mpd5 проблема
Установил МПД и PPPOE server настроиль стартуется отлично Но когда клиент коннект делает PADI запросы к серверу идет но ответ PADO нету вот мои конф файлы /etc/rc.conf ifconfig_rl0="inet 192.168.11.239 netmask 255.255.255.0" defaultrouter="192.168.11.229" hostname="raduis.rabita.az" ifconfig_vr0="inet 10.0.0.1 netmask 255.255.255.0" sshd_enable="YES" inetd_enable="YES" apache2_enable="YES" mysql_enable="YES" mpd_enable="YES" mpd_flags="-b" radiusd_enable="YES" natd_enable="YES" natd_interface="vr0" firewall_enable="YES" firewall_type="OPEN" gateway_enable="YES" /usr/local/etc/mpd5/mpd.conf startup: set user camal freebsd admin set user eldar freebsd set console self 127.0.0.1 5005 set console open set web self 192.168.11.239 5006 set web open default: load pppoe_server pppoe_server: create bundle template B # Set IP addresses. Peer address will be later replaced by RADIUS. set ipcp ranges 10.0.0.1/32 127.0.0.2/32 set ipcp dns 192.168.11.136 192.168.11.166 create link template common pppoe set link enable multilink set link action bundle B set link disable chap pap eap set link enable pap chap load radius set pppoe service "superisp" create link template vr0 common set link max-children 1000 set pppoe iface vr0 set link enable incoming create link template vr1 common set link max-children 500 set pppoe iface vr0 set link enable incoming #radius: # set radius config /usr/local/etc/raddb/radius.conf # set radius server localhost freebsd 1812 1813 # set radius retries 3 # set radius timeout 3 # set radius me 10.0.0.1 # set auth acct-update 300 # set auth enable radius-auth # set auth enable radius-acct # set radius enable message-authentic /usr/local/etc/mpd5/mpd.secret MyLogin MyPassword PeerLogin PeerPassword test test 10.0.0.2 fred "fred-pw" joe "foobar" 192.168.1.1 bob "\x34\"foo\n" 192.168.1.10/24 sal "yipee" 192.168.1.254 Ядро установлен с етими опциями options HZ=1000 options NETGRAPH options NETGRAPH_PPPOE options NETGRAPH_SOCKET options NETGRAPH_CISCO options NETGRAPH_ECHO options NETGRAPH_FRAME_RELAY options NETGRAPH_HOLE options NETGRAPH_KSOCKET options NETGRAPH_LMI options NETGRAPH_RFC1490 options NETGRAPH_TTY options NETGRAPH_ASYNC options NETGRAPH_BPF options NETGRAPH_ETHER options NETGRAPH_IFACE options NETGRAPH_KSOCKET options NETGRAPH_L2TP options NETGRAPH_MPPC_ENCRYPTION options NETGRAPH_PPP options NETGRAPH_PPTPGRE options NETGRAPH_TEE options NETGRAPH_UI options NETGRAPH_VJC В чем же проблема ? На заранее огромное спосибо ... |
| 22.05.2009, 20:07:31 |
mpd5 проблема
Неужели никто не знает про MPD5? ... |
| 23.05.2009, 22:34:44 |
mpd5 проблема
QabrielНеужели никто не знает про MPD5? давно это было и неправда ))) думаю дорога тебе на форум к лисяре ... |
| 24.05.2009, 12:12:29 |
mpd5 проблема
Какой пут я уже на русском все сайты про mpd прочитал а шас прошел на English lissyaya.su я уже прочитал там только mpd c PPTP a PPPoE нету там ... |
| 24.05.2009, 22:56:39 |
start [/forum/topic.php?desktop=1&fid=25&tid=1485798]: |
35ms |
48ms |
| others: | 302ms |
| total: | 443ms |
