solaris, SVM, metadb...
было 2 диска, 7 слайс на каждом в котором лежали реплики и были софт партишины. второй диск вылетел, поменяли, пересоздали слайсы. вспомнили что забыли про реплики. и теперь: Код: plaintext 1. 2. ситуация с репликами сейчас: Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. 15. 16. 17. 18. 19. 20. Непонятна ошибка. либо реплику нужно создавать в первую очередь (как говорится by design) либо реплика пишется в строго определенное место раздела и d59 занял его. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. ... |
| 18.10.2007, 04:23:15 |
Metadevice State Database Conventions What is the size of a state database replica? By default, 517 Kbytes or 1034 disk blocks of a slice. Because your disk slices may not be that small, you may want to resize a slice to hold the state database replica. (See Solstice DiskSuite 4.2.1 User’s Guide for more information on resizing a slice.) What are the minimum number of state database replicas required? Three (3), preferably spread out across at least three disks (to avoid a single point-of-failure). DiskSuite does not operate with less than a majority. What are the maximum number of state database replicas possible? 50. Where are state database replicas created? You can create state database replicas on slices not in use. You cannot create state database replicas on existing file systems, root (/), /usr, and swap. If necessary, you can create a new slice (provided a slice name is available) by allocating space from swap and put state database replicas on that new slice. See Solstice DiskSuite 4.2.1 User’s Guide for more information. Can I create a state database replica on a slice that will be part of a metadevice? Yes, but you must create it before adding the slice to the metadevice. You can also create a state database replica on a logging device. DiskSuite reserves the starting part of the slice for the state database replica. Can I place more than one state database replica on a single disk drive? In general, it is best to distribute state database replicas across slices, drives, and controllers, to avoid single points-of-failure. If you have two disks, create two state database replicas on each disk. What happens if a slice that contains a state database replica becomes errored? The rest of your configuration should remain in operation. DiskSuite finds a good state database (as long as there are at least half + 1 valid state database replicas). What happens when state database replicas are repaired? When you manually repair or enable state database replicas, DiskSuite updates them with valid data. ... |
| 18.10.2007, 12:01:02 |
start [/forum/topic.php?desktop=1&fid=25&tid=1487599]: |
25ms |
42ms |
73ms |
| others: | 361ms |
| total: | 560ms |
