Suse 10.2 cron
Имеем: SuSE 10.1 Код: plaintext 1. Код: plaintext З.Ы. Прошу сильно не пинать, сам скорее dba.(Linux нужен как платформа для Oracle). ... |
| 15.05.2008, 09:56:01 |
Suse 10.2 cron
man 5 crontab Note: The day of a command's execution can be specified by two fields -- day of month, and day of week. If both fields are restricted (ie, aren't *), the command will be run when either field matches the cur- rent time. For example, ``30 4 1,15 * 5'' would cause a command to be run at 4:30 am on the 1st and 15th of each month, plus every Friday. т.е. одновременное задание условий "день недели" и "число месяца" проверяются как ИЛИ. ... |
| 15.05.2008, 10:19:42 |
Suse 10.2 cron
Serik Akhmetov man 5 crontab Note: The day of a command's execution can be specified by two fields -- day of month, and day of week. If both fields are restricted (ie, aren't *), the command will be run when either field matches the cur- rent time. For example, ``30 4 1,15 * 5'' would cause a command to be run at 4:30 am on the 1st and 15th of each month, plus every Friday. т.е. одновременное задание условий "день недели" и "число месяца" проверяются как ИЛИ. Понятно -сенкс. ... |
| 15.05.2008, 10:54:56 |
start [/forum/topic.php?desktop=1&fid=25&tid=1486912]: |
25ms |
53ms |
68ms |
| others: | 306ms |
| total: | 512ms |
