Configuration Assistants - Установка Oracle 10.2, Fedora 6
Устанавливаю Oracle 10g Release 2 (10.2) for Linux x86-64 на Fedora 6 в процессе установки во время запуска Configuration Assistants незапускаеться , в логах следующая ошибка : INFO: Starting to execute configuration assistants INFO: Command = /u01/app/oracle/product/10.1.0/asm/jdk/jre//bin/java -Duser.dir=/u01/app/oracle/product/10.1.0/asm/network/jlib -classpath /u01/app/oracle/product/10.1.0/asm/jdk/jre//lib/i18n.jar:/u01/app/oracle/product/10.1.0/asm/jdk/jre//lib/rt.jar:/u01/app/oracle/product/10.1.0/asm/jlib/ewt3.jar:/u01/app/oracle/product/10.1.0/asm/jlib/ewtcompat-3_3_15.jar:/u01/app/oracle/product/10.1.0/asm/jlib/netcfg.jar:/u01/app/oracle/product/10.1.0/asm/network/jlib/netcam.jar:/u01/app/oracle/product/10.1.0/asm/network/jlib/netca.jar:/u01/app/oracle/product/10.1.0/asm/jlib/help4.jar:/u01/app/oracle/product/10.1.0/asm/jlib/jewt4.jar:/u01/app/oracle/product/10.1.0/asm/jlib/oracle_ice.jar:/u01/app/oracle/product/10.1.0/asm/jlib/share.jar:/u01/app/oracle/product/10.1.0/asm/jlib/swingall-1_1_1.jar:/u01/app/oracle/product/10.1.0/asm/jlib/srvmhas.jar:/u01/app/oracle/product/10.1.0/asm/jlib/srvm.jar:/u01/app/oracle/product/10.1.0/asm/network/tools:/u01/app/oracle/product/10.1.0/asm/jlib/ldapjclnt9.jar:/u01/app/oracle/product/10.1.0/asm/jlib/ldapjclnt10.jar:/u01/app/oracle/product/10.1.0/asm/oui/jlib/OraInstaller.jar:/u01/app/oracle/product/10.1.0/asm/lib/xmlparserv2.jar oracle.net.ca.NetCA /orahome /u01/app/oracle/product/10.1.0/asm /orahnam OraDb10g_home1 /instype typical /inscomp client,oraclenet,javavm,server,ano /insprtcl tcp /cfg local /authadp NO_VALUE /nodeinfo NO_VALUE /responseFile /u01/app/oracle/product/10.1.0/asm/network/install/netca_typ.rsp Execution of the plugin was aborted INFO: Configuration assistant "Oracle Net Configuration Assistant" was canceled. ----------------------------------------------------------------------------- *** Starting OUICA *** Oracle Home set to /u01/app/oracle/product/10.1.0/asm Configuration directory is set to /u01/app/oracle/product/10.1.0/asm/cfgtoollogs. All xml files under the directory will be processed INFO: The "/u01/app/oracle/product/10.1.0/asm/cfgtoollogs/configToolFailedCommands" script contains all commands that failed, were skipped or were cancelled. This file may be used to run these configuration assistants outside of OUI. Note that you may have to update this script with passwords (if any) before executing the same. ----------------------------------------------------------------------------- SEVERE: OUI-25031:Some of the configuration assistants failed. It is strongly recommended that you retry the configuration assistants at this time. Not successfully running any "Recommended" assistants means your system will not be correctly configured. 1. Check the Details panel on the Configuration Assistant Screen to see the errors resulting in the failures. 2. Fix the errors causing these failures. 3. Select the failed assistants and click the 'Retry' button to retry them. INFO: User Selected: Yes/OK конфигурация системы : Intel S5000PSLSATA 2xXeon DC 2.0 / 1333 4 x1 GB DDR2 2 HDD (Raid 1) ... |
| 20.02.2007, 12:39:04 |
Ну так это же... Oracle Net Configuration Assistants.... слабо после установки отдельно запустить и сконфигурировать? PS Не сдержался: "не" с глаголами пишется отдельно ... http://surgutnet.ru Люди часто совершают старые ошибки, но при этом ссылаются на новые обстоятельствами. ... |
| 26.02.2007, 07:35:10 |
как его запустить ? ... |
| 27.02.2007, 10:44:33 |
эх... дети GUI....netca зайдите в $ORACLE_HOME/network/admin и напишитек в любом текстовом редакторе вашу конфигурацию.... http://surgutnet.ru Люди часто совершают старые ошибки, но при этом ссылаются на новые обстоятельствами. ... |
| 27.02.2007, 18:14:20 |
start [/forum/topic.php?desktop=1&fid=25&tid=1488417]: |
28ms |
47ms |
74ms |
| others: | 326ms |
| total: | 531ms |
