вопрос по IPMItool для rhel4
Добрый день всем! Прошу откликнуться тех кто работал с IPMItool. Локально работает, но не могу достучаться через сетевой интерфейс ======================================= Исходные данные: - серверная интеловская плата SE7520JR22S - Имеем RHEL4 update4 # yum -y install OpenIPMI-tools # modprobe ipmi_devintf # modprobe ipmi_si # ipmitool chassis power status Chassis Power is on # /usr/share/ipmitool/bmclanconf -c 1 -i eth0 Auto-configuring eth0 (channel 1) Setting LAN IP Address to 192.168.16.32 Setting LAN Subnet Mask to 255.255.255.0 Setting LAN MAC Address to 00:04:23:b3:59:1a Setting LAN Default Gateway IP to 192.168.16.177 Setting LAN Default Gateway MAC to 00:13:0a:bb:3c:45 Enabling BMC-generated Gratuitous ARPs BMC-generated Gratuitous ARP interval: 8.0 seconds Setting channel authentication capabilities Enabling channel 1 #ipmitool -I open lan print 1 Set in Progress : Set In Progress Auth Type Support : NONE MD2 MD5 PASSWORD Auth Type Enable : Callback : MD2 MD5 : User : MD2 MD5 : Operator : MD2 MD5 : Admin : MD2 MD5 : OEM : IP Address Source : Static Address IP Address : 192.168.16.32 Subnet Mask : 255.255.255.0 MAC Address : 00:04:23:b3:59:1a SNMP Community String : IP Header : TTL=0x40 Flags=0x40 Precedence=0x00 TOS=0x10 BMC ARP Control : ARP Responses Disabled, Gratuitous ARP Enabled Gratituous ARP Intrvl : 8.0 seconds Default Gateway IP : 192.168.16.177 Default Gateway MAC : 00:13:0a:bb:3c:45 Backup Gateway IP : 0.0.0.0 Backup Gateway MAC : 00:00:00:00:00:00 RMCP+ Cipher Suites : None Cipher Suite Priv Max : XXXXXXXXXXXXXXX : X=Cipher Suite Unused : c=CALLBACK : u=USER : o=OPERATOR : a=ADMIN : O=OEM #ipmitool -I open sol set set-in-progress set-complete 1 получился set complete #ipmitool -I open user set password 1 qwertyuiopasdfgh # ipmitool -I open user list 1 ID Name Callin Link Auth IPMI Msg Channel Priv Limit 1 true false true ADMINISTRATOR 2 root true false false NO ACCESS #ipmitool -I lan -H 192.168.16.32 -P qwertyuiopasdfgh chassis power status Activate Session command failed Error: Unable to establish LAN session ipmi_lan_send_cmd failed to open intf Unable to get Chassis Power Status =========================================== маки eth0 и bmc совпадают Как еще можно продиагностировать проблему? Спасибо, Александр ... |
| 02.02.2007, 09:05:35 |
...алгоритм шифрования указать ? у меня примерно так выглядит все это: Код: plaintext 1. причем если не сильно измудрятся с роутингом, то делать это надо с другой машины... ... |
| 02.02.2007, 09:48:26 |
пробовал с другой машины #ipmitool -I lan -A MD5 -H 192.168.16.33 -P 'qwertyuiopasdfgh' sdr list Error: Unable to establish LAN session ipmi_lan_send_cmd failed to open intf Get Device ID command failed Unable to open SDR for reading А у тебя какой дистрибутив линукса? ... |
| 02.02.2007, 10:30:06 |
CentOS 4.4, RedHat 7.3... ... |
| 02.02.2007, 10:32:17 |
...а адреса чего разные кстати ? ... |
| 02.02.2007, 10:35:50 |
start [/forum/topic.php?desktop=1&fid=25&tid=1488519]: |
31ms |
78ms |
26ms |
93ms |
| others: | 309ms |
| total: | 577ms |
