startx + vga=0x318?
Если добавить параметр vga=0x318 в загрузку ядра, то перестаёт работать команда xstart, пишет ошибку: автор[root@node0 ~]# startx xauth: creating new authority file /root/.serverauth.4559 X Window System Version 7.1.1 Release Date: 12 May 2006 X Protocol Version 11, Revision 0, Release 7.1.1 Build Operating System: Linux 2.6.18-164.11.1.el5 x86_64 Red Hat, Inc. Current Operating System: Linux node0 2.6.18-194.el5 #1 SMP Tue Mar 16 21:52:39 EDT 2010 x86_64 Build Date: 06 March 2010 Build ID: xorg-x11-server 1.1.1-48.76.el5 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Module Loader present Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 19 06:25:35 2010 (EE) Unable to locate/open config file New driver is "mga" (==) Using default built-in configuration (55 lines) Fatal server error: Cannot run in framebuffer mode. Please specify busIDs for all framebuffer devices XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0" after 0 requests (0 known processed) with 0 events remaining. Если убрать vga=0x318 из menu.lst, то xstart загружается, но в нём низкое разрешение. Как бы сделать так, чтобы консоль была с vga=0x318 и xstart работал? RedHat 5.5 ... |
| 19.10.2010, 10:37:23 |
startx + vga=0x318?
В логе /var/log/Xorg.0.log пишет: автор... Fatal server error: Cannot run framebuffer mode. Please specify busID's for all framebuffer devices. ... |
| 19.10.2010, 10:55:06 |
startx + vga=0x318?
Проблема решилась. ... |
| 19.10.2010, 11:57:11 |
start [/forum/topic.php?desktop=1&fid=25&tid=1484663]: |
25ms |
46ms |
61ms |
| others: | 321ms |
| total: | 505ms |
