linux wifi
после обновления ubuntu c 9-04 до 9-10 появилась проблема с интернетом работает в течении полминуты - минуты и потом disconnect , проходит секунд 5 и появляется снова и так бесконечно . daemon.log пишет следующее вопрос в чем причина и как пофиксить? Mar 7 19:22:16 wpa_supplicant[945]: CTRL-EVENT-SCAN-RESULTS Mar 7 19:22:16 wpa_supplicant[6837]: Trying to associate with 00:21:91:35:83:8b (SSID='dlink' freq=2437 MHz) Mar 7 19:22:16 wpa_supplicant[945]: WPS-AP-AVAILABLE Mar 7 19:22:16 wpa_supplicant[6837]: Association request to the driver failed Mar 7 19:22:16 wpa_supplicant[945]: Trying to associate with 00:21:91:35:83:8b (SSID='dlink' freq=2437 MHz) Mar 7 19:22:16 wpa_supplicant[945]: Association request to the driver failed Mar 7 19:22:16 NetworkManager: <info> (wlan0): supplicant connection state: scanning -> associating Mar 7 19:22:16 wpa_supplicant[6837]: WPA: EAPOL-Key Replay Counter did not increase - dropping packet Mar 7 19:22:16 wpa_supplicant[6837]: Associated with 00:21:91:35:83:8b Mar 7 19:22:16 NetworkManager: <info> (wlan0): supplicant connection state: associating -> 4-way handshake Mar 7 19:22:16 wpa_supplicant[945]: Associated with 00:21:91:35:83:8b Mar 7 19:22:16 NetworkManager: <info> (wlan0): supplicant connection state: 4-way handshake -> associated Mar 7 19:22:26 wpa_supplicant[945]: Authentication with 00:21:91:35:83:8b timed out. Mar 7 19:22:26 wpa_supplicant[6837]: Authentication with 00:21:91:35:83:8b timed out. Mar 7 19:22:26 wpa_supplicant[6837]: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Mar 7 19:22:26 NetworkManager: <info> (wlan0): supplicant connection state: associated -> disconnected Mar 7 19:22:26 wpa_supplicant[945]: Failed to initiate AP scan. Mar 7 19:22:26 wpa_supplicant[945]: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Mar 7 19:22:26 NetworkManager: <info> (wlan0): supplicant connection state: disconnected -> scanning Mar 7 19:22:26 NetworkManager: <info> (wlan0): supplicant connection state: scanning -> disconnected Mar 7 19:22:29 wpa_supplicant[6837]: CTRL-EVENT-SCAN-RESULTS Mar 7 19:22:29 wpa_supplicant[6837]: WPS-AP-AVAILABLE Mar 7 19:22:29 wpa_supplicant[6837]: Trying to associate with 00:21:91:35:83:8b (SSID='dlink' freq=2437 MHz) Mar 7 19:22:29 wpa_supplicant[6837]: Association request to the driver failed Mar 7 19:22:29 wpa_supplicant[945]: CTRL-EVENT-SCAN-RESULTS Mar 7 19:22:29 wpa_supplicant[945]: WPS-AP-AVAILABLE Mar 7 19:22:29 wpa_supplicant[945]: Trying to associate with 00:21:91:35:83:8b (SSID='dlink' freq=2437 MHz) Mar 7 19:22:29 wpa_supplicant[945]: Association request to the driver failed Mar 7 19:23:16 NetworkManager: <info> (wlan0): supplicant connection state: scanning -> associating Mar 7 19:23:16 wpa_supplicant[6837]: WPA: EAPOL-Key Replay Counter did not increase - dropping packet Mar 7 19:23:16 wpa_supplicant[6837]: Associated with 00:21:91:35:83:8b Mar 7 19:23:16 NetworkManager: <info> (wlan0): supplicant connection state: associating -> 4-way handshake Mar 7 19:23:16 wpa_supplicant[945]: Associated with 00:21:91:35:83:8b Mar 7 19:23:16 NetworkManager: <info> (wlan0): supplicant connection state: 4-way handshake -> associated Mar 7 19:23:26 wpa_supplicant[945]: Authentication with 00:21:91:35:83:8b timed out. Mar 7 19:23:26 wpa_supplicant[6837]: Authentication with 00:21:91:35:83:8b timed out. Mar 7 19:23:26 wpa_supplicant[6837]: CTRL-EVENT-DISCONNECTED - Disconnect event - remove key3 Mar 7 19:23:26 NetworkManager: <info> (wlan0): supplicant connection state: associated -> disconnected Mar 7 19:23:26 wpa_supplicant[945]: Failed to initiate AP scan. Mar 7 19:23:26 wpa_supplicant[945]: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Mar 7 19:23:26 NetworkManager: <info> (wlan0): supplicant connection state: disconnected -> scanning Mar 7 19:23:26 NetworkManager: <info> (wlan0): supplicant connection state: scanning -> disconnected Mar 7 19:23:29 wpa_supplicant[6837]: CTRL-EVENT-SCAN-RESULTS Mar 7 19:23:29 wpa_supplicant[6837]: WPS-AP-AVAILABLE Mar 7 19:23:29 wpa_supplicant[6837]: Trying to associate with 00:21:91:35:83:8b (SSID='dlink' freq=2437 MHz) Mar 7 19:23:29 wpa_supplicant[6837]: Association request to the driver failed Mar 7 19:23:29 wpa_supplicant[945]: CTRL-EVENT-SCAN-RESULTS Mar 7 19:23:29 wpa_supplicant[945]: WPS-AP-AVAILABLE Mar 7 19:23:29 wpa_supplicant[945]: Trying to associate with 00:21:91:35:83:8b (SSID='dlink' freq=2437 MHz) Mar 7 19:23:29 wpa_supplicant[945]: Association request to the driver failed Mar 7 19:23:29 NetworkManager: <info> (wlan0): supplicant connection state: disconnected -> associating Mar 7 19:23:31 wpa_supplicant[6837]: Associated with 00:21:91:35:83:8b Mar 7 19:23:31 wpa_supplicant[945]: Associated with 00:21:91:35:83:8b Mar 7 19:23:31 NetworkManager: <info> (wlan0): supplicant connection state: associating -> associated Mar 7 19:23:32 NetworkManager: <info> (wlan0): supplicant connection state: associated -> 4-way handshake Mar 7 19:23:32 wpa_supplicant[945]: WPA: Invalid EAPOL-Key MIC when using TPTK - ignoring TPTK Mar 7 19:23:32 wpa_supplicant[945]: WPA: Could not verify EAPOL-Key MIC - dropping packet Mar 7 19:23:34 NetworkManager: <info> wlan0: link timed out. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0/wireless): association took too long. Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 5 -> 6 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0/wireless): asking for new secrets Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled... Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started... Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 6 -> 4 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled... Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting... Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 4 -> 5 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0/wireless): access point 'dlink' has security, but secrets are required. Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 5 -> 6 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled... Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started... Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 6 -> 4 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled... Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting... Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 4 -> 5 (reason 0) Mar 7 19:23:41 wpa_supplicant[6837]: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Mar 7 19:23:41 wpa_supplicant[945]: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0/wireless): access point 'dlink' has security, but secrets are required. Mar 7 19:23:41 wpa_supplicant[945]: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0/wireless): access point 'dlink' has security, but secrets are required. Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 5 -> 6 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled... Mar 7 19:23:41 NetworkManager: <info> (wlan0): supplicant connection state: 4-way handshake -> disconnected Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started... Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 6 -> 4 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled... Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting... Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 4 -> 5 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0/wireless): access point 'dlink' has security, but secrets are required. Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 5 -> 6 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) scheduled... Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) started... Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 6 -> 4 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) scheduled... Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 1 of 5 (Device Prepare) complete. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) starting... Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 4 -> 5 (reason 0) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0/wireless): access point 'dlink' has security, but secrets are required. Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 5 -> 9 (reason 7) Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) failed for access point (dlink) Mar 7 19:23:41 NetworkManager: <info> Marking connection 'dlink' invalid. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) failed. Mar 7 19:23:41 NetworkManager: <info> Activation (wlan0) Stage 2 of 5 (Device Configure) complete. Mar 7 19:23:41 NetworkManager: <info> (wlan0): device state change: 9 -> 3 (reason 0) Mar 7 19:23:41 NetworkManager: <info> (wlan0): deactivating device (reason: 0). Mar 7 19:23:41 wpa_supplicant[6837]: Failed to initiate AP scan. ... |
| 07.03.2010, 20:53:21 |
start [/forum/topic.php?desktop=1&fid=25&tid=1485068]: |
36ms |
47ms |
| others: | 298ms |
| total: | 443ms |
