cygwin/putty for OUI
привет всем! пытаюсб запустить инстоллер через X session в cygwin, но ничего не получается. начну по порядку. открываю putty, набираю айпи, к которому хочу подрубиться, потом иду connection->ssh-x11, ставлю Галину, иду обратно в session, нажимаю сохранить/загрузить, вхожу в сервак, имя/пароль. потом иду в cygwin, typing: $ startx Welcome to the XWin X Server Vendor: The Cygwin/X Project Release: 6.8.99.901-4 Contact: cygwin-xfree@cygwin.com XWin was started with the following command line: X :0 -multiwindow -clipboard _XSERVTransmkdir: Owner of /tmp/.X11-unix should be set to root winValidateArgs - g_iNumScreens: 1 iMaxConsecutiveScreen: 1 (II) XF86Config is not supported (II) See http://x.cygwin.com/docs/faq/cygwin-x-faq.html for more information winDetectSupportedEngines - Windows NT/2000/XP winDetectSupportedEngines - DirectDraw installed winDetectSupportedEngines - DirectDraw4 installed winDetectSupportedEngines - Returning, supported engines 00000007 winSetEngine - Multi Window or Rootless => ShadowGDI winAdjustVideoModeShadowGDI - Using Windows display depth of 32 bits per pixel winAllocateFBShadowGDI - Creating DIB with width: 1280 height: 1024 depth: 32 winFinishScreenInitFB - Masks: 00ff0000 0000ff00 000000ff winInitVisualsShadowGDI - Masks 00ff0000 0000ff00 000000ff BPRGB 8 d 24 bpp 32 null screen fn ReparentWindow null screen fn RestackWindow InitQueue - Calling pthread_mutex_init InitQueue - pthread_mutex_init returned InitQueue - Calling pthread_cond_init InitQueue - pthread_cond_init returned winInitMultiWindowWM - Hello winInitMultiWindowWM - Calling pthread_mutex_lock () winMultiWindowXMsgProc - Hello winMultiWindowXMsgProc - Calling pthread_mutex_lock () MIT-SHM extension disabled due to lack of kernel support XFree86-Bigfont extension local-client optimization disabled due to lack of shar ed memory support in the kernel (--) Setting autorepeat to delay=500, rate=31 (--) winConfigKeyboard - Layout: "00000409" (00000409) (--) Using preset keyboard for "English (USA)" (409), type "4" Rules = "xorg" Model = "pc105" Layout = "us" Variant = "(null)" Options = "(null )" (--) 3 mouse buttons found Could not init font path element /usr/X11R6/lib/X11/fonts/CID/, removing from li st! winPointerWarpCursor - Discarding first warp: 640 512 winInitMultiWindowWM - pthread_mutex_lock () returned. winProcEstablishConnection - Hello winInitMultiWindowWM - pthread_mutex_unlock () returned. winMultiWindowXMsgProc - pthread_mutex_lock () returned. winInitMultiWindowWM - DISPLAY=127.0.0.1:0.0 winMultiWindowXMsgProc - pthread_mutex_unlock () returned. winMultiWindowXMsgProc - DISPLAY=127.0.0.1:0.0 cat: /cygdrive/h/.Xauthority: No such file or directory winInitClipboard () winClipboardProc - Hello DetectUnicodeSupport - Windows NT/2000/XP winProcEstablishConnection - winInitClipboard returned. winClipboardProc - DISPLAY=127.0.0.1:0.0 winInitMultiWindowWM - XOpenDisplay () returned and successfully opened the disp lay. winClipboardProc - XOpenDisplay () returned and successfully opened the display. winMultiWindowXMsgProc - XOpenDisplay () returned and successfully opened the di splay. winProcSetSelectionOwner - Clipboard not yet started, aborting. winProcSetSelectionOwner - Clipboard not yet started, aborting. и после этого открывается второе окно и большой Х появляется в трее. потом в putty я пишу: [oracle@ebisdb2 Disk1]$ sh runInstaller Starting Oracle Universal Installer... Checking installer requirements... Checking operating system version: must be redhat-2.1, redhat-3, redhat-4, SuSE-8, SuSE-9 or UnitedLinux-1.0 Passed All installer requirements met. Preparing to launch Oracle Universal Installer from /tmp/OraInstall2007-08-21_06-29-13PM. Please wait ... DISPLAY not set. Please set the DISPLAY and try again. Depending on the Unix Shell, you can use one of the following commands as examples to set the DISPLAY environment variable: - For csh: % setenv DISPLAY 192.168.1.128:0.0 - For sh, ksh and bash: $ DISPLAY=192.168.1.128:0.0; export DISPLAY Use the following command to see what shell is being used: echo $SHELL Use the following command to view the current DISPLAY environment variable setting: echo $DISPLAY - Make sure that client users are authorized to connect to the X Server. To enable client users to access the X Server, open an xterm, dtterm or xconsole as the user that started the session and type the following command: % xhost + To test that the DISPLAY environment variable is set correctly, run a X11 based program that comes with the native operating system such as 'xclock': % <full path to xclock.. see below> If you are not able to run xclock successfully, please refer to your PC-X Server or OS vendor for further assistance. Typical path for xclock: /usr/X11R6/bin/xclock [oracle@ebisdb2 Disk1]$ xhost + xhost: unable to open display "" [oracle@ebisdb2 Disk1]$ export DISPLAY=***.***.***.153:0.0 <- my local IP, on which Putty is [oracle@ebisdb2 Disk1]$ sh runInstaller Starting Oracle Universal Installer... Checking installer requirements... Checking operating system version: must be redhat-2.1, redhat-3, redhat-4, SuSE-8, SuSE-9 or UnitedLinux-1.0 Passed All installer requirements met. Preparing to launch Oracle Universal Installer from /tmp/OraInstall2007-08-21_06-31-55PM. Please wait ...[oracle@ebisdb2 Disk1]$ Oracle Universal Installer, Version 10.1.0.4.0 Production Copyright (C) 1999, 2005, Oracle. All rights reserved. Xlib: connection to "10.0.0.153:0.0" refused by server Xlib: No protocol specified Can't connect to X11 window server using '10.0.0.153:0.0' as the value of the DISPLAY variable. ***.***.***.153:0.0 ***.***.***.153:0.0 Unable to start an interactive install session because of the following error:Can't connect to X11 window server using '***.***.***.153:0.0' as the value of the DISPLAY variable. The DISPLAY environment variable should be set to <hostname or IP address>:<screen>, where the <screen> is usually '0.0'. Depending on the Unix Shell, you can use one of the following commands as examples to set the DISPLAY environment variable: - For csh: % setenv DISPLAY 192.168.1.128:0.0 - For sh, ksh and bash: $ DISPLAY=192.168.1.128:0.0; export DISPLAY Use the following command to see what shell is being used: echo $SHELL Use the following command to view the current DISPLAY environment variable setting: echo $DISPLAY - Make sure that client users are authorized to connect to the X Server. To enable client users to access the X Server, open an xterm, dtterm or xconsole as the user that started the session and type the following command: % xhost + To test that the DISPLAY environment variable is set correctly, run a X11 based program that comes with the native operating system such as 'xclock': % <full path to xclock... see below> If you are not able to run xclock successfully, please refer to your PC-X Server or OS vendor for further assistance. Typical path for 'xclock': '/usr/X11R6/bin/xclock' в cygwin тем временем вот такое появляется: AUDIT: Tue Aug 21 18:33:23 2007: 1708 X: client 6 rejected from IP ***.***.***.122 <- server IP, where the oracle will reside я уж что только не пробовала, и local ip, 172.0.0.1, localhost, b просто :0.0 и мониторы и :1, :0.1, :1 короче, все равинты, уже крышняк едетъ. помогите, пожалуйста. на этой тачке (с виндами, рабочей) ваервола нет, ничего нет. раньше работало - с другими серваками, теперь ни с одним не работает (я правда сносила cygwin и переустанавливала его не шибко гладко, долго-долго он вообще никакие пакеты не подгружал, комманды н понимал, но потом. наконец, встал, startx понимает, но gui не кажет. ) гуру, подскажите, где копать. заранее огромное спасибо, маша. ... |
| 22.08.2007, 03:00:15 |
хм... странно... а зачем делать startx на стороне сервера? я юзаю Exceed или X-Win на рабочей машине: 1) putty 2) запуск Exceed или X-Win в passive режиме 3) export DISPLAY= 4) пускаем gui все работает через ssh (никаких ssh->x11) ... |
| 22.08.2007, 10:54:03 |
[oracle@ebisdb2 Disk1]$ xhost + вот это надо писать у себя в Cygwine. Сможете ответить на вопрос "почему"? ... |
| 22.08.2007, 15:47:31 |
сварщик, СПАСИБО БОЛЬШОЕ!!!честно, я не знаю, почему надо запускать xhost на рабочей тачке, я жумала эта команда позволяет коннектиться к серваку с любого хоста, но все сработало! огромное спасибо. сделала xhost + в сигвине, ipconfig на рабочей тачке, export DISPLAY=winip:0.0 и все заработало. буду очень признательна, если проясните команду xhost именно в свете сигвина. всем спасибо еще раз за быструю и квалифицированную помосчь. маша ... |
| 22.08.2007, 17:44:28 |
marguren, А Вы того, не слишком оборзели? Мож сами попытаетесь разобраться? ... |
| 22.08.2007, 20:18:19 |
упс, да канеш, спасибо и так громадное. эт ваще-то одмин раньше все делал, просто он в отпуске счас, поэтому с линуксом теснее начинаю общаццо. до этого не приходилось. но я как только время найду, сразу пробью, просто работы до фига. спасибо, не надо ругаццо ... |
| 22.08.2007, 20:25:54 |
margurenупс, да канеш, спасибо и так громадное. эт ваще-то одмин раньше все делал, просто он в отпуске счас, поэтому с линуксом теснее начинаю общаццо. до этого не приходилось. но я как только время найду, сразу пробью, просто работы до фига. спасибо, не надо ругаццо Да в моих постах не капли эмоции. Пытаюсь Вас задеть, чтобы Вы начали немного читать/вникать/думать. Пока не получается ... |
| 22.08.2007, 21:57:08 |
дяденька, так я же ненастоящий сварщик :-) и зря вы думаете, что у вас не получается. еще как получается. я например нашла и осознала: http://www.soe.ucsc.edu/~you/notes/cygwin-install.html#mozTocId635485 авторWhen you say "login in a cse account" you probably are wondering how to use X11 forwarding so that you can view windows on your local (Cygwin) machine that is running its X11 server while executing the programs remotely on the remote Unix host. Normally you have to set up your DISPLAY environment variable so that the X client program (e.g. xterm/gv) knows which X11 server to use. You can use "export DISPLAY=my-windows-xp-hostname:0.0" if you use bash (or setenv if you use csh/tcsh). This can be a nuisance because you have to do this each time you log in on the cse machine. Also, you must set up your X11 server to enable remote hosts, so you say "xhost +" (all machines can open a window on your server) or if you're more paranoid you can use something like "xhost + someworkstation.cse.ucsc.edu". I don't think it is necessary to be so specific so I just use the "xhost +" form. When I work off campus I have to use ssh in order to connect to cse machines, so I use something like this: cygwin> xhost + cygwin> ssh -Y someworkstation.cse.ucsc.edu someworkstation> xterm & # this opens a window on cygwin's X11 server просто когда, например, только-только знакомишься с чем-то, иногда бывает трудно отвлечься (putty's configuration) и перейти на что-то другое (cygwin conf), без подсказки. еще раз спосибо за поддержание тонуса. ... |
| 22.08.2007, 22:51:55 |
margurenдяденька, так я же ненастоящий сварщик :-) Уже почти, главное не отступать! :) Я на самом деле думаю, что так полезнее, чем если бы я Вам в первом же посте в реверансах все разжевал, томно вздыхая над фоткой. ... |
| 22.08.2007, 23:06:51 |
ггг, я знала, знала, что мне она не поможет! ;-) да не, все правильно, не шучу. то, что я иной раз ищу shortcut - это чистая правда. и хорошо, что есть сварщики (про вторую часть умолчим тактично :-)))), которые не дают расслабляться. кроме шуток, спасибо! ... |
| 22.08.2007, 23:12:51 |
Автобиография понравилась. Мне симпатичны люди, могущие не плыть по течению. Респект :) Надеюсь, что слова Сыны о затыкании за пояс (не будем показывать пальцем, кого он имел ввиду) будут пророческими. :) Главное не лениться ... |
| 22.08.2007, 23:31:35 |
спасибо большое. биография, кстати, весьма тривиальная для эмигранта. все тут либо в программеры подались, либо в доктора. ну в самом деле, смешно мне было в стране, где реклама впитывается с молоком матери, лезьть со своим рылом в калашный ряд. а в дибиэйстве я вполне пока подвизаюсь. конечно, много есть гемора, типо: не знаю линуксовских команд, пока разгребу километровые маны, придет синиор и все сам сделает, или там, путь не тот в инстолляции укажу и придется все сначало... но все равно, мне оч. нравится. это на данный момент самое интересное из того, что доводилось делать. ... |
| 23.08.2007, 00:12:52 |
marguren25 лет, OCP с 2005-го. до этого занималась сетями margurenсварщик, ну и что? вы уже родились с ОСМ в зубах и никогда не учились? я только в марте сдала экзамен и только три месяца назад пошла на работу джуниором (о чем не раз тут писала). проглоченные 4 книги по 800 страниц и подготовка к 1z0-043 еще не значит, что я знаю все на свете и никогда не задам тупого вопроса. наоброт, я вот так вот здесь их задаю, на меня гуру орут, но я что-то понимаю :-) 2 Сварщик-гинеколог: никогда не верь женщинам. Это я тебе как женщина говорю ... |
| 01.09.2007, 23:45:35 |
DBA, стало обидна за всех несправедливо оскорбленных ОСР? :) ... |
| 03.09.2007, 08:58:39 |
Сварщик-гинекологDBA, стало обидна за всех несправедливо оскорбленных ОСР? :) нет, не стало :) ты умеешь не переходить границу между острыми шутками и грубым оскорблением. ... |
| 03.09.2007, 12:37:33 |
DВА Сварщик-гинекологDBA, стало обидна за всех несправедливо оскорбленных ОСР? :) нет, не стало :) ты умеешь не переходить границу между острыми шутками и грубым оскорблением. Посмотрим, изменится ли Ваше мнение, когда язва будет в Ваш адрес :) ... |
| 03.09.2007, 13:24:10 |
Сварщик-гинекологПосмотрим, изменится ли Ваше мнение, когда язва будет в Ваш адрес :) от то типа мало их было ... |
| 03.09.2007, 14:16:43 |
DBA, Вы меня с кем-то путаете. Я еще не имел этого удовольствия :) ... |
| 03.09.2007, 16:05:08 |
DBA, лано, лано. ОСА с 2005-го, ОЦП с 2007-го. ну выпендриться хотела, жалко? обязательно, вам как женщине, все белье наружу вытащить! :-( ... |
| 12.09.2007, 00:10:19 |
start [/forum/topic.php?desktop=1&fid=25&tid=1487755]: |
25ms |
47ms |
269ms |
| others: | 339ms |
| total: | 739ms |
