samba + ad не работает getent passwd BusyBox v1.00-rc2
samba Version 3.0.26 К домену оно подцепляется так работает # net ads user -Uden|wc -l den's password: 65 а так # getent passwd долго думает и выдает только локальных пользователей # cat /usr/local/samba/var/log.winbindd-idmap [2008/03/18 17:28:12, 1] nsswitch/idmap.c:idmap_init(343) Initializing idmap domains # cat /usr/local/samba/var/log.winbindd-dc-connect [2008/03/18 17:41:36, 1] libads/cldap.c:recv_cldap_netlogon(219) no reply received to cldap netlogon [2008/03/18 17:41:36, 1] libads/cldap.c:recv_cldap_netlogon(219) no reply received to cldap netlogon [2008/03/18 17:41:37, 1] libads/cldap.c:recv_cldap_netlogon(219) no reply received to cldap netlogon [2008/03/18 17:41:39, 1] libads/cldap.c:recv_cldap_netlogon(219) no reply received to cldap netlogon [2008/03/18 17:41:43, 1] libads/cldap.c:recv_cldap_netlogon(219) no reply received to cldap netlogon [2008/03/18 17:41:44, 1] libads/cldap.c:recv_cldap_netlogon(219) no reply received to cldap netlogon [2008/03/18 17:41:46, 1] libads/cldap.c:recv_cldap_netlogon(219) no reply received to cldap netlogon [2008/03/18 17:46:38, 1] libsmb/clientgen.c:cli_rpc_pipe_close(387) cli_rpc_pipe_close: cli_close failed on pipe \lsarpc, fnum 0x4028 to machine dc.dit.sgb.rus. Error was SUCCESS - 0 [2008/03/18 17:46:38, 1] libsmb/clientgen.c:cli_rpc_pipe_close(387) cli_rpc_pipe_close: cli_close failed on pipe \NETLOGON, fnum 0x4038 to machine dc.dit.sgb.rus. Error was SUCCESS - 0 [2008/03/18 17:46:45, 1] libads/cldap.c:recv_cldap_netlogon(219) no reply received to cldap netlogon ... |
| 18.03.2008, 17:54:10 |
Я прошу прощения, а в nsswitch.conf winbind прописан? а wbinfo -u что говорит? ... |
| 18.03.2008, 22:07:19 |
Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. 14. Утилиты wbinfo нет, или уже нет. Железка не обычный комп, это nas стартующий с флешки. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. ... |
| 19.03.2008, 09:31:15 |
Когда конекчусь телнетом тоже странные паузы, что-то нето с пам? ... |
| 19.03.2008, 09:36:07 |
А net ads join -U ... - давал или нет Все что ты показывал, это авторизация человека на консоли в ADS, а не самого компьютера в ADS ... |
| 19.03.2008, 17:27:05 |
Я прошу прощения, а klist чего дает? ... |
| 19.03.2008, 17:57:26 |
Sergey OrlovА net ads join -U ... - давал или нет Все что ты показывал, это авторизация человека на консоли в ADS, а не самого компьютера в ADSДа join успешно проходит. ... |
| 20.03.2008, 08:21:29 |
stepanov_vvЯ прошу прощения, а klist чего дает?В смысле net cache list ? Показывает кучу ключей, развесистое дерево доменов. Код: plaintext 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. ... |
| 20.03.2008, 08:27:23 |
Рассогласование времени с контроллером домена не должно быть больше 5-и минут, я бы еще в hosts на самом верху прописал домен-контроллер. Мне не понятна строчка в nsswitch.conf на тему hosts, winbind из не убрал или же поставил в конец. а если на консоли дать kinit -p ..., а потом посмотреть klist, что дает... ... |
| 20.03.2008, 09:25:35 |
Sergey OrlovРассогласование времени с контроллером домена не должно быть больше 5-и минут, я бы еще в hosts на самом верху прописал домен-контроллер. Мне не понятна строчка в nsswitch.conf на тему hosts, winbind из не убрал или же поставил в конец. а если на консоли дать kinit -p ..., а потом посмотреть klist, что дает... рассогласования времени нет. Попробовал поставил в конец, передернул сервисы, изменений никаких. Адрес контроллера из днс получает влет. # net cache flush # getent passwd .... локальные пользователи # net cache list|grep DIT\.SGB Key: NBT/DC.DIT.SGB.RUS#20 Timeout: 09:50:28 Value: 192.168.5.220:0 Key: AD_SITENAME/DOMAIN/DIT.SGB.RUS Timeout: Tue Jan 19 06:14:07 2038 Value: Cherepovets-DIT Key: SAF/DOMAIN/DIT.SGB.RUS Timeout: 09:55:43 Value: 192.168.5.220 Вторая строчка Timeout: -- Это что-нибудь значит? Прописал контроллер в хостс, не помогло. ... |
| 20.03.2008, 09:47:38 |
хехе Код: plaintext 1. 2. ничо не понимаю ... |
| 20.03.2008, 10:24:57 |
Журавлев ДенисDIT\den:*:10011:10005:Журавлев Д.С.:/home/DIT/den:/bin/falseНет, только на меня работает, я логинился, остальных не выдает. ... |
| 20.03.2008, 10:45:39 |
После рестарта /etc/init.d/domain stop&&/etc/init.d/domain start работает # getent passwd "DIT\allen" allen:*:10000:10005:Титов А.Ю.:/home/DIT/allen:/bin/false # getent passwd "DIT\den" den:*:10011:10005:Журавлев Д.С.:/home/DIT/den:/bin/false Но getent passwd все тоже самое виснет. ... |
| 20.03.2008, 12:58:29 |
start [/forum/topic.php?desktop=1&fid=25&tid=1487049]: |
23ms |
50ms |
68ms |
| others: | 306ms |
| total: | 497ms |
