Помогите настроить интернет через VPN на FreeBSD 7.0
Хочю подсоеденить freeBSD к нету и сделать через него доступ в интернет с внутренней сети помогите настроить vpn Скомпилить ядро: [code]options IPFIREWALL options IPFIREWALL_VERBOSE options IPFIREWALL_VERBOSE_LIMIT=100 options IPFIREWALL_DEFAULT_TO_ACCEPT options DUMMYNET прописал в rc.conf natd_enable="YES" natd_interface="rl0" natd_flags="-same_ports yes -use_sockets yes" вписал в mpd.conf startup: set global disable tcp-wrapper default: load vpn vpn: new -i ng0 vpn vpn set iface disable on-demand set iface idle 0 set bundle disable multilink set auth authname "логин set auth password "пароль" set link yes acfcomp protocomp set link mtu 1500 set link disable chap pap set link accept chap pap set link enable no-orig-auth set link keep-alive 10 75 set link bandwidth 1048576 set ipcp yes vjcomp set ipcp yes req-pri-dns set ipcp yes req-sec-dns set ipcp ranges 0.0.0.0/0.0.0.0/0 set bundle enable compression вписал в mpd.links vpn: set link type pptp set pptp peer 172.25.255.1 set pptp self 172.25.18.109 set pptp enable originate set pptp enable originate incoming outcall это всё что сделал запускаю mpd а оно мне пишет: #mpd -k Multi-link PPP for FreeBSD, by Archie L. Cobbs. Based on iij-ppp, by Toshiharu OHNO. mpd: pid 1016, version 3.18 (root@freebsd.org 15:30 22-Dec-2007) [vpn] can't create socket node: Invalid argument mpd: local IP address for PPTP is 172.25.18.109 [vpn] using interface set auth: unknown command. Try "help". set auth: unknown command. Try "help". Usage: set ipcp ranges self/width peer/width [vpn] IFACE: Open event [vpn] IPCP: Open event [vpn] IPCP: state change Initial --> Starting [vpn] IPCP: LayerStart [vpn:vpn] [vpn] bundle: OPEN event in state CLOSED [vpn] opening link "vpn"... [vpn] link: OPEN event [vpn] LCP: Open event [vpn] LCP: state change Initial --> Starting [vpn] LCP: LayerStart [vpn] device: OPEN event in state DOWN pptp0: connecting to 172.25.255.1:1723 [vpn] device is now in state OPENING pptp0: connected to 172.25.255.1:1723 pptp0: attached to connection with 172.25.255.1:1723 pptp0-0: outgoing call connected at 64000 bps [vpn] PPTP call successful [vpn] can't attach pptpgre node: Bad file descriptor pptp0-0: clearing call [vpn] can't shutdown "bypass.link0": Bad file descriptor [vpn] device: DOWN event in state OPENING [vpn] device is now in state DOWN [vpn] link: DOWN event [vpn] LCP: Down event [vpn] can't get stats, link=0: Bad file descriptor [vpn] device: OPEN event in state DOWN [vpn] pausing 9 seconds before open [vpn] device is now in state DOWN pptp0: ctrl connection closed by peer pptp0: killing connection with 172.25.255.1:1723 pptp0-0: killing channel это мои данные для настройки 172.25.18.109 мой ip в локальной сети провайдера 255.255.255.0 маска 172.25.255.10 днс 172.25.18.1 шлюз 172.25.255.1 vpn 192.168.0.1 ip адрес втророй сетевой карты для внутренней сети на команду ifconfig пишет: rl0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 00:80:48:53:b7:35 inet6 fe80::280:48ff:fe53:b735%rl0 prefixlen 64 scopeid 0x1 inet 172.25.18.109 netmask 0xffffff00 broadcast 172.25.18.255 media: Ethernet autoselect (100baseTX <full-duplex>) status: active rl1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 00:02:44:86:13:82 inet6 fe80::202:44ff:fe86:1382%rl1 prefixlen 64 scopeid 0x2 inet 192.168.0.1 netmask 0xffffff00 broadcast 192.168.0.255 media: Ethernet autoselect (10baseT/UTP) status: active plip0: flags=108810<POINTOPOINT,SIMPLEX,MULTICAST,NEEDSGIANT> metric 0 mtu 1500 lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 inet6 ::1 prefixlen 128 inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4 inet 127.0.0.1 netmask 0xff000000 где ошибка?? помогите плиз 2 дня долблюсь я новичёк так что сильно не ругайте Заранее спасибо! ... |
| 22.02.2008, 13:53:40 |
RamzesII set auth: unknown command. Try "help". set auth: unknown command. Try "help". меня смущает вот это кто знает как это исправить ... |
| 22.02.2008, 14:38:04 |
версия mpd 3.18 тут правильно заполнено ?? авторset auth authname "логин set auth password "пароль" ... |
| 22.02.2008, 16:04:03 |
авторверсия mpd 3.18 А что мешает исп-ть 4.х? Она вроде как намного лучше автортут правильно заполнено ?? потому что вам надо использовать что то типа - set bundle authname "mylogin1" авторменя смущает вот это кто знает как это исправить а это не смущает - [vpn] can't create socket node: Invalid argument ? ;) Короче читай доку до полного просветления - /usr/local/share/doc/mpd.html ... |
| 22.02.2008, 20:34:48 |
start [/forum/topic.php?desktop=1&fid=25&tid=1487117]: |
45ms |
58ms |
| others: | 308ms |
| total: | 475ms |
