Azureus TERMINATED
Дистрибутив Mandriva PowerPack 2007 Установил java после запска azureus наблюдаю следующее ./azureus Starting Azureus... Java exec not found in PATH, starting auto-search... Java exec found in /usr/java/jre1.5.0_09/bin/ Suitable java version found [/usr/java/jre1.5.0_09/bin/java = 1.5.0_09] Configuring environment... Loading Azureus: /usr/java/jre1.5.0_09/bin/java -Xms16m -Xmx128m -cp "/usr/sbin/azureus/Azureus2.jar:/usr/sbin/azureus/swt.jar" -Djava.library.path="/usr/sbin/azureus" -Dazureus.install.path="/usr/sbin/azureus" org.gudy.azureus2.ui.swt.Main '' Exception in thread "main" java.lang.NoClassDefFoundError: org/gudy/azureus2/ui/swt/Main Azureus TERMINATED. помогите разобраься... ... |
| 10.12.2006, 00:56:23 |
start [/forum/topic.php?desktop=1&fid=25&tid=1488704]: |
25ms |
69ms |
55ms |
| others: | 386ms |
| total: | 589ms |
