libclntsh.so is up to date
Здравствуйте! Подскажите, пожалуйста, что значит сообщение при компиляции программы? /export/home/ora92/app/oracle/9.2.0.1/lib/libclntsh.so is up to date КАК ПОБОРОТЬ?????????????????????????????????????????????????????? На SunOS 5.7 всё работало. Переношу на SunOS 5.8. Взял с $(НОМE_ORACLE)/network/lib/env_network.mk переименовал в env_precomp.mk make -f ./proc.mk OBJS=$1.o EXE=$1 2> err сам файл proc.mk include ./env_precomp.mk .SUFFIXES: .pc .c .o #EXE=$@ #OBJS=$@.o LDSTRING= PRODUCT_LIBHOME= MAKEFILE=proc.mk PROCFLAGS= sqlcheck=semantics userid=shema/pass dbms=native PROCPLSFLAGS= sqlcheck=semantics userid=$(USERID) dbms=v6_char # pp250 PROCPPFLAGS= sqlcheck=semantics code=cpp include=/usr/include include=/opt/SUNWspro/SC3.0.1/include/CC PROCPPFLAGS= sqlcheck=semantics code=cpp include=/usr/include include=/opt/SUNWspro/WS6U2/include/CC USERID=shema/pass INCLUDE=$(I_SYM). $(PRECOMPPUBLIC) CC=gcc SAMPLES= $2 sample1 sample2 sample3 sample4 sample6 sample7 sample8 \ sample9 sample10 sample11 sample12 oraca sqlvcp cv_demo CPPSAMPLES=cppdemo1 cppdemo2 cppdemo3 # Rule to compile any program (specify EXE= and OBJS= on command line) build: $(OBJS) $(CC) -o $(EXE) $(OBJS) -L$(LIBHOME) $(PROLDLIBS) cppbuild: $(PROC) $(PROCPPFLAGS) iname=$(EXE) CC -c $(INCLUDE) $(EXE).c CC -o $(EXE) $(OBJS) -L$(LIBHOME) $(PROLDLIBS) samples: $(SAMPLES) cppsamples: $(CPPSAMPLES) $(SAMPLES): $(MAKE) -f $(MAKEFILE) build OBJS=$@.o EXE=$@ $(CPPSAMPLES): $(MAKE) -f $(MAKEFILE) cppbuild OBJS=$@.o EXE=$@ sample5: @echo 'sample5 is a user-exit demo; use a forms makefile to build it.' .pc.c: $(PROC) $(PROCFLAGS) iname=$*.pc .pc.o: $(PROC) $(PROCFLAGS) iname=$*.pc $(CC) $(CFLAGS) -c $*.c .c.o: $(CC) $(CFLAGS) -c $*.c sample6.o: sample6.pc $(PROC) dbms=v6_char iname=$*.pc $(CC) $(CFLAGS) $(PRECOMPPUBLIC) -c $*.c sample9.o: sample9.pc calldemo-sql $(PROC) $(PROCPLSFLAGS) iname=$*.pc $(CC) $(CFLAGS) $(PRECOMPPUBLIC) -c $*.c cv_demo.o: cv_demo.pc cv_demo-sql $(PROC) $(PROCPLSFLAGS) iname=$*.pc $(CC) $(CFLAGS) $(PRECOMPPUBLIC) -c $*.c sample11.o: sample11.pc sample11-sql $(PROC) $(PROCPLSFLAGS) iname=$*.pc dbms=v6 $(CC) $(CFLAGS) $(PRECOMPPUBLIC) -c $*.c calldemo-sql: sqlplus scott/tiger @../sql/calldemo </dev/null sample11-sql: sqlplus scott/tiger @../sql/sample11 </dev/null cv_demo-sql: sqlplus scott/tiger @../sql/cv_demo </dev/null ... |
| 11.10.2007, 12:58:56 |
наверное, что не надо компилировать? удалить ее (переименовать временно) - и перекомпилировать ... |
| 11.10.2007, 19:09:43 |
вОПРОС НАФИГА ОН СОБРАЛСЯ ПЕРЕКОМПИЛИРОВАТЬ libclntsh.so Там где-то буг в этой портянке, ... |
| 11.10.2007, 19:21:46 |
да нет. Так и надо - компилится на клиент. Я уж не помню подробностей, но ето нормально ... |
| 11.10.2007, 23:51:38 |
start [/forum/topic.php?desktop=1&fid=25&tid=1487623]: |
67ms |
93ms |
| others: | 317ms |
| total: | 555ms |
