfixadmin ne sazdayot (/var/spool/mail/domain.az/alex@domain.az/) eti kataloqi mojet cto to postfix adminom nado delat? ... |
| 10.11.2006, 09:59:23 |
pop3 problema
авторme kajetsya cto postfixadmin ne sazdayot (/var/spool/mail/domain.az/alex@domain.az/) eti kataloqi mojet cto to postfix adminom nado delat? да, скорее всего у тебя просто нет этого каталога. Почему, смотри логи postfix при создании ящика с помощью postfixadmin. Вчера проверил, /usr/local/etc/rc.d/courier-imap-pop3d.sh status действительно всегда говорит, что courier-imap не запущен ... |
| 10.11.2006, 10:19:43 |
pop3 problema
v postfixadmin-a log pakazivayet cto mail est a kak mojna reshit etu problemu? ... |
| 10.11.2006, 11:29:48 |
pop3 problema
автор v postfixadmin-a log pakazivayet cto mail est a kak mojna reshit etu problemu? я ж написал в логе постфикса, а не постфиксадмина. Покажи лог. з.ы. Почему на русском не пишешь? Читать очень неудобно ... |
| 10.11.2006, 16:44:51 |
pop3 problema
ya kajetsya vse isportila dala chown -R virtual /var/spool kak eto ispravit? /var (drwxr-xr-x 11 virtual virtual 512 Nov 10 17:48 spool) /var/spool (drwxrwx--- 2 virtual virtual 512 Nov 7 18:56 clientmqueue drwxrwxr-x 2 virtual virtual 512 Nov 11 10:48 lock drwxr-xr-x 2 virtual virtual 512 May 7 2006 lpd drwxr-xr-x 2 virtual virtual 512 Nov 7 16:32 mail drwxr-xr-x 2 virtual virtual 512 May 7 2006 mqueue drwx------ 2 virtual virtual 512 May 7 2006 opielocks drwxr-xr-x 3 virtual virtual 512 Nov 6 13:45 output drwxr-xr-x 16 root wheel 512 Nov 7 15:41 postfix drwxr-xr-x 4 www www 512 Nov 10 17:48 squirrelmail) /var/spool/postfix (drwx------ 2 root wheel 512 Nov 11 10:48 active drwx------ 2 root wheel 512 Nov 7 15:41 bounce drwx------ 2 root wheel 512 Nov 7 15:41 corrupt drwx------ 3 root wheel 512 Nov 10 17:06 defer drwx------ 3 root wheel 512 Nov 10 17:06 deferred drwx------ 2 root wheel 512 Nov 10 17:06 flush drwx------ 2 root wheel 512 Nov 7 15:41 hold drwx------ 2 root wheel 512 Nov 11 10:48 incoming drwx-wx--- 2 root maildrop 512 Nov 7 15:41 maildrop drwxr-xr-x 2 root wheel 512 Nov 10 17:06 pid drwx------ 2 root wheel 512 Nov 11 10:48 private drwx--x--- 2 root maildrop 512 Nov 11 10:48 public drwx------ 2 root wheel 512 Nov 7 15:41 saved drwx------ 2 root wheel 512 Nov 7 15:41 trace) ... |
| 11.11.2006, 09:32:48 |
pop3 problema
pomaqite pojalusta ispravit etu oshibku ... |
| 11.11.2006, 09:34:30 |
pop3 problema
#postfix check #postsuper: fatal: scan_dir_push: open directory defer: Permission denied dayot takoye proshu esli smojete ya vam dam dostup k serveru vi pasmotrite v com tam dela? dayte email i ya vam otpravlyu user i password ... |
| 11.11.2006, 09:46:48 |
pop3 problema
авторproshu esli smojete ya vam dam dostup k serveru vi pasmotrite v com tam dela? dayte email i ya vam otpravlyu user i password icq - 282891476 email: sysadmin( at )akko.com.ua ... |
| 11.11.2006, 10:18:16 |
start [/forum/topic.php?desktop=1&fid=25&tid=1488830]: |
25ms |
77ms |
98ms |
| others: | 342ms |
| total: | 601ms |
