redirect standard output of fuser command.
Please help. I need to check whether exist processes using files in certain directory. Normaly you can do it with fuser <dir>/*. I need to check this in if clause in a shall script. I need a construct looks like: if [ (fuser /var/opt/dir/*) ] but th output of fuser is never empty even than no processes using files: ... |
| 10.07.2008, 14:30:30 |
start [/forum/topic.php?desktop=1&fid=25&tid=1486737]: |
23ms |
46ms |
43ms |
| others: | 323ms |
| total: | 482ms |
