Не ставится firebird-client 2 на FreeBSD 6
Инсталирую через порты Выдает ошибку: Please do not build firebird as 'root' because this may cause conflicts with SysV semaphores of running services ... |
| 01.12.2006, 20:20:22 |
За что отвечают эти строки в MAKEFILE, можно ли их закоментировать .ifndef WITHOUT_IPC_CLEANUP pre-build: .ifndef PACKAGE_BUILDING @if [ `${ID} -u` -eq 0 ]; then \ ${ECHO_MSG} "==> Please do not build ${PORTNAME} as 'root' because this may cause conflicts with SysV semaphores of running services."; exit 1; fi .endif [ -f ${WRKDIR}/ipcs.pre.build ] || /usr/bin/ipcs -s | ${TAIL} -n +3 | \ ${GREP} -F `${ID} -un` | ${CAT} > ${WRKDIR}/ipcs.pre.build post-build: /usr/bin/ipcs -s | ${TAIL} -n +3 | ${GREP} -F `${ID} -un` | ${CAT} > ${WRKDIR}/ipcs.post.build /usr/bin/diff -n ${WRKDIR}/ipcs.pre.build ${WRKDIR}/ipcs.post.build | \ ${TAIL} -n +2 | ${SED} -E 's/^s +([0-9]+).*$$/\/usr\/bin\/ipcrm -s \1/' > ${WRKDIR}/ipcrm.sh ${SH} ${WRKDIR}/ipcrm.sh .endif ... |
| 01.12.2006, 22:11:46 |
start [/forum/topic.php?desktop=1&fid=25&tid=1488730]: |
23ms |
59ms |
47ms |
| others: | 365ms |
| total: | 539ms |
